package_descriptions_for_review
1
MapSuiteDependency-EsriFileGeoDatabase
<Id>MapSuiteDependency-EsriFileGeoDatabase</Id>
<Title>Map Suite Dependency - EsriFileGeoDatabase</Title>
<Summary />
<Description> EsriFileGeoDatabase Wrapper is a .NET wrapper to help with using the unmanaged EsriFileGeoDatabase library.
A FileGeodatabase is a folder that holds a collection of files that can be accessed and edited by multiple users provided that they are not editing the same data at the same time. They are useful for very large projects that requires multiple people to work on.
This is a repackage of the third party EsriFileGeoDatabase project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly, it will be a dependency of other Map Suite packages.
The purpose of the repackage is to enable ThinkGeo to control release and debug versions known to be compatible with various Map Suite products and to provide ongoing backward compatibility independent from the original author. You can find more information at the link below.
Why we repackage: http://wiki.thinkgeo.com/wiki/repackaged_nuget_packages
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#esrifilegeodatabase
Supported Platforms: Window
Source Website: http://www.gdal.org/drv_filegdb.html
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET FileGeoDatabase ESRI GeoDatabase</Tags>
</PackageInfo> (Reviewed by Brad) 2
MapSuiteDependency-Fdo
<Id>MapSuiteDependency-Fdo</Id>
<Title>Map Suite Dependency - Fdo</Title>
<Summary />
<Description>MapSuite FDO Extension Wrapper is a .NET wrapper to assist in using the unmanaged MapSuite FDO Extension library.
From the OSGeo website: “FDO Data Access Technology is an API for manipulating, defining and analyzing geospatial information regardless of where it is stored. FDO uses a provider-based model for supporting a variety of geospatial data sources, where each provider typically supports a particular data format or data store.”
This is a repackage of the third party FDO project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly. It will be a dependency of other Map Suite packages.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#fdo
Supported Platforms: Windows
Source Website: http://fdo.osgeo.org/ml
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET FDO OSGeo Feature Data Objects Vector Raster Formats</Tags>
</PackageInfo> (Reviewed by Brad) 3
MapSuiteDependency-GdalS57
<Id>MapSuiteDependency-GdalS57</Id>
<Title>Map Suite Dependency - GdalS57</Title>
<Summary />
<Description> GdalS57 Wrapper is a .NET wrapper to help with using the unmanaged GdalS57 library.
International Hydrographic Organisation (IHO) S-57 Electronic Navigation Charts (ENC) datasets are supported for read access. The S-57 driver module produces features for all S-57 features in the S-57 file, and associated updates. S-57 (ENC) files normally have the extension “.000”. S-57 feature objects are translated into features. S-57 geometry objects are automatically collected and formed into geometries on the features.
This is a repackage of the third party S57 Gdal project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly, it will be a dependency of other Map Suite packages.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#gdals57
Source Website: http://www.gdal.org/</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET GDAL S-57 ENC Electronic Navigation Charts S57</Tags>
4
MapSuiteDependency-HexagonGeospatialEcw
<Id>MapSuiteDependency-HexagonGeospatialEcw</Id>
<Title>Map Suite Dependency - HexagonGeospatialEcw</Title>
<Summary />
<Description>Erdas Raster Wrapper is .NET wrapper to help with using the unmanaged Erdas Raster library.
ECW (Enhanced Compression Wavelet) is a proprietary wavelet compression image format optimized for aerial and satellite imagery. It was developed by Earth Resource Mapping, and is now owned by Intergraph part of Hexagon AB. The lossy compression format efficiently compresses very large images with fine alternating contrast while retaining their visual quality.
This is a repackage of the third party HexagonGeospatialEcw project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly, it will be a dependency of other Map Suite packages.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#hexagongeospatialecw
Source Website: http://www.hexagongeospatial.com/</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET HexagonGeospatialEcw ECW Hexagon</Tags>
</PackageInfo> (Reviewed by Brad) 5
MapSuiteDependency-LibGeoTiff
<Id>MapSuiteDependency-LibGeoTiff</Id>
<Title>Map Suite Dependency - LibGeoTiff</Title>
<Summary />
<Description> LibGeoTiff is a .NET wrapper to help with using the GeoTiff format.
From the OSGeo website: “GeoTIFF represents an effort by over 160 different remote sensing, GIS, cartographic, and surveying related companies and organizations to establish a TIFF based interchange format for georeferenced raster imagery.”
This is a repackage of the third party LibGeoTiff project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly, it will be a dependency of other Map Suite packages.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#libgeotiff
Source Website: http://libtiff.org/ </Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET LibGeoTiff GeoTiff</Tags>
</PackageInfo>
(Reviewed by Brad) 6
MapSuiteDependency-LizardTechMrSid
<Id>MapSuiteDependency-LizardTechMrSid</Id>
<Title>Map Suite Dependency - LizardTechMrSid</Title>
<Summary />
<Description> LizardTechMrSid Wrapper is a .NET wrapper to help with using the unmanaged MrSid library.
MrSID (pronounced Mister Sid) is an acronym that stands for multiresolution seamless image database. It is a file format developed for encoding of georeferenced raster graphics, such as orthophotos. MrSID Rasters(.sid) contains a large raster image that is highly compressed that allows you to view parts of the image without having to decompress the whole image.
This is a repackage of the third party LizardTechMrSid project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly, it will be a dependency of other Map Suite packages.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#lizardtechmrsid
Source Website https://www.lizardtech.com/ </Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET LizardTech MrSid Multiresolution Seamless Image Database Raster </Tags>
</PackageInfo> (Reviewed by Brad) 7
MapSuiteDependency-Oracle
<Id>MapSuiteDependency-Oracle</Id>
<Title>Map Suite Dependency - Oracle</Title>
<Summary />
<Description>Oracle Wrapper is a .NET wrapper to help with using the unmanaged Oracle library.
This is a repackage of the third party Oracle project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly, it will be a dependency of other Map Suite packages.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#oracle
Source Website: http://www.oracle.com/ </Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Oracle Database </Tags>
</PackageInfo> (Reviewed by Brad) 8
MapSuiteDependency-TeighaCad
<Id>MapSuiteDependency-TeighaCad</Id>
<Title>Map Suite Dependency - TeighaCad</Title>
<Summary /> TeighaCad Wrapper is a .NET wrapper to help with using the unmanaged TeighaCad library.
<Description>For over a decade, Teigha has been the trusted solution for building CAD software recognized by hundreds of companies that require high-quality access to engineering data. With the ability to recover, repair, read and write .dwg files, Teigha enables companies to maintain and develop their intellectual property.
This is a repackage of the third party CAD project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly, it will be a dependency of other Map Suite packages.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#teighacad
Source Website: https://www.opendesign.com/</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET TeighaCad CAD DWG DGN</Tags>
</PackageInfo>
(Reviewed by Brad) 9
MapSuiteDependency-UnmanagedProj4Projection
<Id>MapSuiteDependency-UnmanagedProj4Projection</Id>
<Title>Map Suite Dependency - UnmanagedProj4Projection</Title>
<Summary />
<Description> UnmanagedProj4Projection Wrapper is a .NET wrapper to help with using the unmanaged Proj4Projection library.
Proj.4 is a standard UNIX filter function which converts geographic longitude and latitude coordinates into cartesian coordinates (and vice versa), and it is a C API for software developers to include coordinate transformation in their own software.
This is a repackage of the third party GeoRaster Projection project for use with ThinkGeo's Map Suite product line.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#unmanagedproj4projection
Source Website: https://github.com/OSGeo/proj.4/
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET GdalGeoRasterProjection GDAL</Tags>
</PackageInfo> (Reviewed by Brad) 10
MapSuiteDependency-WindowsAPICodePack
<Id>MapSuiteDependency-WindowsAPICodePack</Id>
<Title>Map Suite Dependency - WindowsAPICodePack</Title>
<Summary />
<Description> WindowsAPICodePack Wrapper is a .NET wrapper to help with using the unmanaged WindowsAPICodePack library.
