<PackageInfo>
<Id>MapSuiteDependency-EsriFileGeoDatabase</Id> <Title>Map Suite Dependency - EsriFileGeoDatabase</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <LicenseUrl>https://github.com/Esri/file-geodatabase-api/blob/master/FileGDB_API_1.5/License.txt</LicenseUrl> <RequireLicenseAcceptance>true</RequireLicenseAcceptance> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET FileGeoDatabase ESRI GeoDatabase</Tags> <Description>EsriFileGeoDatabase Wrapper is a .NET wrapper to help with using the unmanaged EsriFileGeoDatabase library.
A FileGeodatabase is a folder that holds a collection of files that can be accessed and edited by multiple users provided that they are not editing the same data at the same time. They are useful for very large projects that requires multiple people to work on.
This is a repackage of the third party EsriFileGeoDatabase project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly, it will be a dependency of other Map Suite packages.
The purpose of the repackage is to enable ThinkGeo to control release and debug versions known to be compatible with various Map Suite products and to provide ongoing backward compatibility independent from the original author. You can find more information at the link below.
Why we repackage: http://wiki.thinkgeo.com/wiki/map_suite_via_nuget#why_we_repackage
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#esrifilegeodatabase
Supported Platforms: Window
Source Website: http://www.gdal.org/drv_filegdb.html</Description> </PackageInfo>
<PackageInfo>
<Id>MapSuiteDependency-Fdo</Id> <Title>Map Suite Dependency - Fdo</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <LicenseUrl>http://fdo.osgeo.org/licenceAndGovernance.html</LicenseUrl> <RequireLicenseAcceptance>true</RequireLicenseAcceptance> <Description>MapSuite FDO Extension Wrapper is a .NET wrapper to assist in using the unmanaged MapSuite FDO Extension library.
From the OSGeo website: “FDO Data Access Technology is an API for manipulating, defining and analyzing geospatial information regardless of where it is stored. FDO uses a provider-based model for supporting a variety of geospatial data sources, where each provider typically supports a particular data format or data store.”
This is a repackage of the third party FDO project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly. It will be a dependency of other Map Suite packages.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#fdo
Supported Platforms: Windows
Source Website: http://fdo.osgeo.org/ml</Description>
<Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET FDO OSGeo Feature Data Objects Vector Raster Formats</Tags>
</PackageInfo>
<PackageInfo>
<Id>MapSuiteDependency-GdalS57</Id> <Title>Map Suite Dependency - GdalS57</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo/NauticalChartsViewerSample-ForWpf</ProjectUrl> <LicenseUrl>https://trac.osgeo.org/gdal/wiki/RevisedEPSGLicense</LicenseUrl> <RequireLicenseAcceptance>true</RequireLicenseAcceptance> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET GDAL S-57 ENC Electronic Navigation Charts S57</Tags> <Description>GdalS57 Wrapper is a .NET wrapper to help with using the unmanaged GdalS57 library.
International Hydrographic Organisation (IHO) S-57 Electronic Navigation Charts (ENC) datasets are supported for read access. The S-57 driver module produces features for all S-57 features in the S-57 file, and associated updates. S-57 (ENC) files normally have the extension “.000”. S-57 feature objects are translated into features. S-57 geometry objects are automatically collected and formed into geometries on the features.
This is a repackage of the third party S57 Gdal project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly, it will be a dependency of other Map Suite packages.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#gdals57
Source Website: http://www.gdal.org/</Description> </PackageInfo>
<PackageInfo>
<Id>MapSuiteDependency-HexagonGeospatialEcw</Id> <Title>Map Suite Dependency - HexagonGeospatialEcw</Title> <Summary /> <ReleaseNote /> <LicenseUrl>https://support.hexagonsafetyinfrastructure.com/infocenter/index?page=licensing_resources</LicenseUrl> <ProjectUrl>https://github.com/ThinkGeo/EcwSample-ForWinForms</ProjectUrl> <RequireLicenseAcceptance>true</RequireLicenseAcceptance> <Description>Erdas Raster Wrapper is .NET wrapper to help with using the unmanaged Erdas Raster library.
ECW (Enhanced Compression Wavelet) is a proprietary wavelet compression image format optimized for aerial and satellite imagery. It was developed by Earth Resource Mapping, and is now owned by Intergraph part of Hexagon AB. The lossy compression format efficiently compresses very large images with fine alternating contrast while retaining their visual quality.
This is a repackage of the third party HexagonGeospatialEcw project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly, it will be a dependency of other Map Suite packages.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#hexagongeospatialecw
Source Website: http://www.hexagongeospatial.com/</Description>
<Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET HexagonGeospatialEcw ECW Hexagon</Tags>
</PackageInfo>
<PackageInfo>
<Id>MapSuiteDependency-LibGeoTiff</Id> <Title>Map Suite Dependency - LibGeoTiff</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <LicenseUrl>https://bitmiracle.github.io/libtiff.net/#</LicenseUrl> <RequireLicenseAcceptance>true</RequireLicenseAcceptance> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET LibGeoTiff GeoTiff</Tags> <Description>LibGeoTiff is a .NET wrapper to help with using the GeoTiff format.
From the OSGeo website: “GeoTIFF represents an effort by over 160 different remote sensing, GIS, cartographic, and surveying related companies and organizations to establish a TIFF based interchange format for georeferenced raster imagery.”
This is a repackage of the third party LibGeoTiff project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly, it will be a dependency of other Map Suite packages.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#libgeotiff
Supported Platforms: Windows, Linux, macOS
Source Website: http://libtiff.org/</Description> </PackageInfo>
<PackageInfo>
<Id>MapSuiteDependency-LizardTechMrSid</Id> <Title>Map Suite Dependency - LizardTechMrSid</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo/MrSidSample-ForWinForms</ProjectUrl> <LicenseUrl>https://www.lizardtech.com/developer/portal-sdk-license</LicenseUrl> <RequireLicenseAcceptance>true</RequireLicenseAcceptance> <Description>LizardTechMrSid Wrapper is a .NET wrapper to help with using the unmanaged MrSid library.
MrSID (pronounced Mister Sid) is an acronym that stands for multiresolution seamless image database. It is a file format developed for encoding of georeferenced raster graphics, such as orthophotos. MrSID Rasters(.sid) contains a large raster image that is highly compressed that allows you to view parts of the image without having to decompress the whole image.
