<!– Class –> This class specifies the InterativeResult when deal with the Interative method in InterativeOverlay.
*System.Object **ThinkGeo.MapSuite.AndroidEdition.InteractiveResult
InteractiveResult | Constructor of InteractiveResult class. | ||
InteractiveResult | InteractiveOverlayDrawType, ProcessOtherOverlaysMode | Constructor of InteractiveResult class. |
DrawThisOverlay | InteractiveOverlayDrawType | Gets or sets the DrawThisOverlay type to indicicate to draw this overlay or not. | |
NewCurrentExtent | RectangleShape | Gets or sets the new current extent if the interative action affect the extent. | |
ProcessOtherOverlaysMode | ProcessOtherOverlaysMode | Gets or sets the DrawThisOverlay type to indicicate how to process other overlays. | |
TransformInfo | TransformArguments |
| interactiveOverlayDrawType | InteractiveOverlayDrawType<!– ThinkGeo.MapSuite.AndroidEdition.InteractiveOverlayDrawType –> | This parameter specified the interactiveOverlayDrawType to construct the class. |
| processOtherOverlays | ProcessOtherOverlaysMode<!– ThinkGeo.MapSuite.AndroidEdition.ProcessOtherOverlaysMode –> | This parameter specified the processOtherOverlays to construct the class. |
<!– ThinkGeo.MapSuite.AndroidEdition.InteractiveResult –> Go Back
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
| TransformArguments<!– ThinkGeo.MapSuite.AndroidEdition.TransformArguments –> |
