<!– Class –> This class represents an overlay that requesting images from OpenStreet Map Service.
*System.Object ThinkGeo.MapSuite.AndroidEdition.Overlay *ThinkGeo.MapSuite.AndroidEdition.TileOverlay ThinkGeo.MapSuite.AndroidEdition.OpenStreetMapOverlay
![]() | This is constructore of OpenStreetMapOverlay. | ||
![]() | GeoWebProxy | This is constructore of OpenStreetMapOverlay. |
![]() | Overlay | This method will simulate the Close interaction. | |
![]() | Overlay | This method dispose unmanaged resource used in this class. | |
![]() | MapArguments, OverlayRefreshType | Overlay | This method draws the overlay with the provided extent in world coordinate. |
![]() | Object | Object | |
![]() | Overlay | This method gets a bounding box of the Overlay. | |
![]() | Object | ||
![]() | Object | ||
![]() | MapArguments | Overlay | This method initializes overlay object. |
![]() | Overlay | This method will simulate the Open interaction. | |
![]() | TransformArguments, MapArguments | Overlay | This method will simulate the PostTransform interaction. |
![]() | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
![]() | Object |
![]() | Overlay(overriden) | ||
![]() | Boolean | Overlay(overriden) | |
![]() | MapArguments, OverlayRefreshType | Overlay(overriden) | |
![]() | GeoCanvas, Exception | Overlay | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
![]() | TileView, MapArguments | TileOverlay | Redraws a specified tile with the provided world extent. |
![]() | GeoCanvas, TileView | TileOverlay(overriden) | This method overrides from its base class TileOverlay. It actually requests image for the passed tile with the passed world extent. |
![]() | Object(overriden) | ||
![]() | Overlay(overriden) | This method gets a world extent for holding the entire OpenStreed map. | |
![]() | Context | TileOverlay | Get a new tile object to form the TileOverlay. |
![]() | Context | TileOverlay(overriden) | This method gets a concrete tile class to form this overlay. |
![]() | Double, Int32, Int32, GeographyUnit | TileOverlay | |
![]() | MapArguments, Double | TileOverlay | |
![]() | Object | ||
![]() | DrawingExceptionOverlayEventArgs | Overlay | This method raises before the overlay is drawing exception. |
![]() | DrawnExceptionOverlayEventArgs | Overlay | This method raises after the overlay is drawn exception. |
![]() | SendingWebRequestEventArgs | ||
![]() | SentWebRequestEventArgs | ||
![]() | Overlay | This protected virtual method is the Core method of Open API. | |
![]() | TransformArguments, MapArguments | Overlay(overriden) | |
![]() | String | Overlay | Gets or sets the attribution for this overlay. |
![]() | Collection<Uri> | ||
![]() | DrawingExceptionMode | Overlay | This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing. |
![]() | DrawingQuality | Overlay | Gets or sets the drawingQuality for this overlay. |
![]() | Boolean | Overlay | This property gets if this overlay is empty or not. |
![]() | LayerType | TileOverlay | Gets or sets the LayerType of the Overlay. |
![]() | MapArguments | Overlay | Gets or sets the mapArguments for this overlay. |
![]() | String | Overlay | Gets or sets the name of this overaly. |
![]() | Double | Overlay | Gets or sets the opacity for this overlay. |
![]() | BitmapTileCache | ||
![]() | Projection | ||
![]() | BitmapTileCache | TileOverlay(overriden) | |
![]() | TileSnappingMode | TileOverlay | Gets or sets the tile snapping mode. |
![]() | TileType | TileOverlay | Gets and sets the overlay is formed by multiple tiles or single tile. |
![]() | Int32 | Gets or sets the length of time, in seconds, before the request times out. | |
![]() | TransitionEffect | TileOverlay | Gets and sets the transition effect of the overlay when zooming. After zooming, the existing tiles stretch and leave in current viewport. Set to None when its background is transparent. |
![]() | GeoWebProxy | Gets or sets the WebProxy for using OpenStreet map service. |
![]() | TileView | TileOverlay | Gets or sets the single tile. |
![]() | DrawingExceptionOverlayEventArgs | Overlay | Occurs before exception is drawing on map. |
![]() | DrawnExceptionOverlayEventArgs | Overlay | Occurs after exception is drawn on map. |
Name | Type | Description |
webProxy | GeoWebProxy<!– ThinkGeo.MapSuite.Core.GeoWebProxy –> | This parameter indicates a WebProxy for requesting image from OpenStreet imagery service. |
Return Type | Description |
Void<!– System.Void –> |
<!– ThinkGeo.MapSuite.AndroidEdition.Overlay –> Go Back
mapArguments | MapArguments<!– ThinkGeo.MapSuite.AndroidEdition.MapArguments –> | This parameter maintains current map information for calculating mechanism. |
refreshType | OverlayRefreshType<!– ThinkGeo.MapSuite.AndroidEdition.OverlayRefreshType –> | This parameter indicates whether the elements of this overlay needs to be refreshed. For example, TileOverlay is formed by tiles. When panning the map around, the existing tile doesn't need to be redraw, the only thing we need to do is modifying the position of these tiles. On another hand, when click to change the style of the overlay, we need to redraw the tile images to change the appearance. So we need refresh mode. |
This method is the concrete wrapper for the abstract method GetBoundingBoxCore. This method returns the bounding box of the Overlay.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | A RectangleShape indicating the bounding box of this overlay. |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
This is a wrapper method for the virtual method InitializeCore.
