map_suite_windows_phone_edition_features_bug_fixes_change_log
Map Suite Windows Phone Edition Features & Bug Fixes Change Log
Version 9.0.0.0
Release date: 06/24/2015
ThinkGeo.MapSuite.WindowsPhoneEdition Namespace:
  • Fixed a bug where the LayerOverlay has a big offset compared with BingMapsOverlay.
Version 7.0.17.0
Release date: 06/27/2013
  • Upgraded to WindowsPhone 8.0
  • Added the ClearCache method to MapPrinterLayer to delete the cache image
  • Added the spatial index status cache for MsSql2008FeatureSource
  • Added support of the FileGeoDatabase
  • Added support off write white paper on Printing
  • Added support of the GRD/GRI grid format
Version 6.0.0.0
Release date: 05/14/2012
Version 5.0.82.0
Beta Release date: 8/3/2011
Beta Release - No Changes
map_suite_windows_phone_edition_features_bug_fixes_change_log.txt · Last modified: 2015/09/11 03:48 by admin