This is a repackage of the third party LizardTechMrSid project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly, it will be a dependency of other Map Suite packages.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#lizardtechmrsid
Source Website https://www.lizardtech.com/</Description>
<Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET LizardTech MrSid Multiresolution Seamless Image Database Raster</Tags>
</PackageInfo>
<PackageInfo>
<Id>MapSuiteDependency-Oracle</Id> <Title>Map Suite Dependency - Oracle</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <LicenseUrl>http://www.oracle.com/technetwork/licenses/odt-lic-152011.html</LicenseUrl> <RequireLicenseAcceptance>true</RequireLicenseAcceptance> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Oracle Database</Tags> <Description>Oracle Wrapper is a .NET wrapper to help with using the unmanaged Oracle library.
This is a repackage of the third party Oracle project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly, it will be a dependency of other Map Suite packages.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#oracle
Source Website: http://www.oracle.com/</Description> </PackageInfo>
<PackageInfo>
<Id>MapSuiteDependency-TeighaCad</Id> <Title>Map Suite Dependency - TeighaCad</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <LicenseUrl>http://wiki.thinkgeo.com/wiki/map_suite_dependencies_licenses</LicenseUrl> <RequireLicenseAcceptance>true</RequireLicenseAcceptance> <Description>For over a decade, Teigha has been the trusted solution for building CAD software recognized by hundreds of companies that require high-quality access to engineering data. With the ability to recover, repair, read and write .dwg files, Teigha enables companies to maintain and develop their intellectual property.
This is a repackage of the third party CAD project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly, it will be a dependency of other Map Suite packages.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#teighacad
Source Website: https://www.opendesign.com/</Description>
<Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET TeighaCad CAD DWG DGN</Tags>
</PackageInfo>
<PackageInfo>
<Id>MapSuiteDependency-UnmanagedProj4Projection</Id> <Title>Map Suite Dependency - UnmanagedProj4Projection</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <LicenseUrl>http://proj4.org/license.html</LicenseUrl> <RequireLicenseAcceptance>true</RequireLicenseAcceptance> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET GdalGeoRasterProjection GDAL</Tags> <Description>UnmanagedProj4Projection Wrapper is a .NET wrapper to help with using the unmanaged Proj4Projection library.
Proj.4 is a standard UNIX filter function which converts geographic longitude and latitude coordinates into cartesian coordinates (and vice versa), and it is a C API for software developers to include coordinate transformation in their own software.
This is a repackage of the third party GeoRaster Projection project for use with ThinkGeo's Map Suite product line.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#unmanagedproj4projection
Source Website: https://github.com/OSGeo/proj.4/</Description> </PackageInfo>
<PackageInfo>
<Id>MapSuiteDependency-WindowsAPICodePack</Id> <Title>Map Suite Dependency - WindowsAPICodePack</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <LicenseUrl>http://code.msdn.microsoft.com/WindowsAPICodePack/Project/License.aspx</LicenseUrl> <RequireLicenseAcceptance>true</RequireLicenseAcceptance> <Description>WindowsAPICodePack Wrapper is a .NET wrapper to help with using the unmanaged WindowsAPICodePack library.
The Windows® API Code Pack for Microsoft®.NET Framework provides a source code library that can be used to access some features of Windows 7 and Windows Vista from managed code. These Windows features are not available to developers today in the .NET Framework. This package includes the XML Documentation so you can explore the API while you code using IntelliSense.
This is a repackage of the third party Windows API Code Pack project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly, it will be a dependency of other Map Suite packages.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#windowsapicodepack
Source Website: https://msdn.microsoft.com/en-us/library/ff356173(v=vs.100).aspx</Description>
<Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WindowsAPICodePack WPF</Tags>
</PackageInfo>
<PackageInfo>
<Id>MapSuiteDesktopForWinForms-BareBone</Id> <Title>Map Suite Desktop for WinForms - BareBone</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo/HowDoISample-ForWinForms</ProjectUrl> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WinForms Windows Forms Desktop Control</Tags> <Description>This package allows you to add maps and perform GIS spatial operations within your Winforms application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
This is the barebone version of the Map Suite Desktop for Winforms and is intended for experienced Map Suite developers who require fine grain control over their dependencies. All other developer please use the Standard Edition found at the link below.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_desktop_for_winforms#barebone
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_desktop_for_winforms
Other ThinkGeo Products:
- Map Suite UI Components -
Map Suite Desktop Map Suite Mobile Map Suite Web
- Map Suite Servers and Services -
Map Suite World Streets Map Suite World Imagery Map Suite Routing Map Suite Geocoder Map Suite Reverse Geocoder Map Suite Elevation</Description>
</PackageInfo>
<PackageInfo>
<Id>MapSuiteDesktopForWinForms-Standard</Id> <Title>Map Suite Desktop for WinForms - Standard</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo/HowDoISample-ForWinForms</ProjectUrl> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WinForms Windows Forms Desktop Control</Tags> <Description>This package allows you to add maps and perform GIS spatial operations within your Winforms application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_desktop_for_winforms#standard
</PackageInfo>
<PackageInfo>
<Id>MapSuiteDesktopForWpf-BareBone</Id> <Title>Map Suite Desktop for Wpf - BareBone</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo/HowDoISample-ForWpf</ProjectUrl> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WPF Windows Presentation Foundation Desktop Control</Tags> <Description>This package allows you to add maps and perform GIS spatial operations within your WPF application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
This is the barebone version of the Map Suite Desktop For WPF and is intended for experienced Map Suite developers who require fine grain control over their dependencies. All other developer please use the Standard Edition found at the link below.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_desktop_for_wpf#standard
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_desktop_for_wpf
</PackageInfo>
<PackageInfo>
<Id>MapSuiteDesktopForWpf-Standard</Id> <Title>Map Suite Desktop for Wpf - Standard</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo/HowDoISample-ForWpf</ProjectUrl> <Description>This package allows you to add maps and perform GIS spatial operations within your WPF application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
Map Suite World Streets Map Suite World Imagery Map Suite Routing Map Suite Geocoder Map Suite Reverse Geocoder Map Suite Elevation</Description> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WPF Windows Presentation Foundation Desktop Control</Tags>
</PackageInfo>
<PackageInfo>
<Id>MapSuiteMobileForAndroid-BareBone</Id> <Title>Map Suite Mobile for Android - BareBone</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo/HowDoISample-ForAndroid</ProjectUrl> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Android Xamarin C# Control Mobile</Tags> <Description>This package allows you to add maps and perform GIS spatial operations within your Android application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
