Map Suite Web for WebAPI allows you to easily build REST based web services to do the server side rendering, querying and geometric functions in your HTML5/Javascript application utilizing any JavaScript mapping client library (Leaflet, OpenLayers3 & KendoUI).
Browse the demo applications to see the power of Map Suite Web for WebAPI and how it can be utilized to build professional grade mapping applications using both the Leaflet and OpenLayers JavaScript mapping libraries.
Getting Started
Overlays
The Map Suite Web for WebAPI API documentation covers the ThinkGeo.MapSuite.WebApi namespace which resides in the ThinkGeo.MapSuite.WebApi.dll assembly. It contains all of the Map Suite Web for WebAPI specific classes such as the map control itself, Overlays, and supported map classes.
The Map Suite Web for WebAPI change log details the changes made to the product for each major release cycle.
Map Suite Web for WebAPI Sample App Walkthrough Video Series
Step through the Map Suite Web for WebAPI sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
Screen Shots of the Map Suite Web for WebAPI on different types of devices.
Traditional Browsers
Tablets
Phones
All the frequently asked questions about Map Suite Web for WebAPI.
All the frequently asked questions about Map Suite Web for License.
