<!– Class –> This gradient style is a new style with the concept of GradientBrush. By specifying the LowerValue and its color, as well as the UpperValue and its color, we can set the color of each feature based on a column value using linear interpolation.
*System.Object ThinkGeo.MapSuite.Core.Style *ThinkGeo.MapSuite.Core.GradientStyle
GradientStyle | String, Double, GeoSolidBrush, Double, GeoSolidBrush | This constructor creates a new instance by passing the ColumnName (which it will get the data from) as well as the lowerValue and its corresponding SolidBrush, and the upperValue and its corresponding SolidBrush. | |
GradientStyle | String, Double, GeoSolidBrush, Double, GeoSolidBrush, Double, GeoSolidBrush | This constructor creates a new instance by passing the ColumnName (which it will get the data from) as well as the lowerValue and its corresponding SolidBrush, the upperValue and its corresponding SolidBrush, and the NoDataValue and its corresponding SolidBrush. |
CloneDeep | Style | Create a copy of style using the deep clone process. | |
Draw | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the features on the canvas you provided. |
Draw | IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the shapes on the canvas you provided. |
DrawSample | GeoCanvas | Style | |
DrawSample | GeoCanvas, DrawingRectangleF | Style | This method draws a sample feature on the canvas you provided. |
GetRequiredColumnNames | Style | This method returns the column data for each feature that is required for the style to properly draw. | |
![]() LoadStyle | Uri | Style | |
![]() LoadStyle | Stream | Style | |
SaveStyle | String | Style | |
SaveStyle | Stream | Style | |
CloneDeepCore | Style | Create a copy of style using the deep clone process. The default implementation method uses serialization. | |
DrawCore | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style(overriden) | This method draws the features on the canvas you provided. |
DrawSampleCore | GeoCanvas, DrawingRectangleF | Style | This method draws a sample feature on the canvas you provided. |
GetRequiredColumnNamesCore | Style(overriden) | This method returns the column data for each feature that is required for the style to properly draw. | |
ColumnName | String | This property gets and sets the column name used in the style. | |
Filters | Collection<String> | Style | |
IsActive | Boolean | Style | This property gets and sets the active status of the style. |
LowerGeoSolidBrush | GeoSolidBrush | This property gets and sets the solid brush that is used for the style's lower value. | |
LowerValue | Double | This property gets and sets the lower value used in the style. | |
Name | String | Style | This property gets and set the name of the style. |
NoDataSolidBrush | GeoSolidBrush | This property gets and sets the solid brush that is used for the style's NoDataValue. | |
NoDataValue | Double | This property gets and sets the no data value used in the style. | |
RequiredColumnNames | Collection<String> | Style | This property gets the collection of fields that are required for the style. |
UpperGeoSolidBrush | GeoSolidBrush | This property gets and sets the solid brush that is used for the style's upper value. | |
UpperValue | Double | This property gets and sets the upper value used in the style. |
FiltersCore | Collection<String> | Style |
In this constructor, the NoDataValue defaults to -9999 and the NoDataBrush color is transparent.
| columnName | String<!– System.String –> | |
| lowerValue | Double<!– System.Double –> | |
| lowerGeoSolidBrush | GeoSolidBrush<!– ThinkGeo.MapSuite.Core.GeoSolidBrush –> | |
| upperValue | Double<!– System.Double –> | |
| upperGeoSolidBrush | GeoSolidBrush<!– ThinkGeo.MapSuite.Core.GeoSolidBrush –> |
| upperGeoSolidBrush | GeoSolidBrush<!– ThinkGeo.MapSuite.Core.GeoSolidBrush –> | |
| noDataValue | Double<!– System.Double –> | |
| noDataSolidBrush | GeoSolidBrush<!– ThinkGeo.MapSuite.Core.GeoSolidBrush –> |
| Style<!– ThinkGeo.MapSuite.Core.Style –> | A cloned style. |
<!– ThinkGeo.MapSuite.Core.Style –> Go Back
| features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Feature} –> | This parameter represents the features you want to draw on the canvas. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter represents the canvas you want to draw the features on. |
| labelsInThisLayer | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> | The labels will be drawn in the current layer only. |
| labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> | The labels will be drawn in all layers. |
| shapes | IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.BaseShape} –> | This parameter represents the shapes you want to draw on the canvas. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter represents the canvas you want to draw the shapes on. |
This method is the concrete wrapper for the abstract method DrawSampleCore. In this method we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area.
| drawingExtent | DrawingRectangleF<!– ThinkGeo.MapSuite.Core.DrawingRectangleF –> |
| Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns a collection of column names that the style needs. |
<!– static –>
| styleUri | Uri<!– System.Uri –> |
<!– static –>
| styleStream | Stream<!– System.IO.Stream –> |
| filePathName | String<!– System.String –> |
| stream | Stream<!– System.IO.Stream –> |
This virtual method is called from the concrete public method Draw. In this method, we take the features you passed in and draw them on the canvas you provided. Each style (based on its properties) may draw each feature differently.
When implementing this virtual method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
<!– ThinkGeo.MapSuite.Core.Style(overriden) –> Go Back
This virtual method is called from the concrete public method Draw. In this method, we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area.
When implementing this virtual method, consider the canvas size and draw the sample image appropriately. You should keep in mind that the sample typically shows up on a legend.
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw.
None.
<!– ThinkGeo.MapSuite.Core.GradientStyle –> Go Back
None.
None.
None.
None.
None.
None.