This is the barebone version of the Map Suite Mobile Edition and is intended for experienced Map Suite developers who require fine grain control over their dependencies. All other developer please use the Standard Edition found at the link below.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_android#barebone
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_android
Supported Platforms: Android
</PackageInfo>
<PackageInfo>
<Id>MapSuiteMobileForAndroid-Standard</Id> <Title>Map Suite Mobile for Android - Standard</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo/HowDoISample-ForAndroid</ProjectUrl> <Description>This package allows you to add maps and perform GIS spatial operations within your Android application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_android#standard
Map Suite World Streets Map Suite World Imagery Map Suite Routing Map Suite Geocoder Map Suite Reverse Geocoder Map Suite Elevation</Description> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Android Xamarin C# Control Mobile</Tags>
</PackageInfo>
<PackageInfo>
<Id>MapSuiteMobileForiOS-BareBone</Id> <Title>Map Suite Mobile for iOS - BareBone</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo/HowDoISample-ForiOS</ProjectUrl> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET iOS Xamarin C# Control Mobile iPhone iPad</Tags> <Description>This package allows you to add maps and perform GIS spatial operations within your iOS application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_ios#barebone
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_ios
Supported Platforms: iOS
</PackageInfo>
<PackageInfo>
<Id>MapSuiteMobileForiOS-Standard</Id> <Title>Map Suite Mobile for iOS - Standard</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo/HowDoISample-ForiOS</ProjectUrl> <Description>This package allows you to add maps and perform GIS spatial operations within your iOS application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_ios#standard
Map Suite World Streets Map Suite World Imagery Map Suite Routing Map Suite Geocoder Map Suite Reverse Geocoder Map Suite Elevation</Description> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET iOS Xamarin C# Control Mobile iPhone iPad</Tags>
</PackageInfo>
<PackageInfo>
<Id>MapSuiteWebForMvc-BareBone</Id> <Title>Map Suite Web for Mvc - BareBone</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo/HowDoISample-ForMvc</ProjectUrl> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Mvc ASP.NET Web Control</Tags> <Description>This package allows you to add maps and perform GIS spatial operations within your MVC application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
This is the barebone version of the Map Suite Web Edition and is intended for experienced Map Suite developers who require fine grain control over their dependencies. All other developer please use the Standard Edition found at the link below.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_mvc#barebone
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_mvc
</PackageInfo>
<PackageInfo>
<Id>MapSuiteWebForMvc-Standard</Id> <Title>Map Suite Web for Mvc - Standard</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo/HowDoISample-ForMvc</ProjectUrl> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Mvc ASP.NET Web Control</Tags> <Description>This package allows you to add maps and perform GIS spatial operations within your MVC application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_mvc#standard
</PackageInfo>
<PackageInfo>
<Id>MapSuiteWebForWebApi-BareBone</Id> <Title>Map Suite Web for WebApi - BareBone</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo?q=webapi</ProjectUrl> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WebApi HTML5 JavaScript RESTful Webservice</Tags> <Description>This package allows you to add maps and perform GIS spatial operations within your WebAPI application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_webapi#barebone
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_webapi
</PackageInfo>
<PackageInfo>
<Id>MapSuiteWebForWebApi-Standard</Id> <Title>Map Suite Web for WebApi - Standard</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo?q=webapi</ProjectUrl> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WebApi HTML5 JavaScript RESTful Webservice</Tags> <Description>This package allows you to add maps and perform GIS spatial operations within your WebAPI application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_webapi#standard
</PackageInfo>
<PackageInfo>
<Id>MapSuiteWebForWebForms-BareBone</Id> <Title>Map Suite Web for WebForms - BareBone</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo/HowDoISample-ForWebForms</ProjectUrl> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WebForms ASP.NET Web Control</Tags> <Description>This package allows you to add maps and perform GIS spatial operations within your WebForms application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_webforms#barebone
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_webforms
</PackageInfo>
<PackageInfo>
<Id>MapSuiteWebForWebForms-Standard</Id> <Title>Map Suite Web for WebForms - Standard</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo/HowDoISample-ForWebForms</ProjectUrl> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WebForms ASP.NET Web Control</Tags> <Description>This package allows you to add maps and perform GIS spatial operations within your WebForms application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_webforms#standard
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Cogo</Id> <Title>ThinkGeo MapSuite Cogo</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Cogo Coordinate Geometry</Tags> <Description>ThinkGeo.MapSuite.Cogo is an extension is an extension to the Map Suite product line, see below for compatibility. This extension provides the ability to use coordinate geometry.
COGO refers to a data conversion process in which a digital map is constructed from written descriptions, such as legal descriptions of land parcel boundaries. Map Suite supports straight line calls like direction distance or x/y, as well as advance calls like tangent/non-tangent curve. Multi direction type are supported such as NorthAzimuth, Polar, SouthAzimuth and QuadrantBearing.
This is an extension for use in ThinkGeo's Map Suite product line, see below, as it cannot be used stand alone.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_api
Supported Platforms: Windows, Linux, macOS, iOS, Android
- Compatible Products -
Map Suite Desktop for WPF Map Suite Desktop for WinForms Map Suite Mobile for Android Map Suite Mobile for iOS Map Suite Web for WebForms Map Suite Web for MVC Map Suite Web for WebAPI</Description>
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Drawing.PdfGeoCanvas</Id> <Title>ThinkGeo MapSuite Drawing PdfGeoCanvas</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Drawing.PdfGeoCanvas is a extension for Map Suite Drawing. PdfGeoCanvas represents a canvas that is used to draw geographic shapes on a PDF document. It allows you to use PDF drawing to render your features. The basic flow of use for the class is to first call BeginDrawing and pass in an image along with its world extent.
Map Suite Desktop for WPF Map Suite Desktop for WinForms Map Suite Web for WebForms Map Suite Web for MVC Map Suite Web for WebAPI</Description> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET PdfGeoCanvas PDF</Tags>
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Drawing.WicBitmapGeoCanvas</Id> <Title>ThinkGeo MapSuite Drawing WicBitmapGeoCanvas</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Drawing.WicBitmapGeoCanvas is an extension for Map Suite Drawing. The Windows Imaging Component (WIC) is an extensible platform that provides low-level API for digital images. WIC supports the standard web image formats, high dynamic range images, and raw camera data.
