<!– Class –> Provides data for the FeatureRotated. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.AndroidEdition.FeatureRotatedEditInteractiveOverlayEventArgs
FeatureRotatedEditInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
FeatureRotatedEditInteractiveOverlayEventArgs | Feature | This is the commonly used constructor. |
RotatedFeature | Feature | This property gets or sets the Feature rotated. |
| rotatedFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specified the feature rotated. |
<!– ThinkGeo.MapSuite.AndroidEdition.FeatureRotatedEditInteractiveOverlayEventArgs –> Go Back
