If you use this constructor, you will need to set the properties of the fill brush and outline pen manually.
This constructor allows you to specify just a fill brush. In this way, the area you draw will not have an outline.
fillSolidBrush
This constructor allows you to specify a fill brush and an outline pen.
outlinePen
This constructor allows you to specify a fill brush and an outline pen. It also allows you to specify which is drawn first. If the pen is drawn first, the outline will be thinner than if the pen is drawn last. The effect is subtle but noticeable.
outlinePen
penBrushDrawingOrder
