This static class exposes a number of helpful methods when dealing with extents.
GetScreenDistanceBetweenTwoWorldPoints
GetWorldDistanceBetweenTwoScreenPoints
This is a static function that allows you to pass in a world rectangle, a world point to center on, and a height and width in screen units. The function will center the rectangle based on the point, then adjust the rectangle's ratio based on the height and width in screen coordinates.
worldExtent
worldPoint
screenWidth
screenHeight
worldExtent
centerFeature
screenWidth
screenHeight
This method returns an adjusted extent centered on a point.
worldExtent
screenX
screenY
screenWidth
screenHeight
This API gets the BoundingBox of a group of Features.
features
This API gets the BoundingBox of a group of BaseShapes.
shapes
This method returns an adjusted extent based on the ratio of the screen width and height.
This function is used because the extent to draw must be the rame ratio as the screen width and height. If they are not, then the image drawn will be stretched or compressed. We always adjust the extent upwards to ensure that no matter how we adjust it, the original extent will fit within the new extent. This ensures that everything you wanted to see in the first extent is visible and maybe a bit more.
worldExtent
screenWidth
screenHeight
This method returns the current scale.
worldExtent
screenWidth
worldExtentUnit
worldExtent
screenWidth
worldExtentUnit
dpi
This method returns the number of pixels between two world points.
worldExtent
worldPoint1
worldPoint2
screenWidth
screenHeight
This method returns the number of pixels between two features.
worldExtent
worldPointFeature1
worldPointFeature2
screenWidth
screenHeight
This method returns the distance in world units between two screen points.
worldExtent
screenPoint1X
screenPoint1Y
screenPoint2X
screenPoint2Y
screenWidth
screenHeight
worldExtentUnit
distanceUnit
worldExtent
screenPoint1
screenPoint2
screenWidth
screenHeight
worldExtentUnit
distanceUnit
This method returns a panned extent.
worldExtent
direction
percentage
worldExtent
degree
percentage
This method returns a RectangleShape by resize parameters.
sourceExtent
sourceScreenWidth
targetScreenWidth
targetScreenHeight
mapUnit
resizeType
This method returns an extent that is snapped to a zoom level in the provided zoom level set.
worldExtent
worldExtentUnit
screenWidth
screenHeight
zoomLevelSet
This method returns screen coordinates from world coordinates.
worldExtent
worldPointFeature
screenWidth
screenHeight
worldExtent
worldPoint
screenWidth
screenHeight
This method returns Rectangle in screen coordinates from RectangleShape in world coordinates.
worldExtent
targetExtent
currentExtentWidth
currentExtentHeight
worldExtent
worldX
worldY
screenWidth
screenHeight
This method returns world coordinates from screen coordinates.
worldExtent
screenX
screenY
screenWidth
screenHeight
worldExtent
screenPoint
screenWidth
screenHeight
This method returns a new extent that is zoomed in by the percentage provided.
worldExtent
percentage
This method returns an extent that is centered and zoomed in.
The resulting rectangle will already be adjusted for the ratio of the screen. You do not need to call GetDrawingExtent afterwards.
worldExtent
percentage
screenX
screenY
screenWidth
screenHeight
worldExtent
percentage
worldPoint
screenWidth
screenHeight
This method returns an extent that is centered and zoomed.
worldExtent
percentage
centerFeature
screenWidth
screenHeight
This method returns an extent that is keeping the offsetScreenPoint constant and zoomed.
The resulting rectangle will already be adjusted for the ratio of the screen. You do not need to afterward call GetDrawingExtent.
worldExtent
screenWidth
screenHeight
offsetScreenPoint
percentage
This method returns a new extent that is zoomed out by the percentage provided.
worldExtent
percentage
This method returns an extent that is centered and zoomed out.
worldExtent
percentage
centerFeature
screenWidth
screenHeight
worldExtent
percentage
worldPoint
screenWidth
screenHeight
The resulting rectangle will already be adjusted for the ratio of the screen. You do not need to call GetDrawingExtent afterward.
worldExtent
percentage
screenX
screenY
screenWidth
screenHeight
worldExtent
screenWidth
screenHeight
offsetScreenPoint
percentage
This method returns a extent that has been zoomed into a certain scale.
targetScale
worldExtent
worldExtentUnit
screenWidth
screenHeight
targetScale
worldExtent
worldExtentUnit
screenWidth
screenHeight
offsetScreenPoint
newWidth
newTileExtent
mapUnit
dpi
worldExtent
screenWidth
worldExtentUnit
dpi
scale
zoomLevelScales
minimumScale
maximumScale
worldExtent
screenWidth
worldExtentUnit
originalBitmap
destRect
srcRect
