 This is the event arguments class for the AdornmentLayersDrawn event. It is raised after all of the AdornmentLayers have been drawn.
 This class represents a NativeImageTile, which is defined as scale, RectangleBox and a byte array for its tile bitmap.
 This class is a concrete class inherits from BitmapTileCache. In this class, the tiles will be saved in memory and it provides some properties to control it very easily.
 This is the base class for NativeTileCache system which inherits from TileCache class.
 This class represents the parameters passed in through the CreatedMemberNode event.
 This class represents the parameters passed in through the CreatingMemberObject event.
 Indicates how the default value of a member will be dealt with by the modeler.
 When applied to a method, specifies that the method is called after serialization of an object graph.
 When applied to a method, specifies that the method is called before serialization of an object.
