thinkgeo.mapsuite.core.cogocall
ThinkGeo.MapSuite.Core.CogoCall
CogoCall()
GetCallLine(PointShape,PointShape)
GetDescriptionString(CogoDirectionType,AngleUnit)
This method is the concrete method which always calls the associated core method. This is used to give us, the framework designer, flexability when user override the core method.
  • returningAngleUnit
GetTraverseString(CogoDirectionType,AngleUnit)
LoadFromTraverseString(String,CogoDirectionType,AngleUnit)
  • traverseString
GetCallLineCore(PointShape,PointShape)
GetDescriptionStringCore(CogoDirectionType,AngleUnit)
This abstract method has to be overridden in sub classes. It is responsible for converting the call into a descriptive string which will display on the call grid
GetTraverseStringCore(CogoDirectionType,AngleUnit)
This abstract method has to be overridden in sub classes. It is responsible for converting the call into a traverse string used to build up the traverse file for saving
LoadFromTraverseStringCore(String,CogoDirectionType,AngleUnit)
This method will populate this class from a single line of a traverse string
  • traverseString
IsPointOfBeginning
This porperty denotes if this call is the point of begining. This is the point from which we will begin the polygon
thinkgeo.mapsuite.core.cogocall.1442554754.txt.gz · Last modified: 2015/09/18 05:39 by admin
