thinkgeo.mapsuite.androidedition.featuredraggingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.FeatureDraggingEditInteractiveOverlayEventArgs
Provides data for the FeatureDragging. event.
      • ThinkGeo.MapSuite.AndroidEdition.FeatureDraggingEditInteractiveOverlayEventArgs
FeatureDraggingEditInteractiveOverlayEventArgs()
FeatureDraggingEditInteractiveOverlayEventArgs(Feature,Boolean,PointShape,PointShape)
  • draggingFeature
    • Type:Feature
    • Description:This parameter specified the target feature to be dragged.
  • cancel
  • sourceControlPoint
    • Description:This parameter specified the source control point to be dragged.
  • targetControlPoint
    • Description:This parameter specified the target control point to be dragged.
DraggingFeature
This property gets or sets the Feature to be used to dragged.
SourceControlPoint
This property gets or sets the source control point to drag.
TargetControlPoint
This property gets or sets the target control point to drag.
Cancel
thinkgeo.mapsuite.androidedition.featuredraggingeditinteractiveoverlayeventargs.1442831361.txt.gz · Last modified: 2015/09/21 10:29 by admin
