thinkgeo.mapsuite.androidedition.vertexaddingtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.VertexAddingTrackInteractiveOverlayEventArgs
Provides data for the VertexAdding. event.
      • ThinkGeo.MapSuite.AndroidEdition.VertexAddingTrackInteractiveOverlayEventArgs
VertexAddingTrackInteractiveOverlayEventArgs()
VertexAddingTrackInteractiveOverlayEventArgs(Vertex,Feature,Boolean)
  • addingVertex
    • Type:Vertex
    • Description:This parameter specified the vertex is going to be added.
  • affectedFeature
    • Type:Feature
    • Description:This parameter specified the feature to be used to add vertex on when tracking shape.
  • cancel
Cancel
  • This property gets or sets the action to be canceled or not.
AddingVertex
  • This property gets or sets the feature to be used to add vertex on when tracking shape.
AffectedFeature
  • This property gets or sets the Feature to be used to add vertex to.
thinkgeo.mapsuite.androidedition.vertexaddingtrackinteractiveoverlayeventargs.1442966347.txt.gz · Last modified: 2015/09/22 23:59 by admin
