Sample:Labeling Based On Columns
This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like “[ColumnName1][ColumnName2]” and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.
For more information you can see the discussion forum post below: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6955/afv/topic/Default.aspx