Map Suite Desktop for WPF</Description> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WicBitmapGeoCanvas WIC</Tags>
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Geocoding</Id> <Summary /> <ReleaseNote /> <Title>ThinkGeo MapSuite Geocoding</Title> <ProjectUrl>https://github.com/ThinkGeo/GeocodingSample-ForWinForms</ProjectUrl> <Description>ThinkGeo MapSuite Geocodeing is a native Geocoder and reverse Geocoder component for .NET that lets you convert a street address into a geographic location and vice-versa. It can also deliver additional details like county, FIPS codes, census tract and more. Plus, it ships with an optimized set of United States street data based on TIGER® 2012 data from the U.S. Census Bureau.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_geocoding_api
Map Suite Desktop for WPF Map Suite Desktop for WinForms Map Suite Web for WebForms Map Suite Web for MVC Map Suite Web for WebAPI</Description> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Geocoder Reverse Geocoder</Tags>
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Jeffersonian</Id> <Title>ThinkGeo MapSuite Jeffersonian</Title> <Summary /> <ReleaseNote /> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Jeffersonian MetesAndBounds Section Township Range</Tags> <Description>ThinkGeo.MapSuite.Jeffersonian is a extension to the Map Suite product line, see below for compatibility. The Jeffersonian tool allows you to subdivide township ranges, sections, quarter-sections and lots as well as loading maps from surveys.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Adornments</Id> <Title>ThinkGeo MapSuite Adornment Layers</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Adornments Legends Titles North Arrows Logos Scale Line Bar Compass</Tags> <ProjectUrl>https://github.com/ThinkGeo/AdornmentsSample-ForWebApi</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.AdornmentLayers is a layer extension to the Map Suite product line, see below for compatibility. It is used to place adornments on the map.
Here is the link to our samples page that includes a sample for adornments: http://samples.thinkgeo.com/MvcEdition/HowDoISamples
This package integrates following adornment layers:
1. LegendAdornment, 2. LogoAdornment, 3. MagneticDeclinationAdornment, 4. ScaleBarAdornment, 5. ScaleLineAdornment, 6. ScaleTextAdornment
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Background</Id> <Title>ThinkGeo MapSuite Background Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Background</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Background is a layer extension to the Map Suite product line, see below for compatibility. This layer draws the background of the map.
Here is the link to our samples page that includes a sample for changing backgrounds: http://samples.thinkgeo.com/MvcEdition/HowDoISamples
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.BingMaps</Id> <Title>ThinkGeo MapSuite BingMaps Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET BingMaps</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.BingMaps is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to create a layer using data obtained from the Bing Maps Imagery API. A license from Bing is required to use the Bing Map Layer in Map Suite. For more detail on obtaining the license, please visit https://www.microsoft.com/maps/licensing/licensing.aspx.
Here is the link to our samples page that includes a sample for Bing Maps: http://samples.thinkgeo.com/MvcEdition/HowDoISamples
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.BoundarySolutionsParcel</Id> <Title>ThinkGeo MapSuite BoundarySolutionsParcel Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET BoundarySolutionsParcel Parcel</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.BoundarySolutionsParcel is a layer extension is an extension to the Map Suite product line, see below for compatibility. Boundary Solutions Inc. has assembled the National ParcelMap Data Portal, or NPDP, the most current normalized digital parcel map databases from jurisdictions throughout the nation. This layer draws the parcel feature layer of the map.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Cad</Id> <Title>ThinkGeo MapSuite Cad Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET CAD DWG DXF</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Cad is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to render CAD formats as a data source.
Computer-aided design (CAD) is the use of computer systems to aid in the creation, modification, analysis, or optimization of a design. CAD software for mechanical design uses either vector-based graphics to depict the objects of traditional drafting, or may also produce raster graphics showing the overall appearance of designed objects. CAD may be used to design curves and figures in two-dimensional space; or curves, surfaces, and solids in three-dimensional space.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.CloudFile</Id> <Title>ThinkGeo MapSuite CloudFile Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET CloudFile</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.CloudFile is a layer extension to the Map Suite product line, see below for compatibility. This extension provides ability to load an online data source and render on maps.
A cloud file is a predefined data structure and style that is stored on Amazon’s S3 service.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Delimited</Id> <Title>ThinkGeo MapSuite Delimited Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Delimited CSV Tab Pipe Comma Seperated</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Delimited is a layer extension to the Map Suite product line, see below for compatibility. This extension provides ability to load delimited data files and render on maps.
A delimited text file is a text file used to store data, in which each line represents a single book, company, or other thing, and each line has fields separated by the delimiter.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Ecw</Id> <Title>ThinkGeo MapSuite Ecw Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET ECW Raster Enhanced Compression Wavelet Image File Format</Tags> <ProjectUrl>https://github.com/ThinkGeo/EcwSample-ForWinForms</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Ecw is a layer extension is an extension to the Map Suite product line, see below for compatibility. The EcwRasterLayer represents an ECW file for drawing on the map. Simply provide the path and filename of the ECW file, add the layer to one of the Map Suite UI products, and start drawing. You can also draw the layer manually.
ECW is a wavelet image compression system developed by ER Mapper. It allows you to combine and compress large sets of satellite images into a single file. The images can be accessed very quickly at a variety of scales.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.FdoRaster</Id> <Title>ThinkGeo MapSuite Fdo Raster Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET FdoRasterSource FDO</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.FdoRasterSource is a layer extension to the Map Suite product line, see below for compatibility. This layer allows mapsuite to utilize FDO data sources.
From the FDO website: “FDO Data Access Technology is an API for manipulating, defining and analyzing geospatial information regardless of where it is stored. FDO uses a provider-based model for supporting a variety of geospatial data sources, where each provider typically supports a particular data format or data store.” This is an extension for use in ThinkGeo's Map Suite product line, see below, as it cannot be used stand alone.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.FdoVector</Id> <Title>ThinkGeo MapSuite Fdo Feature Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET FdoFeatureSource Image Format Data</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.FdoFeatureSource is a layer extension to the Map Suite product line, see below for compatibility. This layer allows mapsuite to utilize FDO data sources.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.FileGeoDatabase</Id> <Title>ThinkGeo MapSuite FileGeoDatabase Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET FileGeoDatabase GeoDatabase</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.FileGeoDatabase is a layer extension to the Map Suite product line, see below for compatibility. It provides ability to load the GeoDatabase file format and render on maps.
A file geodatabase is a collection of files in a folder on disk that can store, query, and manage both spatial and nonspatial data.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Gdal</Id> <Title>ThinkGeo MapSuite Gdal Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET FdoGdal File Format Data GDAL</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Gdal is a layer extension to the Map Suite product line, see below for compatibility. This extension provides ability to load the GDAL data format and render on maps.