transformInfo | TransformArguments<!– ThinkGeo.MapSuite.AndroidEdition.TransformArguments –> | This parameter maintains the transfrom information for calculating transform. |
String<!– System.String –> |
<!– ThinkGeo.MapSuite.AndroidEdition.Overlay(overriden) –> Go Back
isDisposing | Boolean<!– System.Boolean –> |
mapArguments | MapArguments<!– ThinkGeo.MapSuite.AndroidEdition.MapArguments –> | |
geoCanvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | |
exception | Exception<!– System.Exception –> |
ex | Exception<!– System.Exception –> |
tile | TileView<!– ThinkGeo.MapSuite.AndroidEdition.TileView –> | A Tile object that is created by the GetTile(Context) method to draw. |
<!– ThinkGeo.MapSuite.AndroidEdition.TileOverlay –> Go Back
tile | TileView<!– ThinkGeo.MapSuite.AndroidEdition.TileView –> | A tile object that creating by the GetTileCore method. It's the tile which needs to be draw in this mehtod. |
<!– ThinkGeo.MapSuite.AndroidEdition.TileOverlay(overriden) –> Go Back
context | Context<!– Android.Content.Context –> | Interface to global information about an application environment. |
TileView<!– ThinkGeo.MapSuite.AndroidEdition.TileView –> | A concrete Tile object that for requesting images from OpenStreet serverice. |
TileMatrix<!– ThinkGeo.MapSuite.Core.TileMatrix –> |
scale | Double<!– System.Double –> | |
tileWidth | Int32<!– System.Int32 –> | |
tileHeight | Int32<!– System.Int32 –> | |
boundingBoxUnit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> |
Collection<TileMatrixCell><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.TileMatrixCell} –> |
targetScale | Double<!– System.Double –> |
When implementing this method, consider initializing the overlay canvas such as setting its z-index, setting current map reference to the CurrentMap property.
mapArgument | MapArguments<!– ThinkGeo.MapSuite.AndroidEdition.MapArguments –> |
args | DrawingExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.DrawingExceptionOverlayEventArgs –> | This parameter is the event argument for DrawingException event. |
args | DrawnExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.DrawnExceptionOverlayEventArgs –> | This parameter is the event argument for DrawingException event. |
e | SendingWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SendingWebRequestEventArgs –> |
<!– ThinkGeo.MapSuite.AndroidEdition.OpenStreetMapOverlay –> Go Back
e | SentWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SentWebRequestEventArgs –> |
transformInfo | TransformArguments<!– ThinkGeo.MapSuite.AndroidEdition.TransformArguments –> | |
Return Type |
Return Type |
Collection<Uri><!– System.Collections.ObjectModel.Collection{System.Uri} –> |
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –> |
Return Type |
DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –> |
This property enhances the performance of the overlay while drawing. If is true, we will skip drawing this overlay and continue drawing the next overlay.
Return Type |
Return Type |
Return Type |
LayerType<!– Android.Views.LayerType –> |
Return Type |
Return Type |
Return Type |
Return Type |
BitmapTileCache<!– ThinkGeo.MapSuite.Core.BitmapTileCache –> |
Return Type |
Projection<!– ThinkGeo.MapSuite.Core.Projection –> |
Return Type |
Return Type |
TileSnappingMode<!– ThinkGeo.MapSuite.AndroidEdition.TileSnappingMode –> |
Return Type |
TileType<!– ThinkGeo.MapSuite.AndroidEdition.TileType –> |
Return Type |
Return Type |
TransitionEffect<!– ThinkGeo.MapSuite.AndroidEdition.TransitionEffect –> |
Return Type |
Return Type |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
NOTOC AndroidEdition ThinkGeo.MapSuite.AndroidEdition UpdateDocumentation
