thinkgeo.mapsuite.androidedition.vertexremovingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.VertexRemovingEditInteractiveOverlayEventArgs
Provides data for the VertexRemoving. event.
      • ThinkGeo.MapSuite.AndroidEdition.VertexRemovingEditInteractiveOverlayEventArgs
VertexRemovingEditInteractiveOverlayEventArgs()
VertexRemovingEditInteractiveOverlayEventArgs(Boolean,Feature,Vertex)
  • cancel
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • removingVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex to be removed.
AffectedVertexFeature
  • This property gets or sets the Feature to be used to remove vertex.
RemovingVertex
  • This property gets or sets the vertex to be removed.
Cancel
  • This property gets or sets the action to be canceled or not.
thinkgeo.mapsuite.androidedition.vertexremovingeditinteractiveoverlayeventargs.1442966354.txt.gz · Last modified: 2015/09/22 23:59 by admin
