map_suite_wpf_desktop_edition_faq_styles
Table of Contents
Map Suite Wpf Desktop Edition FAQ Styles
How do I represent points using an animated GIF?
Sample: Animated Gif
In today’s project, we learn how to extend InMemoryFeatureLayer to have the ability to display animated gif for each layer in the Desktop edition. You will notice that for now, we are limited to have one animated gif per InMemoryFeatureLayer but in the future, we will show the technique to have a different animated gif for each feature of the InMemoryFeatureLayer.
Sample: Cached Value Style
How do I cluster multiple points into one point for display?
Sample:ClusterPointStyle
How do I display a label in real world dimensions?
Sample:World Sized Text Style
How do I display an icon in real world dimensions?
How do I word wrap my labels?
Sample:WordWrapped TextStyle
How do I draw features differently based on column values?
How can I display decimal degrees as degrees, minutes and seconds?
How do I display a point based on real time data such as the current time?
Sample:Time Based Point Style
How do I label each line in a MultiLineShape?
How can I show one-way streets arrows on my roads?
How do I draw a line with a different start and end style?
Sample:Start End LineStyle
How do I display the distance of a line as label?
Sample:Distance Line Style
How do I display a point as a doughnut shape?
Sample:Doughnut Point Style
How do I draw points where the size is proportional to a column value?
Sample:Sized Point Style
How do I rotate a side view icon based on its heading?
Sample:Side View Icon
Sample:EditOverlay Styles
How do I draw an icon that flashes?
Sample:Flashing Point Style
How do I make a text larger or smaller based on the current scale?
Sample:Scaling TextStyle
How do I make an icon larger or smaller based on the current scale?
Sample:Scaling Image Style
How do I create a custom style to display routes?
Sample:Routing Styles
Sample:Rotate Icon
Sample:Rotated Image Style
Sample:Vehicle Direction
How do I rotate a feature's text similar to word wrapping?
Sample:Hybrid TextStyle
This project is a follow up to the Discussion Forum post http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6652/afv/topic/Default.aspx Rotating the feature text (similar to wordwrap). In this project, we create a new Text Style combining word wrapping that we saw in the project http://code.thinkgeo.com/projects/show/wordwrapped and text rotation. You can see the labels word wrapping and rotating in harmony with the resizing and rotating of the shapes.
How do I set multiple dot density styles on the map?
How to create a cutomer valuestyle?
Sample:Default ValueStyle
How to create a line style with increment?
How do I display multi line labeling?
Sample:MultiLine Labeling
How to create a weather line style?
Sample:Weather Line Style
Sample:Isolines
map_suite_wpf_desktop_edition_faq_styles.txt · Last modified: 2015/09/17 03:24 by admin