The Geospatial Data Abstraction Library (GDAL) is a computer software library for reading and writing raster and vector geospatial data formats, and is released under the permissive X/MIT style free software license by the Open Source Geospatial Foundation. As a library, it presents a single abstract data model to the calling application for all supported formats.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.GeoTiff</Id> <Title>ThinkGeo MapSuite GeoTiff Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET GeoTiff</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.GeoTiff is a layer extension to the Map Suite product line, see below for compatibility. The TiffRasterLayer represents a TIFF file for drawing on the map. Simply provide the path and filename for the TIFF file, add the layer to one of the Map Suite UI products, and start drawing. You can also draw the layer manually.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.GoogleMaps</Id> <Title>ThinkGeo MapSuite GoogleMaps Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET GoogleMaps</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.GoogleMaps is a layer extension to the Map Suite product line, see below for compatibility. This layer represents an object that encapsulates a Google Map layer. It uses Google Static Maps API to implement url requests. A license is required for use from Google Maps.
Here is the link to our samples page that includes a sample for Google Maps: http://samples.thinkgeo.com/MvcEdition/HowDoISamples
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Gpx</Id> <Title>ThinkGeo MapSuite Gpx Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Gpx GPS</Tags> <ProjectUrl>https://github.com/ThinkGeo/GPSExchangeFormatFeatureLayerSample-ForWpf</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Gpx is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render a GPX data format on maps.
GPX, or GPS Exchange Format, is an XML schema designed as a common GPS data format for software applications. It can be used to describe waypoints, tracks, and routes.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Graticule</Id> <Title>ThinkGeo MapSuite Graticule Layers</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Graticule Longitude Lines Latitude</Tags> <ProjectUrl>https://github.com/ThinkGeo/GraticuleWithGoogleProjectionSample-ForWpf</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Graticule is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load graticules and render on maps.
A Graticule feature layer shows meridians and parallels displaying through the map. Meridians are lines of longitude and they have a north-south orientation. Parallels are lines of latitude and they have an east-west orientation. Showing graticule for latitude and longitude is a standard way in cartography to give spatial references to the users.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Grids</Id> <Title>ThinkGeo MapSuite Grids Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Grids</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Grids is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load grids and render on maps.
The layer displays cells with different colors in a rectangular area of a map. The color of a cell depends on the cell value in the grid file. The grid file provides information about the grid such as row and column numbers, coordinates of the lower left corner, cell size, and values of cells.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Group</Id> <Title>ThinkGeo MapSuite Group Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Group</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Group is a layer extension to the Map Suite product line, see below for compatibility. It is a special layer has the ability to contain a set of other layers.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Heat</Id> <Title>ThinkGeo MapSuite Heat Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Heat Sales Map</Tags> <ProjectUrl>https://github.com/ThinkGeo/HeatMapSample-ForWinForms</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Heat is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load a point dataset and generate a heat visualization based on the density of points in a region.
A heat layer allows you to better visualize data by making areas of high concentration “hotter” using warmer colors and low density areas visually cooler.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.IsoLine</Id> <Title>ThinkGeo MapSuite IsoLine Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET IsoLine Contour Lines Elevation</Tags> <ProjectUrl>https://github.com/ThinkGeo/DisplayIsoLinesSample-ForWpf</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.IsoLine is a layer extension to the Map Suite product line, see below for compatibility. This extension provides ability to load point data with elevation value and render the data as an ISO line map.
An isoline is a line connecting points of equal value on a map.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Jpeg2000</Id> <Title>ThinkGeo MapSuite Jpeg2000 Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Jpeg2000 Raster Aerial JP2</Tags> <ProjectUrl>https://github.com/ThinkGeo/Jpeg2000Sample-ForWinForms</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Jpeg2000 is a layer extension to the Map Suite product line, see below for compatibility. This layer allows you to access pictures from an JPEG2000 file. This class is typically used in the JPEG2000RasterLayer to allow JPEG2000 raster images to be shown on your map.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Kml</Id> <Title>ThinkGeo MapSuite Kml Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Kml Google Earth Kmz</Tags> <ProjectUrl>https://github.com/ThinkGeo/KmlSample-ForWinForms</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Kml is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render KML data formats on maps.
Keyhole Markup Language (KML) is an XML notation for expressing geographic annotation and visualization within Internet-based, two-dimensional maps and three-dimensional Earth browsers.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.MapShape</Id> <Title>ThinkGeo MapSuite MapShape Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET MapShape</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.MapShape is a layer extension to the Map Suite product line, see below for compatibility. This layer represents a mapshape layer drawn on map. Each MapShape composes of a feature and a ZoomLevelSet to control its drawing zoomlevels. This extension provides the ability to load map shapes into a layer and render on maps.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.MrSid</Id> <Title>ThinkGeo MapSuite MrSid Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET MrSid Raster</Tags> <ProjectUrl>https://github.com/ThinkGeo/MrSidSample-ForWinForms</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.MrSid is a layer extension to the Map Suite product line, see below for compatibility. The MrSidRasterLayer represents a MrSid file for drawing on the map. This extension provides the ability to load a MrSid file and render on maps. MrSid is a image compression system developed by LizardTech. It allows you to combine and compress large sets of satellite images into a single file. The images can be accessed very quickly at a variety of scales.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.MsSql</Id> <Title>ThinkGeo MapSuite MsSql Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET MsSql Microsoft Database</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.MsSql is a layer extension to the Map Suite product line, see below for compatibility. This layer represents a FeatureSource backed by MS SQL.
This layer takes advantage of the Microsoft SQL server spatial extension as of SQL server 2008 allowing you to store data natively as geometries.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.MultipleFeatureSource</Id> <Title>ThinkGeo MapSuite MultipleFeature Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET MultipleFeatureSource Multiple</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.MultipleFeature is a layer extension is an extension to the Map Suite product line, see below for compatibility. This layer is a special layer that can contain multiple other layers.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.NativeImage</Id> <Title>ThinkGeo MapSuite NativeImage Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET NativeImage Native</Tags> <ProjectUrl>https://github.com/ThinkGeo/StreamLoadingForNativeImageSample-ForWinForms</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.NativeImage is a layer extension to the Map Suite product line, see below for compatibility. This type of layer is used to draw standard image types on the map. These include .BMP, .JPG, .PNG, .TIFF, and all other image types that are supported by the .NET Framework to be loaded as a Bitmap. Each of these images will need a world file associated with it. The world file contains the geospatial information pertaining to the image. Using the world file, we know its spatial position and other required information to draw it on the map relative to other images or spatial features. World files are small text files with an extension that matches the original image's extension, but with the middle character of the extension changed to a "w". If you have images that you want to use but do not have their world files, please contact the source of the image so that they can provide one for you. world files are fairly common in the GIS community.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.NauticalCharts</Id> <Title>ThinkGeo MapSuite NauticalCharts Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET NauticalCharts S52 S57 Maritime Marine</Tags> <ProjectUrl>https://github.com/ThinkGeo/NauticalChartsViewerSample-ForWpf</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.NauticalCharts is a layer extension to the Map Suite product line, see below for compatibility. This extension represents a layer backed by a IHO ENC 000 File.
