thinkgeo.mapsuite.core.geoserializer
ThinkGeo.MapSuite.Core.GeoSerializer
<!– Class –> This class serializes an object.
Public MethodGeoSerializer Creates an instance of GeoSerializer.
Public MethodGeoSerializer GeoSerializationFormatter
Public MethodDeserialize String, FileAccess Recreates an object from a file.
Public MethodDeserialize Stream Recreates an object from a stream.
Public MethodDeserialize String Recreates an object from a string.
Public MethodDeserialize Uri Recreates an object from an Url.
Public MethodGetType Object
Public MethodSerialize Object, String Serialize an object and save the serialized data to a file.
Public MethodSerialize Object, Stream Serialize an object and save the serialized data to a stream.
Public MethodSerialize Object Serialize an object and save the serialized data to a string.
Public MethodToString Object
Public PropertyFormatter GeoSerializationFormatter Gets or sets the Formatter. The Formatter determines what kind of serialized data will be created.
GeoSerializer()
Name Type Description
Go Back
GeoSerializer(GeoSerializationFormatter)
formatter GeoSerializationFormatter<!– ThinkGeo.MapSuite.Core.GeoSerializationFormatter –>
Go Back
Deserialize(String, FileAccess)
Return Type Description
Object<!– System.Object –> The recreated object.
sourcePathFileName String<!– System.String –> The file path to deserialize from.
fileAccess FileAccess<!– System.IO.FileAccess –> The FileAccess
<!– ThinkGeo.MapSuite.Core.GeoSerializer –> Go Back
Deserialize(Stream)
sourceStream Stream<!– System.IO.Stream –> The Stream to deserialize from.
Deserialize(String)
sourceString String<!– System.String –> The string to deserialize from.
Deserialize(Uri)
sourceUri Uri<!– System.Uri –> The Url to deserialize from.
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
Serialize(Object, String)
Void<!– System.Void –>
objectToSerialize Object<!– System.Object –> The object to be serialized.
targetPathFileName String<!– System.String –> The path to save the serialized data to.
Serialize(Object, Stream)
targetStream Stream<!– System.IO.Stream –> The stream to save the serialized data into.
Serialize(Object)
String<!– System.String –> The string that contains the serialized data.
Formatter
Return Type
thinkgeo.mapsuite.core.geoserializer.1440040128.txt.gz · Last modified: 2015/09/17 09:02 (external edit)