The Windows® API Code Pack for Microsoft®.NET Framework provides a source code library that can be used to access some features of Windows 7 and Windows Vista from managed code. These Windows features are not available to developers today in the .NET Framework. This package includes the XML Documentation so you can explore the API while you code using IntelliSense.
This is a repackage of the third party Windows API Code Pack project for use with ThinkGeo's Map Suite product line. You should not need to reference this package directly, it will be a dependency of other Map Suite packages.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_dependencies#windowsapicodepack
Source Website: https://msdn.microsoft.com/en-us/library/ff356173(v=vs.100).aspx </Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET WindowsAPICodePack WPF</Tags>
</PackageInfo> (Reviewed by Brad) 11
MapSuiteDesktopForWinForms-BareBone
<Id>MapSuiteDesktopForWinForms-BareBone</Id>
<Title>Map Suite Desktop for WinForms - BareBone</Title>
<Summary />
<Description> This package allows you to add maps and perform GIS spatial operations within your Winforms application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
This is the barebone version of the Map Suite Desktop for Winforms and is intended for experienced Map Suite developers who require fine grain control over their dependencies. All other developer please use the Standard Edition found at the link below.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_desktop_for_winforms#barebone
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_desktop_for_winforms
Supported Platforms: Windows, Linux, MacOS
Other ThinkGeo Products:
- Map Suite UI Components -
  Map Suite Desktop
  Map Suite Mobile
  Map Suite Web
- Map Suite Servers and Services -
  Map Suite World Streets
  Map Suite World Imagery
  Map Suite Routing
  Map Suite Geocoder
  Map Suite Reverse Geocoder
  Map Suite Elevation</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET WinForms Windows Forms Desktop Control</Tags>
</PackageInfo> (Reviewed by Brad) 12
MapSuiteDesktopForWinForms-Standard
<Id>MapSuiteDesktopForWinForms-Standard</Id>
<Title>Map Suite Desktop for WinForms - Standard</Title>
<Summary />
<Description> This package allows you to add maps and perform GIS spatial operations within your Winforms application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action. Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_desktop_for_winforms#standard
  Map Suite Desktop
  Map Suite Mobile
  Map Suite Web
  Map Suite Routing
  Map Suite Geocoder
<ReleaseNote />
</PackageInfo> (Reviewed by Brad) 13
MapSuiteDesktopForWpf-BareBone
<Id>MapSuiteDesktopForWpf-BareBone</Id>
<Title>Map Suite Desktop for Wpf - BareBone</Title>
<Summary />
<Description> This package allows you to add maps and perform GIS spatial operations within your WPF application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
This is the barebone version of the Map Suite Desktop For WPF and is intended for experienced Map Suite developers who require fine grain control over their dependencies. All other developer please use the Standard Edition found at the link below.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_desktop_for_wpf#standard
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_desktop_for_wpf
  Map Suite Desktop
  Map Suite Mobile
  Map Suite Web
  Map Suite Routing
  Map Suite Geocoder
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET WPF Windows Presentation Foundation Desktop Control</Tags>
14
MapSuiteDesktopForWpf-Standard
<Id>MapSuiteDesktopForWpf-Standard</Id>
<Title>Map Suite Desktop for Wpf - Standard</Title>
<Summary />
  Map Suite Desktop
  Map Suite Mobile
  Map Suite Web
  Map Suite Routing
  Map Suite Geocoder
<ReleaseNote />
</PackageInfo> (Reviewed by Brad) 15
MapSuiteMobileForAndroid-BareBone
<Id>MapSuiteMobileForAndroid-BareBone</Id>
<Title>Map Suite Mobile for Android - BareBone</Title>
<Summary />
<Description> This package allows you to add maps and perform GIS spatial operations within your Android application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
This is the barebone version of the Map Suite Mobile Edition and is intended for experienced Map Suite developers who require fine grain control over their dependencies. All other developer please use the Standard Edition found at the link below.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_android#barebone
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_android
Supported Platforms: Android
  Map Suite Desktop
  Map Suite Mobile
  Map Suite Web
  Map Suite Routing
  Map Suite Geocoder
  Map Suite Elevation
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Android Xamarin C# Control Mobile</Tags>
</PackageInfo> (Reviewed by Brad) 16
MapSuiteMobileForAndroid-Standard
<Id>MapSuiteMobileForAndroid-Standard</Id>
<Title>Map Suite Mobile for Android - Standard</Title>
<Summary />
<Description> This package allows you to add maps and perform GIS spatial operations within your Android application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action. Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_android#standard
  Map Suite Desktop
  Map Suite Mobile
  Map Suite Web
  Map Suite Routing
  Map Suite Geocoder
  Map Suite Elevation
</Description>
<ReleaseNote />
</PackageInfo> (Reviewed by Brad) 17
MapSuiteMobileForiOS-BareBone
<Id>MapSuiteMobileForiOS-BareBone</Id>
<Title>Map Suite Mobile for iOS - BareBone</Title>
<Summary />
<Description> This package allows you to add maps and perform GIS spatial operations within your iOS application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_ios#barebone
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_ios
Supported Platforms: iOS
  Map Suite Desktop
  Map Suite Mobile
  Map Suite Web
  Map Suite Routing
  Map Suite Geocoder
  Map Suite Elevation
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET iOS Xamarin C# Control Mobile iPhone iPad</Tags>
</PackageInfo> (Reviewed by Brad) 18
MapSuiteMobileForiOS-Standard
<Id>MapSuiteMobileForiOS-Standard</Id>
<Title>Map Suite Mobile for iOS - Standard</Title>
<Summary />
<Description>This package allows you to add maps and perform GIS spatial operations within your iOS application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_ios#standard
  Map Suite Desktop
  Map Suite Mobile
  Map Suite Web
  Map Suite Routing
  Map Suite Geocoder
<ReleaseNote />
</PackageInfo>
(Reviewed by Brad) 19
MapSuiteWebForMvc-BareBone
<Id>MapSuiteWebForMvc-BareBone</Id>
<Title>Map Suite Web for Mvc - BareBone</Title>
<Summary />
<Description> This package allows you to add maps and perform GIS spatial operations within your MVC application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
This is the barebone version of the Map Suite Web Edition and is intended for experienced Map Suite developers who require fine grain control over their dependencies. All other developer please use the Standard Edition found at the link below.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_mvc#barebone
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_mvc
  Map Suite Desktop
  Map Suite Mobile
  Map Suite Web
  Map Suite Routing
  Map Suite Geocoder
  Map Suite Elevation
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Mvc ASP.NET Web Control</Tags>
</PackageInfo> (Reviewed by Brad) 20
MapSuiteWebForMvc-Standard
<Id>MapSuiteWebForMvc-Standard</Id>
<Title>Map Suite Web for Mvc - Standard</Title>
<Summary />
<Description> This package allows you to add maps and perform GIS spatial operations within your MVC application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action. Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_mvc#standard
  Map Suite Desktop
  Map Suite Mobile
  Map Suite Web
  Map Suite Routing
  Map Suite Geocoder
  Map Suite Elevation
</Description>
<ReleaseNote />
</PackageInfo> (Reviewed by Brad) 21
MapSuiteWebForWebApi-BareBone
<Id>MapSuiteWebForWebApi-BareBone</Id>
<Title>Map Suite Web for WebApi - BareBone</Title>
<Summary />
<Description> This package allows you to add maps and perform GIS spatial operations within your WebAPI application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_webapi#barebone
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_webapi
  Map Suite Desktop
  Map Suite Mobile
  Map Suite Web
  Map Suite Routing
  Map Suite Geocoder
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET WebApi HTML5 JavaScript RESTful Webservice</Tags>
</PackageInfo>
(Reviewed by Brad) 22
MapSuiteWebForWebApi-Standard
<Id>MapSuiteWebForWebApi-Standard</Id>
<Title>Map Suite Web for WebApi - Standard</Title>
<Summary />
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_webapi#standard
  Map Suite Desktop
  Map Suite Mobile
  Map Suite Web
  Map Suite Routing
  Map Suite Geocoder
<ReleaseNote />
</PackageInfo>
(Reviewed by Brad) 23
MapSuiteWebForWebForms-BareBone
<Id>MapSuiteWebForWebForms-BareBone</Id>
<Title>Map Suite Web for WebForms - BareBone</Title>
<Summary />
<Description> This package allows you to add maps and perform GIS spatial operations within your WebForms application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action.
Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_webforms#barebone
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_webforms
  Map Suite Desktop
  Map Suite Mobile
  Map Suite Web
  Map Suite Routing
  Map Suite Geocoder
  Map Suite Elevation
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET WebForms ASP.NET Web Control</Tags>
</PackageInfo> (Reviewed by Brad) 24
MapSuiteWebForWebForms-Standard
<Id>MapSuiteWebForWebForms-Standard</Id>
<Title>Map Suite Web for WebForms - Standard</Title>
<Summary />
<Description> This package allows you to add maps and perform GIS spatial operations within your WebForms application. It provides classes to work with most GIS data formats, display popups, allow spatial drawing, manage projections, perform spatial operation and much more. Visit our website and wiki, link below, to learn more and watch Map Suite in action. Package Documentation: http://wiki.thinkgeo.com/wiki/map_suite_web_for_webforms#standard
  Map Suite Desktop
  Map Suite Mobile
  Map Suite Web
  Map Suite Routing
  Map Suite Geocoder
  Map Suite Elevation
</Description>
<ReleaseNote />
</PackageInfo> (Reviewed by Brad) 25
ThinkGeo.MapSuite.Cogo
<Id>ThinkGeo.MapSuite.Cogo</Id>
<Title>ThinkGeo MapSuite Cogo</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Cogo is an extension is an extension to the Map Suite product line, see below for compatibility. This extension provides the ability to use coordinate geometry. COGO refers to a data conversion process in which a digital map is constructed from written descriptions, such as legal descriptions of land parcel boundaries. Map Suite supports straight line calls like direction distance or x/y, as well as advance calls like tangent/non-tangent curve. Multi direction type are supported such as NorthAzimuth, Polar, SouthAzimuth and QuadrantBearing.
This is an extension for use in ThinkGeo's Map Suite product line, see below, as it cannot be used stand alone.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_api
Supported Platforms: Windows, Linux, MacOS, iOS, Android
- Compatible Products -
  Map Suite Desktop for WPF
  Map Suite Web for MVC
  Map Suite Web for WMS
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Cogo Coordinate Geometry</Tags>
</PackageInfo>
(Reviewed by Brad) 26
ThinkGeo.MapSuite.Drawing.PdfGeoCanvas
<Id>ThinkGeo.MapSuite.Drawing.PdfGeoCanvas</Id>
<Title>ThinkGeo MapSuite Drawing PdfGeoCanvas</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Drawing.PdfGeoCanvas is a extension for Map Suite Drawing. PdfGeoCanvas represents a canvas that is used to draw geographic shapes on a PDF document. It allows you to use PDF drawing to render your features. The basic flow of use for the class is to first call BeginDrawing and pass in an image along with its world extent.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET PdfGeoCanvas PDF</Tags>
</PackageInfo> (Reviewed by Brad) 27
ThinkGeo.MapSuite.Drawing.WicBitmapGeoCanvas
<Id>ThinkGeo.MapSuite.Drawing.WicBitmapGeoCanvas</Id>
<Title>ThinkGeo MapSuite Drawing WicBitmapGeoCanvas</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Drawing.WicBitmapGeoCanvas is an extension for Map Suite Drawing. The Windows Imaging Component (WIC) is an extensible platform that provides low-level API for digital images. WIC supports the standard web image formats, high dynamic range images, and raw camera data.
  Map Suite Desktop for WPF</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET WicBitmapGeoCanvas WIC</Tags>
</PackageInfo>
(Reviewed by Brad) 28
ThinkGeo.MapSuite.Geocoder
<Id>ThinkGeo.MapSuite.Geocoder</Id>
<Title>ThinkGeo MapSuite Geocoder</Title>
<Summary />
<Description>ThinkGeo MapSuite Geocoder is a native Geocoder and reverse Geocoder component for .NET that lets you convert a street address into a geographic location and vice-versa. It can also deliver additional details like county, FIPS codes, census tract and more. Plus, it ships with an optimized set of United States street data based on TIGER® 2012 data from the U.S. Census Bureau.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_geocoder_api
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Geocoder Reverse Geocode </Tags>
</PackageInfo> (Reviewed by Brad) 29
ThinkGeo.MapSuite.Jeffersonian
<Id>ThinkGeo.MapSuite.Jeffersonian</Id>
<Title>ThinkGeo MapSuite Jeffersonian</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Jeffersonian is a extension to the Map Suite product line, see below for compatibility. The Jeffersonian tool allows you to subdivide township ranges, sections, quarter-sections and lots as well as loading maps from surveys.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Jeffersonian MetesAndBounds Section Township Range</Tags>
</PackageInfo> (Reviewed by Brad) 30
ThinkGeo.MapSuite.Layers.Adornments
<Id>ThinkGeo.MapSuite.Layers.Adornments</Id>
<Title>ThinkGeo MapSuite Adornment Layers</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.AdornmentLayers is a layer extension to the Map Suite product line, see below for compatibility. It is used to place adornments on the map. Here is the link to our samples page that includes a sample for adornments: http://samples.thinkgeo.com/MvcEdition/HowDoISamples
This package integrates following adornment layers:
1. LegendAdornment, 2. LogoAdornment, 3. MagneticDeclinationAdornment, 4. ScaleBarAdornment, 5. ScaleLineAdornment, 6. ScaleTextAdornment
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Adornments Legends Titles North Arrows Logos Scale Line Bar Compass</Tags>
</PackageInfo>
(Reviewed by Brad)
31
ThinkGeo.MapSuite.Layers.Background
<Id>ThinkGeo.MapSuite.Layers.Background</Id>
<Title>ThinkGeo MapSuite Background Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Background is a layer extension to the Map Suite product line, see below for compatibility. This layer draws the background of the map. Here is the link to our samples page that includes a sample for changing backgrounds: http://samples.thinkgeo.com/MvcEdition/HowDoISamples
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Background</Tags>
</PackageInfo> (Reviewed by Brad) 32
ThinkGeo.MapSuite.Layers.BingMaps
<Id>ThinkGeo.MapSuite.Layers.BingMaps</Id>
<Title>ThinkGeo MapSuite BingMaps Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.BingMaps is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to create a layer using data obtained from the Bing Maps Imagery API. A license from Bing is required to use the Bing Map Layer in Map Suite. For more detail on obtaining the license, please visit https://www.microsoft.com/maps/licensing/licensing.aspx.
