<!– Class –> This class formats a GeoObjectModel into serialized data.
*System.Object ThinkGeo.MapSuite.Core.GeoSerializationFormatter *ThinkGeo.MapSuite.Core.XmlGeoSerializationFormatter
![]() | Creates an instance of GeoSerializationFormatter. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Stream | Load a stream into a GeoObjectModel. | |
![]() | GeoObjectModel, Stream | Save serialized data into a stream. | |
![]() | Object |
![]() | Object | ||
![]() | Object | ||
![]() | GeoObjectModel, Stream | Format a GeoObjectModel into serialized data, and save the data into a stream. |
![]() | Encoding | set or get the readEncoding. |
Name | Type | Description |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
GeoObjectModel<!– ThinkGeo.MapSuite.Core.GeoObjectModel –> | The GeoObjectModel recreated from the stream. |
stream | Stream<!– System.IO.Stream –> | The Stream to load from. |
<!– ThinkGeo.MapSuite.Core.GeoSerializationFormatter –> Go Back
Void<!– System.Void –> |
model | GeoObjectModel<!– ThinkGeo.MapSuite.Core.GeoObjectModel –> | The GeoObjectModel to create serialized data for. |
stream | Stream<!– System.IO.Stream –> | The Stream to save serialized data into. |
String<!– System.String –> |
Return Type |
Encoding<!– System.Text.Encoding –> |
