GetDegreesMinutesStringFromDecimalDegreePoint(Feature,Int32)
This method returns a string representation in degrees and minutes from a decimal degree point.
GetDegreesMinutesStringFromDecimalDegreePoint(Feature)
GetDegreesMinutesStringFromDecimalDegreePoint(PointShape)
GetDegreesMinutesStringFromDecimalDegreePoint(PointShape,Int32)
GetDegreesMinutesSecondsFromDecimalDegree(Double)
This method returns a degrees, minutes and seconds structure from a decimal degree value.
The method allows you pass in a decimal degree number and return the degree, minute, second as variables passed in on the method call.
GetDegreesMinutesSecondsStringFromDecimalDegree(Double)
This method returns a string representation in degrees, minutes and seconds from a decimal degree value.
Example: If you enter 75.358 as the number of decimal degrees, the result would be 75 degrees, 21 minutes, 28 seconds. Thus, the return string would be 75?21' 28“.
GetDegreesMinutesSecondsStringFromDecimalDegree(Double,Int32)
This method returns a string representation in degrees, minutes and seconds from a decimal degree value and a specified precision.
Example: If you enter 75.358 as the number of decimal degree and 12 as decimals, the result would be 75 degrees, 21 minutes, 28.80000000015 seconds. Thus, the return string would be 75?21' 28.80000000015”.
GetDegreesMinutesSecondsStringFromDecimalDegreePoint(PointShape)
Passing in a point will return the point's location represented in degrees, minutes, and seconds. For example, if the point's location in decimal degrees is (75.358, 36.345), the actual returned string would be “75?21' 29E 36?20' 42
N”.
GetDegreesMinutesSecondsStringFromDecimalDegreePoint(PointShape,Int32)
GetDegreesMinutesSecondsStringFromDecimalDegreePoint(Feature,Int32)
GetDegreesMinutesSecondsStringFromDecimalDegreePoint(Feature)
GetDecimalDegreeFromDegreesMinutesSeconds(String)
This method returns a decimal degree value based on a string containing degrees, minutes, and seconds.
If you pass in “75?21' 28''” as a string, then the result will be 75.35777777784.
GetDecimalDegreeFromDegreesMinutesSeconds(DegreesMinutesSeconds)
This method returns a decimal degree value based on a degree, minute and second structure.
If you pass in 75, 21 and 28, the result passed back will be 75.2577777778.
GetDecimalDegreeFromDegreesMinutesSeconds(Int32,Int32,Double)
This method returns a decimal degree value based on a set of degrees, minutes, and seconds.
GetDistanceFromDecimalDegrees(PointShape,PointShape,DistanceUnit)
This method returns the distance between two decimal degree points.
GetDistanceFromDecimalDegrees(Feature,Feature,DistanceUnit)
GetDistanceFromDecimalDegrees(Double,Double,Double,Double,DistanceUnit)
GetLongitudeDifferenceFromDistance(Double,DistanceUnit,Double)
Calculate the amount of longitude change given a certain distance and latitude.
GetLatitudeDifferenceFromDistance(Double,DistanceUnit)
Calculate the amount of longitude change given a certain distance and longitude.
Convert the input latitude and longitude to MGRS string
Convert the MGRS string to latitude and longitude
G0M=(Double,Double,Double,DistanceUnit,Double)
HEM=(Double,Double,Double,DistanceUnit,Double)
HUM=(PointShape,PointShape,Int32)
HkM=(Double,Double,Double,Double,PointShape,DistanceUnit)
H0M=(Double,Double,Double,Double,PointShape)
IEM=(Double,Double,DistanceUnit)