The new ThinkGeo Nautical Charts Extension is a great tool for any .NET developer who needs to create or view desktop or web maps that display NOAA’s Electronic Navigational Charts which conform to the International Hydrograph Office (IHO) S-57 international exchange format as defined in the special publication S-52.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Noaa</Id> <Title>ThinkGeo MapSuite Noaa Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Noaa Weather</Tags> <ProjectUrl>https://github.com/ThinkGeo/NOAAGlobelWeatherStationLayerSample-ForWpf</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Noaa is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render NOAA weather station, warning and radar maps.
For the US NOAA also provides real time weather watches, warnings and advisory polygons as a feature layers which you can use as an overlay. Additionally for the US, NOAA also provides weather radar images. All this data is refreshed approximately every 5-15 minutes in the background. With all these APIs you have full control over transparency so you can easily see the affected areas beneath the radar images, weather watches and warnings polygons.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Ogr</Id> <Title>ThinkGeo MapSuite Ogr Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET FdoOgr FDO OGR</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Ogr is a layer extension to the Map Suite product line, see below for compatibility. It provides ability to load and render OGR data format on map.
The Geospatial Data Abstraction Library (GDAL) is a computer software library for reading and writing raster and vector geospatial data formats. As a library, it presents a single abstract data model to the calling application for all supported formats. It may also be built with a variety of useful command line interface utilities for data translation and processing. The related OGR library (OGR Simple Features Library), which is part of the GDAL source tree, provides a similar ability for simple features vector graphics data.
The related OGR library (OGR Simple Features Library[2]), which is part of the GDAL source tree, provides a similar ability for simple features vector graphics data.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.OpenStreetMap</Id> <Title>ThinkGeo MapSuite OpenStreetMap Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET OpenStreetMap OSM</Tags> <ProjectUrl>https://github.com/ThinkGeo/OpenStreetMapSample-ForWinForms</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.OpenStreetMap is a layer extension is an extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render Open Street Map online resources on maps.
OpenStreetMap (OSM) is a collaborative project to create a free editable map of the world. Rather than the map itself, the data generated by the OpenStreetMap project are considered its primary output.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Oracle</Id> <Title>ThinkGeo MapSuite Oracle Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Oracle Database</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Oracle is a layer extension to the Map Suite product line, see below for compatibility. This layer represents a Layer backed by Oracle Spatial.
Oracle Spatial and Graph includes high performance, enterprise-scale, commercial spatial and graph database and analytics for Oracle Database 12c. It supports enterprise business and business intelligence, large-scale Geographic Information Systems, and location-based services applications on premises and in the Cloud.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.PersonalGeoDatabase</Id> <Title>ThinkGeo MapSuite PersonalGeoDatabase Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET FdoPersonalGeoDatabase GeoDatabase FDO</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.PersonalGeoDatabase is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render a Personal GeoDatabase data format on maps.
A personal geodatabase is a Microsoft Access database that can store, query, and manage both spatial and nonspatial data.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.PostgreSql</Id> <Title>ThinkGeo MapSuite PostgreSql Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET PostgreSql Database</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.PostgreSql is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load a PostgreSql feature layer and render on maps.
PostgreSQL, often simply Postgres, is an object-relational database, with additional “object” features – with an emphasis on extensibility and standards compliance. As a database server, its primary function is to store data securely, and to allow for retrieval at the request of other software applications. It can handle workloads ranging from small single-machine applications to large Internet-facing applications (or for data warehousing) with many concurrent users; on macOS Server, PostgreSQL is the default database; and it is also available for Microsoft Windows and Linux (supplied in most distributions).
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Printers</Id> <Title>ThinkGeo MapSuite Printer Layers</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Printers Print Dpi</Tags> <ProjectUrl>https://github.com/ThinkGeo/PrintPreviewSample-ForWpf</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.PrinterLayers is a layer extension to the Map Suite product line, see below for compatibility. This is used to design page layouts for maps. You can use this layer to layout the physical page to be printed. This package integrates the following printer layers:
1. DataGridPrinter, 2. ImagePrinter, 3. LabelPrinter, 4. LegendPrinter, 5. MagneticDeclinationPrinter, 6. MapPrinter, 7. PagePrinter, 8. ScaleBarPrinter, 9. ScaleLinePrinter, 10. ScaleTextPrinter
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Restriction</Id> <Title>ThinkGeo MapSuite Restriction Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Restriction</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Restriction is a layer extension to the Map Suite product line, see below for compatibility. This layer can show or hide one or many zones that you want to restrict from being displayed. You can use the specified style to decorate the zones and set the lower/upper scale to control at which zoom levels you want to show or hide the zones. The default decoration style is a hatch pattern. You can change this to a circle with slash image, or, if you want a different look, you can use custom styles.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Sdf</Id> <Title>ThinkGeo MapSuite SDF Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET FdoSdf FDO SDF</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Sdf is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render the SDF data format on maps.
Simple Data Format or SDF is a platform-independent, precision-preserving binary data I/O format capable of handling large, multi-dimensional arrays.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.ShapeFile</Id> <Title>ThinkGeo MapSuite ShapeFile Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET ShapeFile SHP SHX DBF</Tags> <ProjectUrl>https://github.com/ThinkGeo/QuickstartSample-ForWebForms</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.ShapeFile is a layer extension to the Map Suite product line, see below for compatibility. This layer represents a FeatureSource backed by a ESRI Shape File.
The shapefile format is a popular geospatial vector data format for geographic information system (GIS) software. It is developed and regulated by ESRI as a (mostly) open specification for data interoperability among ESRI and other GIS software products. The shapefile format can spatially describe vector features: points, lines, and polygons, representing, for example, water wells, rivers, and lakes. Each item usually has attributes that describe it, such as name or temperature.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Sqlite</Id> <Title>ThinkGeo MapSuite SQLite Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET SQLite Database</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Sqlite is a layer extension to the Map Suite product line, see below for compatibility. This layer represents a FeatureSource backed by SQLite.
This extension utilizes SQL R*Tree module which allows it to natively query geometries at super fast speeds. An R-Tree is a special index that is designed for doing range queries.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.SqliteForMono</Id> <Title>ThinkGeo MapSuite SQLite Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET SQLite Database</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Sqlite is a layer extension to the Map Suite product line, see below for compatibility. This layer represents a FeatureSource backed by SQLite.
