Yes, absolutely. Map Suite Web Edition is an ASP.NET control, so you can easily integrate it into your application just like any other control from the Toolbox. We expose a large amount of APIs that allow you to customize every aspect of the map and the user interface so that they fit in with the look and feel of your application.
To work with Map Suite Web Edition, you will need a copy of Microsoft Visual Studio or Visual Studio Express to build the code for your custom application.
Does Map Suite Web Edition require any third party controls to be downloaded and installed on the client browser?
No. Map Suite Web Edition utilizes JavaScript to handle all browser-side operations, so no third party ActiveX controls are needed.
Map Suite Web Edition lets you use virtually any map dataset of your choosing. If you have your own map data, you can utilize it. Alternatively, you can utilize our Map Suite World Map Kit extension, Google Maps, Virtual Earth or Yahoo Maps — just to name a few options.
Map Suite Web Edition comes with native support for the most popular vector and raster file formats, and includes a free extension that enables support for more than a dozen more vector formats and more than 80 raster formats. If you have spatial data or imagery, chances are you can use it with Map Suite. Check our Developer Blog for the master list of data formats that Map Suite currently supports.
Map Suite Web Edition was designed to be easy to understand and easy to use. While mapping/GIS controls typically have a larger learning curve than other simpler controls like grids or charts, we feel Map Suite has taken the complexity out of mapping and allows you to develop your application in days or weeks instead of months or years.
We have a very active Developer Community discussion forum, a large number of “How Do I?” sample applications with complete source code, and we also offer professional services if you need to talk with a developer one-on-one.
What is the difference between Map Suite Web Edition and Map Suite Services Edition?
Map Suite Web Edition comes with built-in functionality to construct a robust user interface in a web environment, while the Services Edition is designed for back-end applications like web services, Windows services and console applications where no user interface elements are needed.
Yes. We offer a number of Map Suite add-ons that extend the functionality and map coverage of your application, including the World Map Kit dataset plugin, and the Routing Extension that generates routes, turn-by-turn directions and more. Additionally, check out the Map Suite Code Community for an ever-expanding number of add-on projects that bring new features and ideas to your Map Suite projects - there's something new each week.
You are seeing this message because the Production Web Server license is not installed on your server. There are two kinds of licenses for Map Suite Web Edition:
To install the Production Web Server License, you need to run the Map Suite Web Edition Server Preparation Tool that can be found in the My Downloads section of the Customer Portal. Easy-to-follow installation instructions are included with the tool.
Sample:Custom Map with Google Labels
Sample:Shapefile to Google Map
Sample:Great Circle with Google Map
Sample:Mini map with Google Map
Sample:Dynamic Info On TrackShapes
In this example, you will see displayed in a groupbox, properties such as perimeter and area as the shape is being tracked. In this project, you will learn how to handle events such as TrackStarted, MouseMoved and TrackEnded of TrackOverlay for that purpose. Getting dynamic info of a shape being tracked can be handy in situation where before committing to get the completed shape, you want to know more about the shape. For example, if you are tracking a search zone, you get dynamically info about its area. This project will be followed by other related projects. One will show how to create one’s own inherited TrackOverlay for having the possibility to abort tracking by pressing a key. Another project will show how to display dynamic info inside the shape itself instead of using a separate control.
Sample:Select with Track Shape
Sample:Labeling Based On Columns
This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like “[ColumnName1][ColumnName2]” and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.
For more information you can see the discussion forum post below: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6955/afv/topic/Default.aspx
We also added new designs of compass in smaller version. See the attached file: Rotating Compass New Smaller Designs.zip.
In our “How Do I” apps, there is sample app that shows how to add graphs to the map using the ZedGraph library. In this project, using the same data, the US cities, we elaborate a little bit on the pie chart. You will see how to add some gradient colors to the chart, how to label the different pie slices, how to add a title etc. Zedgraph is a truly massive library for graphics and Pie chart is only one type of chart among many others. As you can add pie charts to your map, you can also add bar charts, trend charts etc. I suggest you check out this site for more info on ZedGraph
http://zedgraph.org/wiki/index.php?title=Main_Page
With Map Suite, you have the whole ZedGraph API available with an easy interface to add the graphs to the map.