Here is the link to our samples page that includes a sample for Bing Maps: http://samples.thinkgeo.com/MvcEdition/HowDoISamples
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET BingMaps</Tags>
</PackageInfo> (Reviewed by Brad) 33
ThinkGeo.MapSuite.Layers.BoundarySolutionsParcel
<Id>ThinkGeo.MapSuite.Layers.BoundarySolutionsParcel</Id>
<Title>ThinkGeo MapSuite BoundarySolutionsParcel Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.BoundarySolutionsParcel is a layer extension is an extension to the Map Suite product line, see below for compatibility. Boundary Solutions Inc. has assembled the National ParcelMap Data Portal, or NPDP, the most current normalized digital parcel map databases from jurisdictions throughout the nation. This layer draws the parcel feature layer of the map.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET BoundarySolutionsParcel Parcel</Tags>
</PackageInfo> (Reviewed by Brad) 34
ThinkGeo.MapSuite.Layers.Cad
<Id>ThinkGeo.MapSuite.Layers.Cad</Id>
<Title>ThinkGeo MapSuite Cad Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Cad is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to render CAD formats as a data source. Computer-aided design (CAD) is the use of computer systems to aid in the creation, modification, analysis, or optimization of a design. CAD software for mechanical design uses either vector-based graphics to depict the objects of traditional drafting, or may also produce raster graphics showing the overall appearance of designed objects. CAD may be used to design curves and figures in two-dimensional space; or curves, surfaces, and solids in three-dimensional space.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET CAD DWG DXF</Tags>
</PackageInfo>
(Reviewed by Brad)
35
ThinkGeo.MapSuite.Layers.CloudFile
<Id>ThinkGeo.MapSuite.Layers.CloudFile</Id>
<Title>ThinkGeo MapSuite CloudFile Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.CloudFile is a layer extension to the Map Suite product line, see below for compatibility. This extension provides ability to load an online data source and render on maps.
A cloud file is a predefined data structure and style that is stored on Amazon’s S3 service.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET CloudFile</Tags>
</PackageInfo> (Reviewed by Brad) 36
ThinkGeo.MapSuite.Layers.Delimited
<Id>ThinkGeo.MapSuite.Layers.Delimited</Id>
<Title>ThinkGeo MapSuite Delimited Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Delimited is a layer extension to the Map Suite product line, see below for compatibility. This extension provides ability to load delimited data files and render on maps.
A delimited text file is a text file used to store data, in which each line represents a single book, company, or other thing, and each line has fields separated by the delimiter.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Delimited CSV Tab Pipe Comma Seperated</Tags>
</PackageInfo> (Reviewed by Brad) 37
ThinkGeo.MapSuite.Layers.Ecw
<Id>ThinkGeo.MapSuite.Layers.Ecw</Id>
<Title>ThinkGeo MapSuite Ecw Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Ecw is a layer extension is an extension to the Map Suite product line, see below for compatibility. The EcwRasterLayer represents an ECW file for drawing on the map. Simply provide the path and filename of the ECW file, add the layer to one of the Map Suite UI products, and start drawing. You can also draw the layer manually.
ECW is a wavelet image compression system developed by ER Mapper. It allows you to combine and compress large sets of satellite images into a single file. The images can be accessed very quickly at a variety of scales.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET ECW Raster Enhanced Compression Wavelet Image File Format</Tags>
</PackageInfo> (Reviewed by Brad) 38
ThinkGeo.MapSuite.Layers.FdoRaster
<Id>ThinkGeo.MapSuite.Layers.FdoRaster</Id>
<Title>ThinkGeo MapSuite Fdo Raster Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.FdoRasterSource is a layer extension to the Map Suite product line, see below for compatibility. This layer allows mapsuite to utilize FDO data sources. From the FDO website: “FDO Data Access Technology is an API for manipulating, defining and analyzing geospatial information regardless of where it is stored. FDO uses a provider-based model for supporting a variety of geospatial data sources, where each provider typically supports a particular data format or data store.” This is an extension for use in ThinkGeo's Map Suite product line, see below, as it cannot be used stand alone.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET FdoRasterSource FDO</Tags>
</PackageInfo> (Reviewed by Brad) 39
ThinkGeo.MapSuite.Layers.FdoVector
<Id>ThinkGeo.MapSuite.Layers.FdoVector</Id>
<Title>ThinkGeo MapSuite Fdo Feature Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.FdoFeatureSource is a layer extension to the Map Suite product line, see below for compatibility. This layer allows mapsuite to utilize FDO data sources. From the FDO website: “FDO Data Access Technology is an API for manipulating, defining and analyzing geospatial information regardless of where it is stored. FDO uses a provider-based model for supporting a variety of geospatial data sources, where each provider typically supports a particular data format or data store.” This is an extension for use in ThinkGeo's Map Suite product line, see below, as it cannot be used stand alone.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET FdoFeatureSource Image Format Data</Tags>
</PackageInfo> (Reviewed by Brad) 40
ThinkGeo.MapSuite.Layers.FileGeoDatabase
<Id>ThinkGeo.MapSuite.Layers.FileGeoDatabase</Id>
<Title>ThinkGeo MapSuite FileGeoDatabase Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.FileGeoDatabase is a layer extension to the Map Suite product line, see below for compatibility. It provides ability to load the GeoDatabase file format and render on maps.
A file geodatabase is a collection of files in a folder on disk that can store, query, and manage both spatial and nonspatial data.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET FileGeoDatabase GeoDatabase</Tags>
</PackageInfo> (Reviewed by Brad) 41
ThinkGeo.MapSuite.Layers.Gdal
<Id>ThinkGeo.MapSuite.Layers.Gdal</Id>
<Title>ThinkGeo MapSuite Gdal Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Gdal is a layer extension to the Map Suite product line, see below for compatibility. This extension provides ability to load the GDAL data format and render on maps.
The Geospatial Data Abstraction Library (GDAL) is a computer software library for reading and writing raster and vector geospatial data formats, and is released under the permissive X/MIT style free software license by the Open Source Geospatial Foundation. As a library, it presents a single abstract data model to the calling application for all supported formats.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET FdoGdal File Format Data GDAL</Tags>
</PackageInfo> (Reviewed by Brad) 42
ThinkGeo.MapSuite.Layers.GeoTiff
<Id>ThinkGeo.MapSuite.Layers.GeoTiff</Id>
<Title>ThinkGeo MapSuite GeoTiff Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.GeoTiff is a layer extension to the Map Suite product line, see below for compatibility. The TiffRasterLayer represents a TIFF file for drawing on the map. Simply provide the path and filename for the TIFF file, add the layer to one of the Map Suite UI products, and start drawing. You can also draw the layer manually.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET GeoTiff</Tags>
</PackageInfo> (Reviewed by Brad) 43
ThinkGeo.MapSuite.Layers.GoogleMaps
<Id>ThinkGeo.MapSuite.Layers.GoogleMaps</Id>
<Title>ThinkGeo MapSuite GoogleMaps Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.GoogleMaps is a layer extension to the Map Suite product line, see below for compatibility. This layer represents an object that encapsulates a Google Map layer. It uses Google Static Maps API to implement url requests. A license is required for use from Google Maps. Here is the link to our samples page that includes a sample for Google Maps: http://samples.thinkgeo.com/MvcEdition/HowDoISamples
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET GoogleMaps</Tags>
</PackageInfo> (Reviewed by Brad) 44
ThinkGeo.MapSuite.Layers.Gpx
<Id>ThinkGeo.MapSuite.Layers.Gpx</Id>
<Title>ThinkGeo MapSuite Gpx Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Gpx is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render a GPX data format on maps.
GPX, or GPS Exchange Format, is an XML schema designed as a common GPS data format for software applications. It can be used to describe waypoints, tracks, and routes.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Gpx GPS</Tags>
</PackageInfo> (Reviewed by Brad) 45
ThinkGeo.MapSuite.Layers.Graticule
<Id>ThinkGeo.MapSuite.Layers.Graticule</Id>
<Title>ThinkGeo MapSuite Graticule Layers</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Graticule is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load graticules and render on maps.
A Graticule feature layer shows meridians and parallels displaying through the map. Meridians are lines of longitude and they have a north-south orientation. Parallels are lines of latitude and they have an east-west orientation. Showing graticule for latitude and longitude is a standard way in cartography to give spatial references to the users.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Graticule Longitude Lines Latitude </Tags>
</PackageInfo> (Reviewed by Brad) 46
ThinkGeo.MapSuite.Layers.Grids
<Id>ThinkGeo.MapSuite.Layers.Grids</Id>
<Title>ThinkGeo MapSuite Grids Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Grids is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load grids and render on maps.
