thinkgeo.mapsuite.core.arcsdefeaturelayer
Table of Contents
ThinkGeo.MapSuite.Core.ArcSdeFeatureLayer
<!– Class –> This class represents a layer backed by an ArcSDE server.
Public MethodArcSdeFeatureLayer This is the class constructor.
Public MethodArcSdeFeatureLayer String, String, String, String, String, String, String, String, String This is the class constructor.
Public MethodCloneDeep Layer
Public MethodClose Layer
Public MethodDraw GeoCanvas, Collection<SimpleCandidate> Layer
Public MethodGetBoundingBox Layer
Public MethodGetFeatureClassNamesBySchema String This method is used to get a list of feature class names in the specified feature schema name.
Public MethodGetFeatureSchemaNames This method is used to get a list of feature schema names in the current datastore.
Public MethodGetType Object
Public MethodOpen Layer
Public MethodToString Object
Public PropertyConnectionString String This property gets and sets the connection string used to connect to the ArcSDE server.
Public PropertyDatastore String This property gets and sets the datastore of the ArcSDE server.
Public PropertyDrawingExceptionMode DrawingExceptionMode Layer
Public PropertyDrawingMarginPercentage Double FeatureLayer
Public PropertyDrawingQuality DrawingQuality FeatureLayer
Public PropertyDrawingTime TimeSpan Layer
Public PropertyEditTools EditTools FeatureLayer
Public PropertyFeatureClassName String This property gets and sets the name of the feature class in the feature schema.
Public PropertyFeatureIdsToExclude Collection<String> FeatureLayer
Public PropertyFeatureSchemaName String This property gets and sets the name of the feature schema in the datastore.
Public PropertyFeatureSource FeatureSource FeatureLayer
Public PropertyGeometryColumnName String This property gets and sets the name of the column that holds the geometry.
Public PropertyHasBoundingBox Boolean Layer(overriden) This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In ArcSdeFeatureLayer, we override this API and mark it as true.
Public PropertyIdColumnName String This property gets and sets the name of the column that holds the unique feature Id.
Public PropertyInstance String This property gets and sets the port of the ArcSDE server.
Public PropertyIsGrayscale Boolean Layer
Public PropertyIsNegative Boolean Layer
Public PropertyIsOpen Boolean Layer
Public PropertyIsVisible Boolean Layer
Public PropertyMaxRecordsToDraw Int32 FeatureLayer
Public PropertyName String Layer
Public PropertyPassword String This property gets and sets the password for the ArcSDE server.
Public PropertyQueryTools QueryTools FeatureLayer
Public PropertyServer String This property gets and sets the machine name or IP address of the ArcSDE server.
Public PropertyTransparency Single Layer
Public PropertyUsername String This property gets and sets the username for the ArcSDE server.
Public PropertyWrappingExtent RectangleShape FeatureLayer
Public PropertyWrappingMode WrappingMode FeatureLayer
Public PropertyZoomLevelSet ZoomLevelSet FeatureLayer
Protected PropertyIsOpenCore Boolean Layer(overriden)
ArcSdeFeatureLayer()
Overloads
This is the default constructor, which requires you to set the properties after you create the class.
Name Type Description
Go Back
ArcSdeFeatureLayer(String, String, String, String, String, String, String, String, String)
Overloads
This constructor allows you to input all required information to create an ArcSdeFeatureSource.
server String<!– System.String –> This parameter represents the machine name or IP address of the ArcSDE server.
instance String<!– System.String –> This parameter represents the port of the server.
username String<!– System.String –> This parameter represents the username for the ArcSDE server.
password String<!– System.String –> This parameter represents the password for the ArcSDE server.
datastore String<!– System.String –> This parameter represents the datastore of the ArcSDE server.
idColumnName String<!– System.String –> This parameter represents the name of the column that holds the unique feature Id.
featureSchemaName String<!– System.String –> This parameter represents the name of the feature schema in the datastore.
featureClassName String<!– System.String –> This parameter represents the name of the feature class in the feature schema.
geometryColumnName String<!– System.String –> This parameter represents the name of the column that holds the geometry.
Go Back
CloneDeep()
Return Type Description
Layer<!– ThinkGeo.MapSuite.Core.Layer –>
Close()
Void<!– System.Void –>
Draw(GeoCanvas, Collection<SimpleCandidate>)
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –>
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –>
Boolean<!– System.Boolean –>
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
GetFeatureClassNamesBySchema(String)
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –>
featureSchemaName String<!– System.String –> This parameter represents the feature schema name whose feature class names you want to list.
<!– ThinkGeo.MapSuite.Core.ArcSdeFeatureLayer –> Go Back
GetFeatureSchemaNames()
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> A list of schema names in the current datastore.
Int32<!– System.Int32 –>
Type<!– System.Type –>
Open()
CloneDeepCore()
CloseCore()
DrawCore(GeoCanvas, Collection<SimpleCandidate>)
DrawException(GeoCanvas, Exception)
e Exception<!– System.Exception –>
DrawExceptionCore(GeoCanvas, Exception)
GetBoundingBoxCore()
e DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingExceptionLayerEventArgs –>
e DrawingFeaturesEventArgs<!– ThinkGeo.MapSuite.Core.DrawingFeaturesEventArgs –>
<!– ThinkGeo.MapSuite.Core.FeatureLayer –> Go Back
e DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.Core.DrawingProgressChangedEventArgs –>
e DrawingWrappingFeaturesFeatureLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingWrappingFeaturesFeatureLayerEventArgs –>
e DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnExceptionLayerEventArgs –>
OpenCore()
SetupTools()
SetupToolsCore()
ConnectionString
Return Type
Datastore
Return Type
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –>
Return Type
Double<!– System.Double –>
DrawingQuality
Return Type
DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –>
DrawingTime
Return Type
TimeSpan<!– System.TimeSpan –>
EditTools
Return Type
EditTools<!– ThinkGeo.MapSuite.Core.EditTools –>
FeatureClassName
Return Type
FeatureIdsToExclude
Return Type
FeatureSchemaName
Return Type
FeatureSource
Return Type
FeatureSource<!– ThinkGeo.MapSuite.Core.FeatureSource –>
GeometryColumnName
Return Type
HasBoundingBox
Return Type
IdColumnName
Return Type
Instance
Return Type
IsGrayscale
Return Type
IsNegative
Return Type
IsOpen
Return Type
IsVisible
Return Type
MaxRecordsToDraw
Return Type
Return Type
Password
Return Type
QueryTools
Return Type
QueryTools<!– ThinkGeo.MapSuite.Core.QueryTools –>
Server
Return Type
Transparency
Return Type
Single<!– System.Single –>
Username
Return Type
WrappingExtent
Return Type
WrappingMode
Return Type
WrappingMode<!– ThinkGeo.MapSuite.Core.WrappingMode –>
ZoomLevelSet
Return Type
ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –>
IsOpenCore
Return Type
DrawingException
Event Arguments
Event Arguments
DrawingFeatures
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
DrawnException
Event Arguments
Event Arguments
NOTOC MapSuiteSpatialDataExtension ThinkGeo.MapSuite.Core UpdateDocumentation
thinkgeo.mapsuite.core.arcsdefeaturelayer.txt · Last modified: 2017/03/16 21:59 (external edit)