For this project, in addition to the MapSuiteCore.dll, you will also need the ZedGraph.dll and ZedGraphStyleExtension.dll references. We will have several projects showing how to integrate other types of charts to your map.
In this project, we create the class OledbPointFeatureSource inheriting from FeatureSource and OledbPointFeatureLayer inheriting from FeatureSource.
Displaying the North Arrow:
This sample shows you how to serialize objects in Map Suite to XML and then deserialze them back to objects. This is usefully in many GIS mapping application to save the state of styles, layers, projections or just about anything. The XML is readable and well formatted, great for working with in you GIS application.
This sample shows you how to generate source code calls from Map Suite objects. Imagine that you have a Layer that has been styled a particular way and uses a certain projection. Once the object is created you can pass it to the code generator and it will create source code to re-create the model passed in. This is very helpful especially in GIS applications where users define things through a custom UI but then want to leverage that in code.
Sample:Context Menu with Sub Menu
Based on a discussion forum request, today's web project shows you how to add sub menus to ContextMenu. This is a built-in function in all of the most recent daily builds of Map Suite, which you can download from the ThinkGeo Customer Portal. This project also demonstrates how to enable the ContextMenu's auto wrap feature when you click on the edges of the map.
Sample:Current Extent to Bitmap
Sample:Use Map with MVC Framework
The purpose of this project is to complete the section “Screen & World Coordinates” of the “How Do I?” sample apps. You will learn how to display world coordinates at the mouse event. Notice that the Layer is in Mercator projection and we use a projection conversion to display Longitude and Latitude in addition to the world coordinates values in meters from the Mercator projection. Also, we are reusing the DecimalDegrees static class we used in a previous project for formatting decimal degrees.
Sample:World Coordinate with Rotation
Sample:Geodetic to State Plane
Sample:Geodetic to UTM on the fly
The appropriate EPSG number for our example can be found at: http://spatialreference.org/
Sample:Routing with Projections
Sample:Great Circle on Pacific Rim
Sample:Polygon across Meridian
Following a request from the Discussion Forum on how to handle cases where the shape straddles the 180 degree meridian on a Decimal Degree map, we created this project. The solution is to split the shape into two main parts to be displayed on the two ends of the map. In this case, we use the case of a Polygon but this could easily be adapted for any other shapes such as lines.
Sample:Measurements Decimal Degrees
This project is in response to a Discussion Forum post that has generated plenty of debate on the meaning of measuring area for shapes in decimal degrees. In this project, you will see how to get area and length measurements according to the projection used from a shape in decimal degrees. For more information on why different measurements can be obtained from the same shapes, please read the Discussion Forum “GetArea on Buffered shape not working as expected” http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6565/afv/topic/Default.aspx
This project shows how to display the Pacific Rim and Asia if you pan to the west, so that the world “wraps around,” as it does with Google Maps. Many of our Map Suite sample applications include an example of the world being displayed using a world ShapeFile. The ShapeFile is in Decimal Degrees and it displays the world according to longitude and latitude value ranges. These ranges are from -180 to 180 for longitude and 90 to -90 for latitude. In our various examples that use this ShapeFile, you see the Western Hemisphere on the left and the Eastern Hemisphere on the right. Now, a common request that we receive is to display the Pacific Rim and Asia if you pan to the west, so that the world “wraps around,” as it does with Google Maps. This can be accomplished in Map Suite 3.x by using a custom projection that offsets all of the points by 360 for the x (longitude) values. (180 + 180 = 360). You will see how to create OffsetProjection class inheriting from Projection. Notice the code in the overrided method GetexternalProjection. It simply loops thru all the points making each feature and offset the X value by 360.