The layer displays cells with different colors in a rectangular area of a map. The color of a cell depends on the cell value in the grid file. The grid file provides information about the grid such as row and column numbers, coordinates of the lower left corner, cell size, and values of cells.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Grids</Tags>
</PackageInfo> (Reviewed by Brad) 47
ThinkGeo.MapSuite.Layers.Group
<Id>ThinkGeo.MapSuite.Layers.Group</Id>
<Title>ThinkGeo MapSuite Group Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Group is a layer extension to the Map Suite product line, see below for compatibility. It is a special layer has the ability to contain a set of other layers.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Group</Tags>
</PackageInfo> (Reviewed by Brad) 48
ThinkGeo.MapSuite.Layers.Heat
<Id>ThinkGeo.MapSuite.Layers.Heat</Id>
<Title>ThinkGeo MapSuite Heat Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Heat is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load a point dataset and generate a heat visualization based on the density of points in a region.
A heat layer allows you to better visualize data by making areas of high concentration “hotter” using warmer colors and low density areas visually cooler.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Heat Sales Map</Tags>
</PackageInfo> (Reviewed by Brad) 49
ThinkGeo.MapSuite.Layers.IsoLine
<Id>ThinkGeo.MapSuite.Layers.IsoLine</Id>
<Title>ThinkGeo MapSuite IsoLine Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.IsoLine is a layer extension to the Map Suite product line, see below for compatibility. This extension provides ability to load point data with elevation value and render the data as an ISO line map. An isoline is a line connecting points of equal value on a map.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET IsoLine Contour Lines Elevation</Tags>
</PackageInfo> (Reviewed by Brad) 50
ThinkGeo.MapSuite.Layers.Jpeg2000
<Id>ThinkGeo.MapSuite.Layers.Jpeg2000</Id>
<Title>ThinkGeo MapSuite Jpeg2000 Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Jpeg2000 is a layer extension to the Map Suite product line, see below for compatibility. This layer allows you to access pictures from an JPEG2000 file. This class is typically used in the JPEG2000RasterLayer to allow JPEG2000 raster images to be shown on your map.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Jpeg2000 Raster Aerial JP2</Tags>
</PackageInfo> (Reviewed by Brad) 51
ThinkGeo.MapSuite.Layers.Kml
<Id>ThinkGeo.MapSuite.Layers.Kml</Id>
<Title>ThinkGeo MapSuite Kml Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Kml is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render KML data formats on maps.
Keyhole Markup Language (KML) is an XML notation for expressing geographic annotation and visualization within Internet-based, two-dimensional maps and three-dimensional Earth browsers.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Kml Google Earth Kmz</Tags>
</PackageInfo> (Reviewed by Brad) 52
ThinkGeo.MapSuite.Layers.MapShape
<Id>ThinkGeo.MapSuite.Layers.MapShape</Id>
<Title>ThinkGeo MapSuite MapShape Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.MapShape is a layer extension to the Map Suite product line, see below for compatibility. This layer represents a mapshape layer drawn on map. Each MapShape composes of a feature and a ZoomLevelSet to control its drawing zoomlevels. This extension provides the ability to load map shapes into a layer and render on maps.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET MapShape</Tags>
</PackageInfo> (Reviewed by Brad) 53
ThinkGeo.MapSuite.Layers.MrSid
<Id>ThinkGeo.MapSuite.Layers.MrSid</Id>
<Title>ThinkGeo MapSuite MrSid Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.MrSid is a layer extension to the Map Suite product line, see below for compatibility. The MrSidRasterLayer represents a MrSid file for drawing on the map. This extension provides the ability to load a MrSid file and render on maps. MrSid is a image compression system developed by LizardTech. It allows you to combine and compress large sets of satellite images into a single file. The images can be accessed very quickly at a variety of scales.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET MrSid Raster</Tags>
</PackageInfo> (Reviewed by Brad) 54
ThinkGeo.MapSuite.Layers.MsSql
<Id>ThinkGeo.MapSuite.Layers.MsSql</Id>
<Title>ThinkGeo MapSuite MsSql Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.MsSql is a layer extension to the Map Suite product line, see below for compatibility. This layer represents a FeatureSource backed by MS SQL.
This layer takes advantage of the Microsoft SQL server spatial extension as of SQL server 2008 allowing you to store data natively as geometries.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET MsSql Microsoft Database</Tags>
</PackageInfo> (Reviewed by Brad) 55
ThinkGeo.MapSuite.Layers.MultipleFeatureSource
<Id>ThinkGeo.MapSuite.Layers.MultipleFeatureSource</Id>
<Title>ThinkGeo MapSuite MultipleFeature Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.MultipleFeature is a layer extension is an extension to the Map Suite product line, see below for compatibility. This layer is a special layer that can contain multiple other layers.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET MultipleFeatureSource Multiple</Tags>
</PackageInfo> (Reviewed by Brad) 56
ThinkGeo.MapSuite.Layers.NativeImage
<Id>ThinkGeo.MapSuite.Layers.NativeImage</Id>
<Title>ThinkGeo MapSuite NativeImage Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.NativeImage is a layer extension to the Map Suite product line, see below for compatibility. This type of layer is used to draw standard image types on the map. These include .BMP, .JPG, .PNG, .TIFF, and all other image types that are supported by the .NET Framework to be loaded as a Bitmap. Each of these images will need a world file associated with it. The world file contains the geospatial information pertaining to the image. Using the world file, we know its spatial position and other required information to draw it on the map relative to other images or spatial features. World files are small text files with an extension that matches the original image's extension, but with the middle character of the extension changed to a “w”. If you have images that you want to use but do not have their world files, please contact the source of the image so that they can provide one for you. world files are fairly common in the GIS community.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET NativeImage Native</Tags>
</PackageInfo> (Reviewed by Brad) 57
ThinkGeo.MapSuite.Layers.NauticalCharts
<Id>ThinkGeo.MapSuite.Layers.NauticalCharts</Id>
<Title>ThinkGeo MapSuite NauticalCharts Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.NauticalCharts is a layer extension to the Map Suite product line, see below for compatibility. This extension represents a layer backed by a IHO ENC 000 File.
The new ThinkGeo Nautical Charts Extension is a great tool for any .NET developer who needs to create or view desktop or web maps that display NOAA’s Electronic Navigational Charts which conform to the International Hydrograph Office (IHO) S-57 international exchange format as defined in the special publication S-52.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET NauticalCharts S52 S57 Maritime Marine</Tags>
</PackageInfo> (Reviewed by Brad) 58
ThinkGeo.MapSuite.Layers.Noaa
<Id>ThinkGeo.MapSuite.Layers.Noaa</Id>
<Title>ThinkGeo MapSuite Noaa Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Noaa is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render NOAA weather station, warning and radar maps.
For the US NOAA also provides real time weather watches, warnings and advisory polygons as a feature layers which you can use as an overlay. Additionally for the US, NOAA also provides weather radar images. All this data is refreshed approximately every 5-15 minutes in the background. With all these APIs you have full control over transparency so you can easily see the affected areas beneath the radar images, weather watches and warnings polygons.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Noaa Weather</Tags>
</PackageInfo> (Reviewed by Brad) 59
ThinkGeo.MapSuite.Layers.Ogr
<Id>ThinkGeo.MapSuite.Layers.Ogr</Id>
<Title>ThinkGeo MapSuite Ogr Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Ogr is a layer extension to the Map Suite product line, see below for compatibility. It provides ability to load and render OGR data format on map.
The Geospatial Data Abstraction Library (GDAL) is a computer software library for reading and writing raster and vector geospatial data formats. As a library, it presents a single abstract data model to the calling application for all supported formats. It may also be built with a variety of useful command line interface utilities for data translation and processing. The related OGR library (OGR Simple Features Library), which is part of the GDAL source tree, provides a similar ability for simple features vector graphics data.
