This class allows you to display information by drawing points on an area based on a value from the features data.
This is the default constructor. If you use this constructor, you should set the values by the properties.
This constructor allows you to set everything you need to a standard scenario.
columnName
pointSize
If you require a custom point symbol, this constructor allows you to set everything you need. Custom points can include bitmaps and points that require custom fill brushes.
columnName
customPointStyle
