GetDecimalDegreeFromDegreesMinutesSeconds
GetDegreesMinutesSecondsFromDecimalDegree
GetDegreesMinutesSecondsStringFromDecimalDegree
GetDegreesMinutesSecondsStringFromDecimalDegreePoint
GetDegreesMinutesStringFromDecimalDegreePoint
GetLatitudeDifferenceFromDistance
GetLongitudeDifferenceFromDistance
Convert the MGRS string to latitude and longitude
Convert the input latitude and longitude to MGRS string
longitude
latitude
This method returns a decimal degree value based on a set of degrees, minutes, and seconds.
If you pass in 75, 21 and 28, the result passed back will be 75.2577777778.
degrees
minutes
seconds
This method returns a decimal degree value based on a degree, minute and second structure.
degreesMinutesSeconds
This method returns a decimal degree value based on a string containing degrees, minutes, and seconds.
If you pass in “75?21' 28” as a string, then the result will be 75.35777777784.
* Return Type:Double
* Description:This method returns a decimal degree value based on a string containing degrees, minutes, and seconds.
==== Parameters ====
* Type:String
* Description:This parameter represents the degrees, minutes and seconds in a string.
Go Back
=== GetDegreesMinutesSecondsFromDecimalDegree(Double) ===
This method returns a degrees, minutes and seconds structure from a decimal degree value.
==== Remarks ====
The method allows you pass in a decimal degree number and return the degree, minute, second as variables passed in on the method call.
* Return Type:DegreesMinutesSeconds
* Description:This method returns a degrees, minutes and seconds structure from a decimal degree value.
decimalDegreesValue
* Type:Double
* Description:The decimal degree value you want to convert.
Go Back
=== GetDegreesMinutesSecondsStringFromDecimalDegree(Double) ===
This method returns a string representation in degrees, minutes and seconds from a decimal degree value.
==== Remarks ====
Example: If you enter 75.358 as the number of decimal degrees, the result would be 75 degrees, 21 minutes, 28 seconds. Thus, the return string would be 75?21' 28“.
* Return Type:String
* Description:This method returns a string representation in degrees, minutes and seconds from a decimal degree value.
decimalDegreesValue
* Type:Double
* Description:The number of decimal degrees to convert.
Go Back
=== GetDegreesMinutesSecondsStringFromDecimalDegree(Double,Int32) ===
This method returns a string representation in degrees, minutes and seconds from a decimal degree value and a specified precision.
==== Remarks ====
Example: If you enter 75.358 as the number of decimal degree and 12 as decimals, the result would be 75 degrees, 21 minutes, 28.80000000015 seconds. Thus, the return string would be 75?21' 28.80000000015”.
decimalDegreesValue
* Type:Double
* Description:The number of decimal degree to convert.
decimals
* Type:Int32
* Description:The number of float decision for the second.
Go Back
=== GetDegreesMinutesSecondsStringFromDecimalDegreePoint(Feature) ===
==== Remarks ====
point
* Type:Feature
* Description:The feature whose decimal degrees to convert.
Go Back
=== GetDegreesMinutesSecondsStringFromDecimalDegreePoint(Feature,Int32) ===
==== Remarks ====
point
* Type:Feature
decimalPlaces
* Type:Int32
Go Back
=== GetDegreesMinutesSecondsStringFromDecimalDegreePoint(PointShape,Int32) ===
==== Remarks ====
pointShape
* Type:PointShape
* Description:The point of decimal degree to convert.
decimals
* Type:Int32
Go Back
=== GetDegreesMinutesSecondsStringFromDecimalDegreePoint(PointShape) ===
==== Remarks ====
Passing in a point will return the point's location represented in degrees, minutes, and seconds. For example, if the point's location in decimal degrees is (75.358, 36.345), the actual returned string would be “75?21' 29E 36?20' 42''N”.
This method returns a string representation in degrees and minutes from a decimal degree point.
pointShape
decimals
point
decimals
This method returns the distance between two decimal degree points.
fromPoint
toPoint
returningUnit
fromPointFeature
toPointFeature
returningUnit
fromLongitude
fromLatitude
toLongitude
toLatitude
returningUnit
Calculate the amount of longitude change given a certain distance and longitude.
distance
distanceUnit
Calculate the amount of longitude change given a certain distance and latitude.
distance
distanceUnit
latitude
fromLongitude
fromLatitude
distance
distanceUnit
degree
fromPointX
fromPointY
toPointX
toPointY
pointShape
fromLongitude
fromLatitude
distance
distanceUnit
degree
fromPoint
toPoint
count
fromPointX
fromPointY
toPointX
toPointY
pointShape
lengthUnit
degreeX
degreeY
distanceUnit