The related OGR library (OGR Simple Features Library[2]), which is part of the GDAL source tree, provides a similar ability for simple features vector graphics data.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET FdoOgr FDO OGR</Tags>
</PackageInfo> (Reviewed by Brad) 60
ThinkGeo.MapSuite.Layers.OpenStreetMap
<Id>ThinkGeo.MapSuite.Layers.OpenStreetMap</Id>
<Title>ThinkGeo MapSuite OpenStreetMap Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.OpenStreetMap is a layer extension is an extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render Open Street Map online resources on maps.
OpenStreetMap (OSM) is a collaborative project to create a free editable map of the world. Rather than the map itself, the data generated by the OpenStreetMap project are considered its primary output.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET OpenStreetMap OSM</Tags>
</PackageInfo> (Reviewed by Brad) 61
ThinkGeo.MapSuite.Layers.Oracle
<Id>ThinkGeo.MapSuite.Layers.Oracle</Id>
<Title>ThinkGeo MapSuite Oracle Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Oracle is a layer extension to the Map Suite product line, see below for compatibility. This layer represents a Layer backed by Oracle Spatial.
Oracle Spatial and Graph includes high performance, enterprise-scale, commercial spatial and graph database and analytics for Oracle Database 12c. It supports enterprise business and business intelligence, large-scale Geographic Information Systems, and location-based services applications on premises and in the Cloud.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Oracle Database</Tags>
</PackageInfo> (Reviewed by Brad) 62
ThinkGeo.MapSuite.Layers.PersonalGeoDatabase
<Id>ThinkGeo.MapSuite.Layers.PersonalGeoDatabase</Id>
<Title>ThinkGeo MapSuite PersonalGeoDatabase Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.PersonalGeoDatabase is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render a Personal GeoDatabase data format on maps.
A personal geodatabase is a Microsoft Access database that can store, query, and manage both spatial and nonspatial data.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET FdoPersonalGeoDatabase GeoDatabase FDO</Tags>
</PackageInfo> (Reviewed by Brad) 63
ThinkGeo.MapSuite.Layers.PostgreSql
<Id>ThinkGeo.MapSuite.Layers.PostgreSql</Id>
<Title>ThinkGeo MapSuite PostgreSql Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.PostgreSql is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load a PostgreSql feature layer and render on maps.
PostgreSQL, often simply Postgres, is an object-relational database, with additional “object” features – with an emphasis on extensibility and standards compliance. As a database server, its primary function is to store data securely, and to allow for retrieval at the request of other software applications. It can handle workloads ranging from small single-machine applications to large Internet-facing applications (or for data warehousing) with many concurrent users; on macOS Server, PostgreSQL is the default database; and it is also available for Microsoft Windows and Linux (supplied in most distributions).
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET PostgreSql Database</Tags>
</PackageInfo> (Reviewed by Brad) 64
ThinkGeo.MapSuite.Layers.Printers
<Id>ThinkGeo.MapSuite.Layers.Printers</Id>
<Title>ThinkGeo MapSuite Printer Layers</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.PrinterLayers is a layer extension to the Map Suite product line, see below for compatibility. This is used to design page layouts for maps. You can use this layer to layout the physical page to be printed. This package integrates the following printer layers:
1. DataGridPrinter, 2. ImagePrinter, 3. LabelPrinter, 4. LegendPrinter, 5. MagneticDeclinationPrinter, 6. MapPrinter, 7. PagePrinter, 8. ScaleBarPrinter, 9. ScaleLinePrinter, 10. ScaleTextPrinter
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Printers Print Dpi</Tags>
</PackageInfo> (Reviewed by Brad) 65
ThinkGeo.MapSuite.Layers.Restriction
<Id>ThinkGeo.MapSuite.Layers.Restriction</Id>
<Title>ThinkGeo MapSuite Restriction Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Restriction is a layer extension to the Map Suite product line, see below for compatibility. This layer can show or hide one or many zones that you want to restrict from being displayed. You can use the specified style to decorate the zones and set the lower/upper scale to control at which zoom levels you want to show or hide the zones. The default decoration style is a hatch pattern. You can change this to a circle with slash image, or, if you want a different look, you can use custom styles.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Restriction</Tags>
</PackageInfo> (Reviewed by Brad) 66
ThinkGeo.MapSuite.Layers.Sdf
<Id>ThinkGeo.MapSuite.Layers.Sdf</Id>
<Title>ThinkGeo MapSuite SDF Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Sdf is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render the SDF data format on maps.
Simple Data Format or SDF is a platform-independent, precision-preserving binary data I/O format capable of handling large, multi-dimensional arrays.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET FdoSdf FDO SDF</Tags>
</PackageInfo>
(Reviewed by Brad) 67
ThinkGeo.MapSuite.Layers.ShapeFile
<Id>ThinkGeo.MapSuite.Layers.ShapeFile</Id>
<Title>ThinkGeo MapSuite ShapeFile Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.ShapeFile is a layer extension to the Map Suite product line, see below for compatibility. This layer represents a FeatureSource backed by a ESRI Shape File.
The shapefile format is a popular geospatial vector data format for geographic information system (GIS) software. It is developed and regulated by ESRI as a (mostly) open specification for data interoperability among ESRI and other GIS software products. The shapefile format can spatially describe vector features: points, lines, and polygons, representing, for example, water wells, rivers, and lakes. Each item usually has attributes that describe it, such as name or temperature.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET ShapeFile SHP SHX DBF</Tags>
68
ThinkGeo.MapSuite.Layers.Sqlite
<Id>ThinkGeo.MapSuite.Layers.Sqlite</Id>
<Title>ThinkGeo MapSuite SQLite Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Sqlite is a layer extension to the Map Suite product line, see below for compatibility. This layer represents a FeatureSource backed by SQLite.
This extension utilizes SQL R*Tree module which allows it to natively query geometries at super fast speeds. An R-Tree is a special index that is designed for doing range queries.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET SQLite Database</Tags>
</PackageInfo> (Reviewed by Brad) 69
ThinkGeo.MapSuite.Layers.SqliteForLinux
<Id>ThinkGeo.MapSuite.Layers.SqliteForLinux</Id>
<Summary />
Supported Platforms: Linux
</Description>
<ReleaseNote />
</PackageInfo> (Reviewed by Brad) 70
ThinkGeo.MapSuite.Layers.Tab
<Id>ThinkGeo.MapSuite.Layers.Tab</Id>
<Title>ThinkGeo MapSuite TAB Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Tab is a layer extension is an extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render the .TAB data format on maps.
Tab files(.TAB) are popular geospatial data format. Each Tab file has an associated file that stores all the attribute data in it, most commonly a .DAT file.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Tab MapInfo</Tags>
</PackageInfo> (Reviewed by Brad) 71
ThinkGeo.MapSuite.Layers.TiledWms
<Id>ThinkGeo.MapSuite.Layers.TiledWms</Id>
<Title>ThinkGeo MapSuite TiledWms Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.TiledWms is a layer extension to the Map Suite product line, see below for compatibility.
This layer is use for a tiled WMS Server. You also can get maps from ThinkGeo world map kit server. A Web Map Service (WMS) is a standard protocol for serving (over the Internet) georeferenced map images which a map server generates using data from a GIS database
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET TiledWms WMS</Tags>
</PackageInfo>
(Reviewed by Brad) 72
ThinkGeo.MapSuite.Layers.TinyGeo
<Id>ThinkGeo.MapSuite.Layers.TinyGeo</Id>
<Title>ThinkGeo MapSuite TinyGeo Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.TinyGeo is a layer extension to the Map Suite product line, see below for compatibility. This layer represents a FeatureLayer created from a TinyGeo File by ThinkGeo.
What is TinyGeo? The goal of the format is to provide our customers with a highly compressed, read-only, secure and easily distributable data file that they can use to disseminate spatial data to their clients.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET TinyGeo Tgeo</Tags>
</PackageInfo> (Reviewed by Brad) 73
ThinkGeo.MapSuite.Layers.TobinBas
<Id>ThinkGeo.MapSuite.Layers.TobinBas</Id>
<Title>ThinkGeo MapSuite TobinBas Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.TobinBas is a layer extension is an extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render the Tobin.Bas data format on maps.