Supported Platforms: Linux, iOS, Android
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Tab</Id> <Title>ThinkGeo MapSuite TAB Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Tab MapInfo</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Tab is a layer extension is an extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render the .TAB data format on maps.
Tab files(.TAB) are popular geospatial data format. Each Tab file has an associated file that stores all the attribute data in it, most commonly a .DAT file.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.TiledWms</Id> <Title>ThinkGeo MapSuite TiledWms Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET TiledWms WMS</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.TiledWms is a layer extension to the Map Suite product line, see below for compatibility.
This layer is use for a tiled WMS Server. You also can get maps from ThinkGeo world map kit server. A Web Map Service (WMS) is a standard protocol for serving (over the Internet) georeferenced map images which a map server generates using data from a GIS database
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.TinyGeo</Id> <Title>ThinkGeo MapSuite TinyGeo Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET TinyGeo Tgeo</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.TinyGeo is a layer extension to the Map Suite product line, see below for compatibility. This layer represents a FeatureLayer created from a TinyGeo File by ThinkGeo.
What is TinyGeo? The goal of the format is to provide our customers with a highly compressed, read-only, secure and easily distributable data file that they can use to disseminate spatial data to their clients.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.TobinBas</Id> <Title>ThinkGeo MapSuite TobinBas Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET TobinBas</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.TobinBas is a layer extension is an extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render the Tobin.Bas data format on maps.
The TOBIN TDRBM II Data Distribution format, commonly called TDRBM II, provides an enhanced graphical representation of TOBIN Survey information.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Wfs</Id> <Title>ThinkGeo MapSuite WFS Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WFS Web Feature Source</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Wfs is a layer extension is an extension to the Map Suite product line, see below for compatibility. This layer represents the WFS (web feature service) feature layer.
In computing, the Open Geospatial Consortium Web Feature Service Interface Standard (WFS) provides an interface allowing requests for geographical features across the web using platform-independent calls.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.WkbFile</Id> <Title>ThinkGeo MapSuite WkbFile Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WkbFile WellKnownBinary WKB</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.WkbFile is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render the WKB data format on maps.
WKB stands for Well-Known Binary, a format for representing geographical and geometrical data.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Wms</Id> <Title>ThinkGeo MapSuite Wms Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WMS Web Map Service</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Wms is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load the WMS format and render on maps.
A Web Map Service (WMS) produces maps of spatially referenced data dynamically from geographic information. This International Standard defines a “map” to be a portrayal of geographic information as a digital image file suitable for display on a computer screen. A map is not the data itself. WMS-produced maps are generally rendered in a pictorial format such as PNG, GIF or JPEG, or occasionally as vector-based graphical elements in Scalable Vector Graphics (SVG) or Web Computer Graphics Metafile (WebCGM) formats.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.Wmts</Id> <Title>ThinkGeo MapSuite Wmts Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Wmts OpenGIS Web Map Tile Service</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.Wmts is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load a WMTS file format and render on maps.
A Web Map Tile Service (WMTS) is a standard protocol for serving pre-rendered georeferenced map tiles over the Internet.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.WorldMapKit</Id> <Title>ThinkGeo MapSuite WorldMapKit Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WorldMapKit Basemaps Vector Aerial Offline Street Hybrid SQLite</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.WorldMapKit is a layer extension to the Map Suite product line, see below for compatibility. This layer is used for world map kit data that can be retrieved from the ThinkGeo world map kit server.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Layers.WorldStreetsAndImagery</Id> <Title>ThinkGeo MapSuite WorldStreetsAndImagery Layer</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WorldMapKit WorldStreets Basemaps Vector Aerial Offline Street Hybrid SQLite</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Layers.WorldStreetsAndImagery is a layer extension to the Map Suite product line, see below for compatibility. This layer is used for the world streets data format that can be retrieved from the ThinkGeo world streets server.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.ProductCenter</Id> <Title>ThinkGeo MapSuite ProductCenter</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET ProductCenter</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo MapSuite Product Center is the ThinkGeo Map Suite SDK for .NET - Core Runtime. It provides download license, sample, daliy build etc. low level functions for building GIS applications. It is the basic product dependency package across all of the MapSuite 10.0 product line and above.
This is a package for ThinkGeo's Map Suite product, see below, as it cannot be used stand alone.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Routing</Id> <Title>ThinkGeo MapSuite Routing</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Routing Driving Directions Route Turn-by-Turn Traveling Salesman</Tags> <ProjectUrl>https://github.com/ThinkGeo/RoutingSample-ForWinForms</ProjectUrl> <Description>ThinkGeo.MapSuite.Routing is an extension to the Map Suite product line, see below for compatibility. ThinkGeo.MapSuite.Routing gives your Map Suite applications the power to find the shortest path from A to B, deliver turn-by-turn directions, avoid specified areas, optimize for the Traveling Salesperson Problem and much more.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_routing_api
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Shapes.UnmanagedProj4Projection</Id> <Title>ThinkGeo MapSuite Shapes UnmanagedProj4Projection</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET UnmanagedProj4Projection Projections Proj4</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Shapes.UnmanagedProj4Projection is an extension for Map Suite products to re-project vector and raster data format with a specific proj4 projection string.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Styles.ClassBreak</Id> <Title>ThinkGeo MapSuite Styles ClassBreak</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET ClassBreak Thematic</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Styles.ClassBreak is a style extension to the Map Suite product line, see below for compatibility. The ClassBreakStyle allows you to change the way features are drawn based on their data values. It is often useful for you to display features differently based on ranges of numeric values. For example, you may have a ShapeFile comprised of states that has the populations of each state as part of its data. You may then want to color states differently based on their population. This ClassBreakStyle allows you to do this.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Styles.ClusterPoint</Id> <Title>ThinkGeo MapSuite ClusterPoint Style</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET ClusterPoint Styles Clustering Cluster</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Styles.ClusterPoint is a style extension to the Map Suite product line, see below for compatibility. It provides ability to cluster nearest markers to one marker with a specific style.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Styles.Composite</Id> <Title>ThinkGeo MapSuite Composite Style</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Composite Styles</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Styles.Composite is a style extension to the Map Suite product line, see below for compatibility. It is a special style that allows to a style to contain various other styles.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Styles.DotDensity</Id> <Title>ThinkGeo MapSuite DotDensity Style</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET DotDensity Styles Population Dot Density</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Styles.DotDensity is a style extension to the Map Suite product line, see below for compatibility. This style allows you to display information by drawing points on an area based on a value from the features’ data. The higher the value is in the data, the greater the number of points that are drawn. The points themselves are distributed randomly inside of the polygon.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Styles.Filter</Id> <Title>ThinkGeo MapSuite Filter Style</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Filter Styles</Tags> <ProjectUrl>https://github.com/ThinkGeo/FilterStyleSample-ForWpf</ProjectUrl> <Description>ThinkGeo.MapSuite.Styles.Filter is a style extension to the Map Suite product line, see below for compatibility. It provides the ability to display features with a specific filter condition.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Styles.FleeBoolean</Id> <Title>ThinkGeo MapSuite FleeBoolean Style</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET FleeBoolean Logical Operation</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Styles.FleeBoolean is a style extension is an extension to the Map Suite product line, see below for compatibility. This extension provides the ability to evaluate complex expressions to create styles.