Sample:Custom Parameters Projection
Sample:Custom Rotation Projection
The purpose of this Wpf sample is to get familiar with the concept of datum and datum shift in UTM and Geographic coordinates. Using local data, you might be required to apply datum transformation to your data to go from an old datum to a more recent datum. Here we are taking the example of Australia which went to change its datum (from AGD84 to GDA94) for its mapping purposes. We show how to apply the datum transformation in both the longitude/latitude coordinate system and in the local UTM systems (AMG based on AGD84 and MGA based on GD94). See the code and read with attention the comments in the MouseMove event where all the projection logic is taken place. Notice that the correction is about 200 meters. Once you understand for the case of Australia, you will be able to apply the same principles for your own datums in UTM. For further reading: http://www.cage.curtin.edu.au/~will/datum.html http://www.usq.edu.au/course/material/SVY3107/lectures/Breeze/SVY2106amgmgafund/index.html
In today’s Wpf project, we are showing a trick for getting the current extent of the map with Google Map as an image and displaying it on a map in decimal degrees unit. You may be in a situation where you want the details and accuracy of Google Map, especially the satellite view but want to have it displayed on your map in decimal degrees. In this sample, you will see how to get the Google Map image and create the accompanying world file for decimal degrees. Notice that we are realizing an affine transformation on the image to go to Geodetic as illustrated in the case 3 http://en.wikipedia.org/wiki/World_file#Definition. You can also use this technique for any other background maps such as Bing Map, Open Street Map using Spherical Mercator. Warning: It is possible to use a world file with parameters for a Geodetic system from an image originally in Spherical Mercator due to some similar projection characteristics. Applying the same operation for other projections such as Lambert or UTM will not work.
Sample:Wrap Dateline Mode With Projection
Sample:Spherical Mercator Projection Adjustment
The purpose of this sample is to address a projection issue that you may encounter when converting your data from your local projection to Google Map. It has been reported by Map Suite users that in some cases reprojecting their data to Google Map or other base maps using Spherical Mercator (Bing Map, Open Street Map etc) is inaccurate with the data being shifted a few hundreds of meters. This problem has been identified as being caused by an unnecessary grid shift when going from ellipsoid datum to spherical datum. Among other projections, the British National Grid (BNG) and the German Gauss-Kruger system have that problem when going to Spherical Mercator. This sample uses the example of BNG to demonstrate the problem and how to fix it. The Map Suite development team will offer a permanent solution to this projection issue but in the meantime, as a rule of thumb, if your data shows some inaccuracies when going to Spherical Mercator, use the method you find this sample. This is a Desktop app but the concept shown applies to all editions of Map Suite.
Sample:Clipping On Point Layer
ConvexHull is a geometric function that returns the smallest ring containing all the points of a shape. Another way to think about it is to imagine a set of points on a plane as nails pounded into a board. If you wrap the entire set with a rubber band snapping it into place, it will form a convex hull, which is the minimum-energy wrapper that encloses all the points. This is the theory, now you may be wondering what the practical use of this is in GIS. In today’s project, we show how to contruct a convex hull polygon from a set of point in a concrete situation of oil rigs offshore. Creating a convex hull could be used to determine the perimeter for constructing a barrier around the oil rigs to help protect from hurricanes. It could also be used for a barrier to keep spilled oil contained within.
As for the projects “Spatial Join” and “Dissolve”, in this project we see how to edit FeatureLayers. In this case, we show some techniques to clean up a line based layer. You may be in a situation where you have to do that on a layer representing a network. Due to a poor digitizing, the end nodes of the lines don’t touch each other showing disconnected when in fact they should be connected. In this project, we show the technique to correct the location of the end vertices (nodes) so that they connect to each other. Keep in mind that the logic for correcting nodes shown here, is very simple and does not take into account various parameters such as tolerance, line order, multi line intersection etc. This logic works in the case of having an ordered sequential network as it is often digitized. The full logic taking into account all the different scenarios is vastly more complicated. We plan to offer this full logic in the future as an API within our core product. Also, notice that we create a custom LineStyle, NodeLineStyle for the purpose of showing the start and end nodes of each line as different color than the body of the line.
