map_suite_wpf_desktop_edition_miscellaneous_samples
Map Suite Wpf Desktop Edition Miscellaneous Samples
Custom Scale Bar
Draw Custom Exception
MDI Form
Topology Validation
Use Map with MVC Framework
ShapeFile to SQLite Convertion Tool
This sample demonstrates how to save the features in a shape file (.shp) into a Sqlite file (.sqlite) for a higher query performance. This takes the built-in functionalities of recent daily builds after 9.0.0.1/9.0.1.0 or later, which you can download from the ThinkGeo Customer Portal or Map Suite Product Center.
Indexed Raster Layer
This sample shows how to create indexed raster layer. The sample supports rTree index file and create it if not exist. It is high performance for multiple raster layers.
Finding Nearest Cross Streets
Labeling Flight Lines
This sample shows how to offset arc shaped flight lines so multiple from point to point are visible and then show popup labels providing information on the flights the lines represent.
Map Suite Explorer (ServiceEdition)
Tile Cache Generator
<div sample_otherlinks> [
map_suite_wpf_desktop_edition_miscellaneous_samples.txt · Last modified: 2017/03/17 02:12 by tgwikiupdate
