This method is the concrete method which always calls the associated core method. This is used to give us, the framework designer, flexability when user override the core method.
returningDirectionType
returningAngleUnit
returningAngleUnit
traverseString
directionType
angleUnit
This abstract method has to be overridden in sub classes. It is responsible for converting the call into a descriptive string which will display on the call grid
returningAngleUnit
This abstract method has to be overridden in sub classes. It is responsible for converting the call into a traverse string used to build up the traverse file for saving
returningAngleUnit
This method will populate this class from a single line of a traverse string
traverseString
directionType
angleUnit
This porperty denotes if this call is the point of begining. This is the point from which we will begin the polygon
Return Type:Boolean