The TOBIN TDRBM II Data Distribution format, commonly called TDRBM II, provides an enhanced graphical representation of TOBIN Survey information.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET TobinBas</Tags>
</PackageInfo> (Reviewed by Brad) 74
ThinkGeo.MapSuite.Layers.Wfs
<Id>ThinkGeo.MapSuite.Layers.Wfs</Id>
<Title>ThinkGeo MapSuite WFS Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Wfs is a layer extension is an extension to the Map Suite product line, see below for compatibility. This layer represents the WFS (web feature service) feature layer.
In computing, the Open Geospatial Consortium Web Feature Service Interface Standard (WFS) provides an interface allowing requests for geographical features across the web using platform-independent calls.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET WFS Web Feature Source</Tags>
</PackageInfo> (Reviewed by Brad) 75
ThinkGeo.MapSuite.Layers.WkbFile
<Id>ThinkGeo.MapSuite.Layers.WkbFile</Id>
<Title>ThinkGeo MapSuite WkbFile Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.WkbFile is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load and render the WKB data format on maps.
WKB stands for Well-Known Binary, a format for representing geographical and geometrical data.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET WkbFile WellKnownBinary WKB</Tags>
</PackageInfo> (Reviewed by Brad) 76
ThinkGeo.MapSuite.Layers.Wms
<Id>ThinkGeo.MapSuite.Layers.Wms</Id>
<Title>ThinkGeo MapSuite Wms Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Wms is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load the WMS format and render on maps.
A Web Map Service (WMS) produces maps of spatially referenced data dynamically from geographic information. This International Standard defines a “map” to be a portrayal of geographic information as a digital image file suitable for display on a computer screen. A map is not the data itself. WMS-produced maps are generally rendered in a pictorial format such as PNG, GIF or JPEG, or occasionally as vector-based graphical elements in Scalable Vector Graphics (SVG) or Web Computer Graphics Metafile (WebCGM) formats.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET WMS Web Map Service</Tags>
</PackageInfo> (Reviewed by Brad) 77
ThinkGeo.MapSuite.Layers.Wmts
<Id>ThinkGeo.MapSuite.Layers.Wmts</Id>
<Title>ThinkGeo MapSuite Wmts Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.Wmts is a layer extension to the Map Suite product line, see below for compatibility. This extension provides the ability to load a WMTS file format and render on maps.
A Web Map Tile Service (WMTS) is a standard protocol for serving pre-rendered georeferenced map tiles over the Internet.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Wmts OpenGIS Web Map Tile Service</Tags>
</PackageInfo> (Reviewed by Brad) 78
ThinkGeo.MapSuite.Layers.WorldMapKit
<Id>ThinkGeo.MapSuite.Layers.WorldMapKit</Id>
<Title>ThinkGeo MapSuite WorldMapKit Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.WorldMapKit is a layer extension to the Map Suite product line, see below for compatibility. This layer is used for world map kit data that can be retrieved from the ThinkGeo world map kit server.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET WorldMapKit Basemaps Vector Aerial Offline Street Hybrid SQLite</Tags>
</PackageInfo> (Reviewed by Brad) 79
ThinkGeo.MapSuite.Layers.WorldStreetsAndImagery
<Id>ThinkGeo.MapSuite.Layers.WorldStreetsAndImagery</Id>
<Title>ThinkGeo MapSuite WorldStreetsAndImagery Layer</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Layers.WorldStreetsAndImagery is a layer extension to the Map Suite product line, see below for compatibility. This layer is used for the world streets data format that can be retrieved from the ThinkGeo world streets server.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET WorldMapKit WorldStreets Basemaps Vector Aerial Offline Street Hybrid SQLite</Tags>
</PackageInfo> (Reviewed by Brad) 80
ThinkGeo.MapSuite.ProductCenter
<Id>ThinkGeo.MapSuite.ProductCenter</Id>
<Title>ThinkGeo MapSuite ProductCenter</Title>
<Summary />
<Description>ThinkGeo MapSuite Product Center is the ThinkGeo Map Suite SDK for .NET - Core Runtime. It provides download license, sample, daliy build etc. low level functions for building GIS applications. It is the basic product dependency package across all of the MapSuite 10.0 product line and above.
This is a package for ThinkGeo's Map Suite product, see below, as it cannot be used stand alone.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET ProductCenter</Tags>
</PackageInfo> (Reviewed by Brad) 81
ThinkGeo.MapSuite.Routing
<Id>ThinkGeo.MapSuite.Routing</Id>
<Title>ThinkGeo MapSuite Routing</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Routing is an extension to the Map Suite product line, see below for compatibility. ThinkGeo.MapSuite.Routing gives your Map Suite applications the power to find the shortest path from A to B, deliver turn-by-turn directions, avoid specified areas, optimize for the Traveling Salesperson Problem and much more.
Wiki Documentation: http://wiki.thinkgeo.com/wiki/map_suite_routing_api
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Routing Driving Directions Route Turn-by-Turn Traveling Salesman </Tags>
</PackageInfo> (Reviewed by Brad) 82
ThinkGeo.MapSuite.Shapes.UnmanagedProj4Projection
<Id>ThinkGeo.MapSuite.Shapes.UnmanagedProj4Projection</Id>
<Title>ThinkGeo MapSuite Shapes UnmanagedProj4Projection</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Shapes.UnmanagedProj4Projection is an extension for Map Suite products to re-project vector and raster data format with a specific proj4 projection string.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET UnmanagedProj4Projection Projections Proj4</Tags>
</PackageInfo> (Reviewed by Brad) 83
ThinkGeo.MapSuite.Styles.ClassBreak
<Id>ThinkGeo.MapSuite.Styles.ClassBreak</Id>
<Title>ThinkGeo MapSuite Styles ClassBreak</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Styles.ClassBreak is a style extension to the Map Suite product line, see below for compatibility. The ClassBreakStyle allows you to change the way features are drawn based on their data values. It is often useful for you to display features differently based on ranges of numeric values. For example, you may have a ShapeFile comprised of states that has the populations of each state as part of its data. You may then want to color states differently based on their population. This ClassBreakStyle allows you to do this.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET ClassBreak Thematic</Tags>
</PackageInfo> (Reviewed by Brad) 84
ThinkGeo.MapSuite.Styles.ClusterPoint
<Id>ThinkGeo.MapSuite.Styles.ClusterPoint</Id>
<Title>ThinkGeo MapSuite ClusterPoint Style</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Styles.ClusterPoint is a style extension to the Map Suite product line, see below for compatibility. It provides ability to cluster nearest markers to one marker with a specific style.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET ClusterPoint Styles Clustering Cluster</Tags>
</PackageInfo> (Reviewed by Brad) 85
ThinkGeo.MapSuite.Styles.Composite
<Id>ThinkGeo.MapSuite.Styles.Composite</Id>
<Title>ThinkGeo MapSuite Composite Style</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Styles.Composite is a style extension to the Map Suite product line, see below for compatibility. It is a special style that allows to a style to contain various other styles.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Composite Styles</Tags>
</PackageInfo> (Reviewed by Brad) 86
ThinkGeo.MapSuite.Styles.DotDensity
<Id>ThinkGeo.MapSuite.Styles.DotDensity</Id>
<Title>ThinkGeo MapSuite DotDensity Style</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Styles.DotDensity is a style extension to the Map Suite product line, see below for compatibility. This style allows you to display information by drawing points on an area based on a value from the features’ data. The higher the value is in the data, the greater the number of points that are drawn. The points themselves are distributed randomly inside of the polygon.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET DotDensity Styles Population Dot Density</Tags>
</PackageInfo> (Reviewed by Brad) 87
ThinkGeo.MapSuite.Styles.Filter
<Id>ThinkGeo.MapSuite.Styles.Filter</Id>
<Title>ThinkGeo MapSuite Filter Style</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Styles.Filter is a style extension to the Map Suite product line, see below for compatibility. It provides the ability to display features with a specific filter condition.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Filter Styles</Tags>
</PackageInfo> (Reviewed by Brad) 88
ThinkGeo.MapSuite.Styles.FleeBoolean
<Id>ThinkGeo.MapSuite.Styles.FleeBoolean</Id>
<Title>ThinkGeo MapSuite FleeBoolean Style</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Styles.FleeBoolean is a style extension is an extension to the Map Suite product line, see below for compatibility. This extension provides the ability to evaluate complex expressions to create styles.
