thinkgeo.mapsuite.core.gridfeaturelayer
ThinkGeo.MapSuite.Core.GridFeatureLayer
This class uses the grid file provided.
      • ThinkGeo.MapSuite.Core.FeatureLayer
        • ThinkGeo.MapSuite.Core.GridFeatureLayer
GridFeatureLayer()
This is the default constructor for the class.
GridFeatureLayer(String)
  • gridPathFilename
    • Description:This parameter is the path and filename of the grid file you want to use.
GenerateGridMatrix()
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
GenerateGrid(GridDefinition,GridInterpolationModel,Stream)
  • outputStream
    • Type:Stream
GenerateGridMatrix(GridDefinition,GridInterpolationModel)
GetBoundingBoxCore()
This method returns the bounding box of the FeatureLayer.
This method is called from the concrete public method GetBoundingBox. It returns the bounding box of the FeatureLayer.
  • Description:This method returns the bounding box of the FeatureLayer.
1BU=(IEnumerable<String>)
  • returningColumnNames
    • Type:IEnumerable<String>
1xU=(GeoCanvas,Dictionary<String,Collection<Feature»,Collection<SimpleCandidate>,ZoomLevel,RectangleShape)
  • featuresForFilters
  • currentZoomLevel
SetupTools()
SetupToolsCore()
OpenCore()
CloseCore()
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
PathFilename
This property gets and sets the path and filename to the grid file you want to use.
This should be the complete path and filename of a grid file.
CellSize
Gets the cell size from the grid.
NumberOfColumns
Gets the column number from the grid.
NumberOfRows
Gets the row number from the grid.
NoDataValue
Gets the NoDataValue from the grid.
HasBoundingBox
This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In GridFeatureLayer, we override this API and mark it as true.
DataValueColumnName
WrappingExtent
WrappingMode
EditTools
FeatureIdsToExclude
  • Type:Collection<String>
QueryTools
MaxRecordsToDraw
FeatureSource
DrawingQuality
ZoomLevelSet
DrawingMarginPercentage
DrawingMarginInPixel
  • Type:Single
GeometryValidationMode
RequestDrawingInterval
  • Type:TimeSpan
IsOpen
DrawingTime
  • Type:TimeSpan
Attribution
IsVisible
Transparency
  • Type:Single
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
KeyColors
IsNegative
IsGrayscale
DrawingExceptionMode
yhU=
  • Type:Int64
zRU=
  • Type:Int64
0BU=
  • Type:TimeSpan
0xU=
  • Type:TimeSpan
IsOpenCore
StreamLoading N/A
DrawingFeatures N/A
DrawingWrappingFeatures N/A
RequestedDrawing N/A
RequestingDrawing N/A
DrawingProgressChanged N/A
DrawingException N/A
DrawnException N/A
DrawingAttribution N/A
DrawnAttribution N/A
thinkgeo.mapsuite.core.gridfeaturelayer.1442555043.txt.gz · Last modified: 2015/09/18 05:44 by admin
