<!– Class –>
*System.Object ThinkGeo.MapSuite.Core.TileCache *ThinkGeo.MapSuite.Core.BitmapTileCache ThinkGeo.MapSuite.AndroidEdition.SqliteBitmapTileCache
SqliteBitmapTileCache | Initializes a new instance of the class. | ||
SqliteBitmapTileCache | String, String | Initializes a new instance of the class. |
ClearCache | TileCache | ||
DeleteTile | Tile | TileCache | |
DeleteTiles | RectangleShape | TileCache | |
GetHigherScaleTile | RectangleShape, Double | BitmapTileCache | |
GetTile | RectangleShape | BitmapTileCache | |
GetTile | Int64, Int64 | BitmapTileCache | |
GetTiles | RectangleShape | BitmapTileCache | |
SaveTile | Tile | TileCache | |
SaveTiles | GeoImage, RectangleShape | TileCache | |
ClearCacheCore | TileCache(overriden) | This abstract method will clear all the tiles in the tileCache, for each sub TileCache class must implement this method. | |
DeleteTileCore | Tile | TileCache(overriden) | This abstract method will delete the target tile passed in, for each sub TileCache class must implement this method. |
GetHigherScaleTileCore | RectangleShape, Double | BitmapTileCache | |
GetTileCore | Int64, Int64 | BitmapTileCache(overriden) | This abstract method returns the BitmapTile corresponding to passed in row and column. Each concrete TileCache need to implement this logic to get tile from a row and column. |
MemberwiseClone | Object | ||
MergeBitmaps | IEnumerable<BitmapTile>, Double | BitmapTileCache | |
OnGettingCacheImage | GettingCacheImageBitmapTileCacheEventArgs | BitmapTileCache | |
OnGottenCacheImage | GottenCacheImageBitmapTileCacheEventArgs | BitmapTileCache | |
SaveTileCore | Tile | TileCache(overriden) | This abstract method will save the target tile passed in, for each sub TileCache class must implement this method. |
CacheId | String | TileCache(overriden) | Gets or sets the id of the TileCache. |
DatabasePathFilename | String | Gets or sets the database path filename. | |
ImageFormat | TileImageFormat | TileCache | |
JpegQuality | Int16 | TileCache | |
LoadingTileImage | GeoImage | TileCache | |
NoDataTileImage | GeoImage | TileCache | |
TileAccessMode | TileAccessMode | TileCache | |
TileMatrix | TileMatrix | TileCache |
| databasePathFilename | String<!– System.String –> | The database path filename. |
| cacheId | String<!– System.String –> | The cache identifier. |
<!– ThinkGeo.MapSuite.Core.TileCache –> Go Back
| tile | Tile<!– ThinkGeo.MapSuite.Core.Tile –> |
| worldExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
| BitmapTile<!– ThinkGeo.MapSuite.Core.BitmapTile –> |
| tileBoundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
| tileScale | Double<!– System.Double –> |
<!– ThinkGeo.MapSuite.Core.BitmapTileCache –> Go Back
| row | Int64<!– System.Int64 –> | |
| column | Int64<!– System.Int64 –> |
| Collection<BitmapTile><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.BitmapTile} –> |
| bitmap | GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –> | |
| bitmapExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
This method will not take effect when the ReadOnly is set to true.
<!– ThinkGeo.MapSuite.Core.TileCache(overriden) –> Go Back
| tile | Tile<!– ThinkGeo.MapSuite.Core.Tile –> | The target tile to be deleted. |
| BitmapTile<!– ThinkGeo.MapSuite.Core.BitmapTile –> | Returns the BitmapTile corresponding to the passed in row and column. |
| row | Int64<!– System.Int64 –> | The target row for the tile to fetch. |
| column | Int64<!– System.Int64 –> | The target column for the tile to fetch. |
<!– ThinkGeo.MapSuite.Core.BitmapTileCache(overriden) –> Go Back
| tilesToMerge | IEnumerable<BitmapTile><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.BitmapTile} –> | |
| scale | Double<!– System.Double –> |
| e | GettingCacheImageBitmapTileCacheEventArgs<!– ThinkGeo.MapSuite.Core.GettingCacheImageBitmapTileCacheEventArgs –> |
| e | GottenCacheImageBitmapTileCacheEventArgs<!– ThinkGeo.MapSuite.Core.GottenCacheImageBitmapTileCacheEventArgs –> |
| tile | Tile<!– ThinkGeo.MapSuite.Core.Tile –> | The target tile to be saved. |
<!– ThinkGeo.MapSuite.AndroidEdition.SqliteBitmapTileCache –> Go Back
| TileImageFormat<!– ThinkGeo.MapSuite.Core.TileImageFormat –> |
| Int16<!– System.Int16 –> |
| TileAccessMode<!– ThinkGeo.MapSuite.Core.TileAccessMode –> |
| TileMatrix<!– ThinkGeo.MapSuite.Core.TileMatrix –> |
| Event Arguments |
| Event Arguments |
NOTOC AndroidEdition ThinkGeo.MapSuite.AndroidEdition UpdateDocumentation
