thinkgeo.mapsuite.androidedition.vertexaddingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.VertexAddingEditInteractiveOverlayEventArgs
Provides data for the VertexAdding. event.
      • ThinkGeo.MapSuite.AndroidEdition.VertexAddingEditInteractiveOverlayEventArgs
VertexAddingEditInteractiveOverlayEventArgs()
VertexAddingEditInteractiveOverlayEventArgs(Boolean,Feature,Vertex)
  • cancel
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • addingVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex to be added.
AffectedVertexFeature
  • This property gets or sets the Feature to be used to move vertex.
AddingVertex
  • This property gets or sets the vertex to be added.
Cancel
  • This property gets or sets the action to be canceled or not.
thinkgeo.mapsuite.androidedition.vertexaddingeditinteractiveoverlayeventargs.1442966345.txt.gz · Last modified: 2015/09/22 23:59 by admin