FLEE is an acronym for Fast Lightweight Expression Evaluator. It is an expression parser and evaluator for the .NET framework. It allows you to compute the value of string expressions such as sqrt(a^2 + b^2) at runtime.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET FleeBoolean Logical Operation</Tags>
</PackageInfo> (Reviewed by Brad) 89
ThinkGeo.MapSuite.Styles.Gradient
<Id>ThinkGeo.MapSuite.Styles.Gradient</Id>
<Title>ThinkGeo MapSuite Gradient Style</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Styles.Gradient is a style extension to the Map Suite product line, see below for compatibility. This gradient style is a new style with the concept of GradientBrush. By specifying the LowerValue and its color, as well as the UpperValue and its color, we can set the color of each feature based on a column value using linear interpolation.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Gradient</Tags>
</PackageInfo> (Reviewed by Brad) 90
ThinkGeo.MapSuite.Styles.Icon
<Id>ThinkGeo.MapSuite.Styles.Icon</Id>
<Title>ThinkGeo MapSuite Icon Style</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Styles.Icon is a style extension to the Map Suite product line, see below for compatibility. This style displays an icon with text from the data of the feature. You can use the icon style when you have an icon you want to display on the map with characters inside of that icon. For example, if you have a circular icon and you want to label the number 1-100 inside of the icon, you can use this class. You need to specify the column name where the numbers or letters will come from, as well as a font. Through various properties, you can also control the positioning of the icon, just as you would with a TextStyle.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Icon Style Custom</Tags>
</PackageInfo> (Reviewed by Brad) 91
ThinkGeo.MapSuite.Styles.IconValue
<Id>ThinkGeo.MapSuite.Styles.IconValue</Id>
<Title>ThinkGeo MapSuite IconValue Style</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Styles.IconValue is a style extension is an extension to the Map Suite product line, see below for compatibility. This class allows you to choose different icons based on values in the data of a feature. When you create an IconValueStyle, you need to add multiple IconValueItems to its collection. You input the column name in the IconValueStyle and it will compare the data's value to each IconValueItems’ data. If they match, it will then draw the Feature using the properties of the IconValueItem. In this way, you can render different data with different icons or text.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET IconValue Style</Tags>
</PackageInfo> (Reviewed by Brad) 92
ThinkGeo.MapSuite.Styles.Regex
<Id>ThinkGeo.MapSuite.Styles.Regex</Id>
<Title>ThinkGeo MapSuite Regex Style</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Styles.Regex is a style extension to the Map Suite product line, see below for compatibility. The RegexStyle allows you to use complex regular expression matching to determine how your features are drawn. A regular expression is a matching syntax that allows you to match a string based on very complex criteria. For example, let's say you have a layer that has a column in the data that contains school names. Most school names include the type of school they are. For instance, you may have “Lincoln Middle School” or “Bush High School.” There are variations to these names though, containing words such as “Elementary” or “Prep.” With a regular expression, you can create matching criteria that will allow you to match on many variations of the names. It is especially useful for fuzzy matches where your data is not clearly categorized. Another classic example is for matching or validating email addresses, where matching rules can become complex. In the RegexStyle, you specify the matching criteria string and also the style you want to use to draw the feature if the criteria matches. It is a simple yet powerful style for dealing with complex rule sets and imprecise data.
  Map Suite Desktop for WinForms
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Regex Style Wildcard Wild Card</Tags>
</PackageInfo> (Reviewed by Brad) 93
ThinkGeo.MapSuite.Styles.Value
<Id>ThinkGeo.MapSuite.Styles.Value</Id>
<Title>ThinkGeo MapSuite Value Style</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Styles.Value is a style extension to the Map Suite product line, see below for compatibility. The ValueStyle allows you to match data in the FeatureSource against a value string. If the value matches, then we will use the style defined in that item to do the drawing. For example, let's say you have some data that contains states, and each state is categorized as either a high, medium or low pollution state. Based on the string values of “High”, Medium“ and “Low”, we can match on these. If a feature's data for the column matched the string “High”, then we would use the high ValueItem's styles to draw that feature. This can be applied to all kinds of things such as road classification and more.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Value Style</Tags>
</PackageInfo> (Reviewed by Brad) 94
ThinkGeo.MapSuite.Styles.WellPoint
<Id>ThinkGeo.MapSuite.Styles.WellPoint</Id>
<Title>ThinkGeo MapSuite WellPoint Style</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Styles.WellPoint is a style extension to the Map Suite product line, see below for compatibility. This style uses hundreds of pre-defined well-point styles to display point vector data.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET WellPoint Well</Tags>
</PackageInfo> (Reviewed by Brad) 95
ThinkGeo.MapSuite.Styles.WorldMapKit
<Id>ThinkGeo.MapSuite.Styles.WorldMapKit</Id>
<Title>ThinkGeo MapSuite WorldMapKit Style</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Styles.WorldMapKit is a style extension to the Map Suite product line, see below for compatibility. It is a pre-defined style in MapSuite containing WorldMapKitAreaStyles, WorldMapKitLineStyles, WorldMapKitPointStyles and WorldMapKitTextStyles.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET WorldMapKit</Tags>
</PackageInfo> (Reviewed by Brad) 96
ThinkGeo.MapSuite.Styles.WorldStreets
<Id>ThinkGeo.MapSuite.Styles.WorldStreets</Id>
<Title>ThinkGeo MapSuite WorldStreets Style</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Styles.WorldStreets is a style extension to the Map Suite product line, see below for compatibility. It is a pre-defined style in MapSuite containing WorldStreetsAreaStyles, WorldStreetsLineStyles, WorldStreetsPointStyles and WorldStreetsTextStyles.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET WorldStreets</Tags>
</PackageInfo> (Reviewed by Brad) 97
ThinkGeo.MapSuite.Styles.ZedGraph
<Id>ThinkGeo.MapSuite.Styles.ZedGraph</Id>
<Title>ThinkGeo MapSuite ZedGraph Style</Title>
<Summary />
<Description>ThinkGeo.MapSuite.Styles.ZedGraph is a style extension to the Map Suite product line, see below for compatibility. Zedgraph is a truly massive library for graphics and charts. As you can add pie charts to your map, you can also add bar charts, trend charts etc. with this style.
</Description>
<ReleaseNote />
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET ZedGraph Line Bar Pie Special Charts Graph</Tags>
</PackageInfo> (Reviewed by Brad) 98
ThinkGeo.MapSuite
<Id>ThinkGeo.MapSuite</Id>
<Title>ThinkGeo MapSuite</Title>
<Summary />
<Description>ThinkGeo.MapSuite is the ThinkGeo Map Suite SDK for .NET - Core Runtime. It provides geometries, data source, layers, styles, rendering, and low level functions for building GIS applications. It is the basic core dependency package across all of the MapSuite 10.0 product line.
  Map Suite Mobile for Android
</Description>
<ReleaseNote />
<LicenseUrl>http://wiki.thinkgeo.com/wiki/licenseagreement</LicenseUrl>
<RequireLicenseAcceptance>true</RequireLicenseAcceptance>
<Tags> Spatial GIS ThinkGeo MapSuite Map Suite .NET Map Suite</Tags>
</PackageInfo>
(Reviewed by Brad)
package_descriptions_for_review.1488344122.txt.gz · Last modified: 2017/03/01 04:55 by tgwikiupdate
