thinkgeo.mapsuite.androidedition.vertexaddededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.VertexAddedEditInteractiveOverlayEventArgs
Provides data for the VertexAdded. event.
      • ThinkGeo.MapSuite.AndroidEdition.VertexAddedEditInteractiveOverlayEventArgs
VertexAddedEditInteractiveOverlayEventArgs()
VertexAddedEditInteractiveOverlayEventArgs(Feature,Vertex)
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • addedVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex added.
AffectedVertexFeature
  • This property gets or sets the Feature to be used to remove vertex.
AddedVertex
  • This property gets or sets the vertex added.
thinkgeo.mapsuite.androidedition.vertexaddededitinteractiveoverlayeventargs.1442966341.txt.gz · Last modified: 2015/09/22 23:59 by admin