Sample:Create Polygon Programatically
In this small project, you will see the technique to dissolve a shapefile based on a common attribute using some key methods such as Union static method to efficiently union together a large number of shapes. You will also find useful the code for creating a shapefile from scratch. This project will soon be followed by another project on how to apply statistics when dissolving a shapefile. Also, there will be another related project on how to do Dissolve on a generic FeatureSource.
Sample:Dissolve with Statistics
This project shows how to perform a Spatial Join on a point Layer based on a Polygon layer. It adds the relevant info to the point layer based on the spatial characteristics of the features of the point layer in comparison to the polygon layer. For example, we have two layers. One is polygon layer of the countries; the other is point layer of the cities. We don’t have any attribute information about what country each city belongs to. We can perform a Spatial Join to add that info to the point layer. A Spatial Join looks at what country of the polygon layer, each city belongs to using a spatial query. Spatial Join requires handling various techniques such as creating, updating layer and spatial queries in one coherent function. In this project, you will also see the technique of displaying a label based on more then one columns. In this example, we show a Spatial Join based on containing rule. Other types of Spatial Joins can be performed based on proximity, or some other topological rules. Later, we will show other projects of Spatial Joins.
For more information, please see the discussion forum post below: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6963/afv/topic/Default.aspx
The key method used here is GetLineOnLine that offers many parameters to get a segment of an existing line. In our example, we get a line segment based on a distance from the start and the length. You can see how this could be applied for application such closing a segment of a highway after an accident for example. This project will be followed by other more advanced projects related to Dynamic Segmentation.
Sample:Get Feature Clicked On(Web)
Sample:Get Feature Clicked On(Web)2
In this sample, we show a geometric function that allows tying to the ground or registering shapes from some non geographic coordinate to the map (in world coordinates). To better understand how useful this can be for your mapping needs, imagine the following scenario: You have some geometric shapes in a CAD for chemical plume. In a CAD or specialized program generating chemical models, you can do all your scientific manipulation, transformation etc. Once you are finished generating the chemical models with your specialized program, you are ready to put it on the map. Using anchor points, one of origin and one of destination, you can tie to the ground the shapes with the help of the Register function. This operation cannot be confused with Projection. Projecting a shape means going from one geographic projection to another one, for example from Geodetic to Spherical Mercator and some deformation of the shape can occur. Registering is simply placing a shape from a non geographic coordinate to a specific location on the map.
Sample:Identify Point with Icon
Sample:Intersecting Multi Polygon
Sample:Intersecting Two Layers
Let say you have a layer of stratigraphy and a layer of counties and you need to do some analysis based on info from the county layer and info from the stratigraphy layer. You can combine the two layers by intersecting them and get only the common data of the two layers while adding the attributes of both original layers. The resulting layer has geographical extent that is common to both layers (as for clipping) while adding the information from both original layers. As for other geoprocessing techniques, writing the code for Intersecting requires combining layer editing with geometric functions.
From the previous project, on the geoprocessing technique of merging point layers, here we show the same technique applied to line layers. Remember that an alternative approach to merging is to use a multi index and treating all the various files as one layer. You can see this Discussion Forum post for more info on that: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5921/afv/topic/Default.aspx
An alternative approach to merging is to use a multi index and treating all the various files as one layer. You can see this Discussion Forum post for more info on that: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5921/afv/topic/Default.aspx Next we will show how to do the same thing for line layers.
If you have many files of the same type and representing the same type of features, Map Suite offers an API for building a multi index and treating all the various files as one layer. You can see this Discussion Forum post for more info on that: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5921/afv/topic/Default.aspx
While this is very convenient, you may still want to combine all your files into one for maintenance purpose. This project shows the geoprocessing technique of accomplishing that task with merging. The logic for writing the merging algorithm is simpler than other geoprocessing tasks since no geometric functions are involved. Keep in mind that this project shows how to merge polygon based shapefiles into one. In the future, we will post a more generic project for layer of various format and type.
