<!– Class –> Provides data for the VertexAdded. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.AndroidEdition.VertexAddedEditInteractiveOverlayEventArgs
VertexAddedEditInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
VertexAddedEditInteractiveOverlayEventArgs | Feature, Vertex | This is the commonly used constructor. |
AddedVertex | Vertex | This property gets or sets the vertex added. | |
AffectedVertexFeature | Feature | This property gets or sets the Feature to be used to remove vertex. |
| Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> |
<!– ThinkGeo.MapSuite.AndroidEdition.VertexAddedEditInteractiveOverlayEventArgs –> Go Back
| Feature<!– ThinkGeo.MapSuite.Core.Feature –> |
