Need it in another language?
Video Overview
Notes from the developer:
Rotating the map:
Displaying the North Arrow:
On the web site
You can also check outPart 1 and Part 2 of the video which provides a brief summary of this sample.
From the Performance Guide:
Need it in another language?
This project is a follow up to the Discussion Forum post at here
In this project, we create a new Text Style combining word wrapping that we saw in the project
http://code.thinkgeo.com/projects/show/wordwrapped and text rotation. You can see the labels word wrapping and rotating in harmony with the resizing and rotating of the shapes.