FLEE is an acronym for Fast Lightweight Expression Evaluator. It is an expression parser and evaluator for the .NET framework. It allows you to compute the value of string expressions such as sqrt(a^2 + b^2) at runtime.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Styles.Gradient</Id> <Title>ThinkGeo MapSuite Gradient Style</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Gradient</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Styles.Gradient is a style extension to the Map Suite product line, see below for compatibility. This gradient style is a new style with the concept of GradientBrush. By specifying the LowerValue and its color, as well as the UpperValue and its color, we can set the color of each feature based on a column value using linear interpolation.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Styles.Icon</Id> <Title>ThinkGeo MapSuite Icon Style</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Icon Style Custom</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Styles.Icon is a style extension to the Map Suite product line, see below for compatibility. This style displays an icon with text from the data of the feature. You can use the icon style when you have an icon you want to display on the map with characters inside of that icon. For example, if you have a circular icon and you want to label the number 1-100 inside of the icon, you can use this class. You need to specify the column name where the numbers or letters will come from, as well as a font. Through various properties, you can also control the positioning of the icon, just as you would with a TextStyle.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Styles.IconValue</Id> <Title>ThinkGeo MapSuite IconValue Style</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET IconValue Style</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Styles.IconValue is a style extension is an extension to the Map Suite product line, see below for compatibility. This class allows you to choose different icons based on values in the data of a feature. When you create an IconValueStyle, you need to add multiple IconValueItems to its collection. You input the column name in the IconValueStyle and it will compare the data's value to each IconValueItems’ data. If they match, it will then draw the Feature using the properties of the IconValueItem. In this way, you can render different data with different icons or text.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Styles.Regex</Id> <Title>ThinkGeo MapSuite Regex Style</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Regex Style Wildcard Wild Card</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Styles.Regex is a style extension to the Map Suite product line, see below for compatibility. The RegexStyle allows you to use complex regular expression matching to determine how your features are drawn. A regular expression is a matching syntax that allows you to match a string based on very complex criteria. For example, let's say you have a layer that has a column in the data that contains school names. Most school names include the type of school they are. For instance, you may have "Lincoln Middle School" or "Bush High School." There are variations to these names though, containing words such as "Elementary" or "Prep." With a regular expression, you can create matching criteria that will allow you to match on many variations of the names. It is especially useful for fuzzy matches where your data is not clearly categorized. Another classic example is for matching or validating email addresses, where matching rules can become complex. In the RegexStyle, you specify the matching criteria string and also the style you want to use to draw the feature if the criteria matches. It is a simple yet powerful style for dealing with complex rule sets and imprecise data.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Styles.Value</Id> <Title>ThinkGeo MapSuite Value Style</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Value Style</Tags> <ProjectUrl>https://github.com/ThinkGeo/DefaultValueStyleSample-ForWpf</ProjectUrl> <Description>ThinkGeo.MapSuite.Styles.Value is a style extension to the Map Suite product line, see below for compatibility. The ValueStyle allows you to match data in the FeatureSource against a value string. If the value matches, then we will use the style defined in that item to do the drawing. For example, let's say you have some data that contains states, and each state is categorized as either a high, medium or low pollution state. Based on the string values of "High", Medium" and "Low", we can match on these. If a feature's data for the column matched the string "High", then we would use the high ValueItem's styles to draw that feature. This can be applied to all kinds of things such as road classification and more.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Styles.WellPoint</Id> <Title>ThinkGeo MapSuite WellPoint Style</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WellPoint Well</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Styles.WellPoint is a style extension to the Map Suite product line, see below for compatibility. This style uses hundreds of pre-defined well-point styles to display point vector data.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Styles.WorldMapKit</Id> <Title>ThinkGeo MapSuite WorldMapKit Style</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WorldMapKit</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Styles.WorldMapKit is a style extension to the Map Suite product line, see below for compatibility. It is a pre-defined style in MapSuite containing WorldMapKitAreaStyles, WorldMapKitLineStyles, WorldMapKitPointStyles and WorldMapKitTextStyles.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Styles.WorldStreets</Id> <Title>ThinkGeo MapSuite WorldStreets Style</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET WorldStreets</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Styles.WorldStreets is a style extension to the Map Suite product line, see below for compatibility. It is a pre-defined style in MapSuite containing WorldStreetsAreaStyles, WorldStreetsLineStyles, WorldStreetsPointStyles and WorldStreetsTextStyles.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite.Styles.ZedGraph</Id> <Title>ThinkGeo MapSuite ZedGraph Style</Title> <Summary /> <ReleaseNote /> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET ZedGraph Line Bar Pie Special Charts Graph</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite.Styles.ZedGraph is a style extension to the Map Suite product line, see below for compatibility. Zedgraph is a truly massive library for graphics and charts. As you can add pie charts to your map, you can also add bar charts, trend charts etc. with this style.
</PackageInfo>
<PackageInfo>
<Id>ThinkGeo.MapSuite</Id> <Title>ThinkGeo MapSuite</Title> <Summary /> <ReleaseNote /> <LicenseUrl>http://wiki.thinkgeo.com/wiki/map_suite_license_agreement</LicenseUrl> <RequireLicenseAcceptance>true</RequireLicenseAcceptance> <Tags>Spatial GIS ThinkGeo MapSuite Map Suite .NET Map Suite</Tags> <ProjectUrl>https://github.com/ThinkGeo</ProjectUrl> <Description>ThinkGeo.MapSuite is the ThinkGeo Map Suite SDK for .NET - Core Runtime. It provides geometries, data source, layers, styles, rendering, and low level functions for building GIS applications. It is the basic core dependency package across all of the MapSuite 10.0 product line.
</PackageInfo>
