<!– Class –> Provides data for the VertexAdding. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.AndroidEdition.VertexAddingTrackInteractiveOverlayEventArgs
VertexAddingTrackInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
VertexAddingTrackInteractiveOverlayEventArgs | Vertex, Feature, Boolean | This is the commonly used constructor. |
AddingVertex | Vertex | This property gets or sets the feature to be used to add vertex on when tracking shape. | |
AffectedFeature | Feature | This property gets or sets the Feature to be used to add vertex to. | |
Cancel | Boolean | This property gets or sets the action to be canceled or not. |
| addingVertex | Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | This parameter specified the vertex is going to be added. |
| affectedFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specified the feature to be used to add vertex on when tracking shape. |
| cancel | Boolean<!– System.Boolean –> | This parameter specified the cancel property. |
<!– ThinkGeo.MapSuite.AndroidEdition.VertexAddingTrackInteractiveOverlayEventArgs –> Go Back