Sample:Offset Point at Right Angle
Sample:Polygon Shapes To Multipolygon Shapes
This project is a follow up to the Discussion Forum post http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6652/afv/topic/Default.aspx Rotating the feature text (similar to wordwrap). In this project, we create a new Text Style combining word wrapping that we saw in the project http://code.thinkgeo.com/projects/show/wordwrapped and text rotation. You can see the labels word wrapping and rotating in harmony with the resizing and rotating of the shapes.
Sample: Callback for Fleet Tracker
Sample:Centering And Rotating WPF
In this project, we show how simple it is to display and do spatial analysis with chemical plumes. The US department of transportation sets standards for protection and isolation zones according to the type of chemical involved. You can find all that publicly available information at http://www.phmsa.dot.gov/
In this sample we are going to handle the common case of snapping a point to a set of features in a layer. The common case for this is snapping real-time GPS points to road layers. GPS has an error factor and it's nice to display vehicles on a map snapped to the roads they are on. It can also be used for a number of other different cases as well, such as finding not just the road position but the road name. You may display or store the road name for the trip in your database. In the sample we have set up a road layer; when you click on the map it will find the closest road segment within a tolerance and snap the point to that road. You can click repeatedly around a road and simulate GPS points coming in. Inside of the sample, we have encapsulated the functionality into a method that can easily support multiple layers, varying tolerances, and different data units.
NOAA (National Oceanic and Atmospheric Administration) makes available for the public Radar images http://radar.weather.gov/ridge/Conus/RadarImg/ Those images show the precipitation activities based on the whole range of dBz scale. (see http://en.wikipedia.org/wiki/DBZ_%28meteorology%29) You might want to keep only dBz scales superior to 20 which correspond to actual rain. You might also want to add some transparency to better show the layers below the radar image. This project shows how to filter the image for that purpose. You will see how to create a new filtered image better fit to be displayed on the map. You will find particularly interesting the power of using directly the GDI+ API which is very handy with dealing with a Map Suite GDIPlusRasterLayer.
Sample:Moving Vehicle with Label
Sample:Moving Features with Ajax
Sample:Center Map Based On Lat/Long
Today we have the first project in the Map Suite WPF Desktop version. This is a simple project that shows how to set the current extent based on a collection of layers. You can use this technique for the common task of having the map set to the full extent. Instead of having to manually set the full extent, you can pass all the layers you want the full extent to be based on. This project will be followed by many other WPF projects due to the increasing popularity of that Map Suite version.
Sample:Zoom Levels Partitioning
Map Suite API conveniently offers 20 predefined zoom levels to set the different styles. With those 20 predefined zoom levels, at any change of extent, the map will snap to the nearest zoom level. While this is appropriate in most cases, you may want a more granular control on the zoom levels. This project shows how to set intermediate zoom levels between the existing predefined ones for more granularity. Since the zoom levels are based on scales, you can still use the predefined zoom levels to set the styles and have the additional custom zoom levels for more refined control on zoom level snapping. In this project, we have the WorldMapKit WMS as a layer and a regular point based shapefile. You can see how the intermediate custom zoom levels have the effect of stretching the WMS image to better fit. This is a Desktop project and you will need the full or evaluation references to MapSuiteCore.dll, DesktopEdition.dll and WorldMapKitWms.dll.
This project is for DesktopEdition users. As for the project TrackZoomInWithoutShiftKey, we show how to create a new class from InteractiveOverlay. InteractiveOverlay is a powerful way to interact with the map but it currently lacks documentation. While this project does not substitute a good documentation, it shows some techniques for using that class. You can take a look at the overriding method MouseDownCore to see how in a few lines of code, you can allow the users to have the map zoomed in and centered to the location the map was clicked on. In the next major public release of Desktop Map Suite, we will present a more complete documentation on InteractiveOverlay.
This web-based project demonstrates how to customize the ZoomLevels of your Map Suite Web Edition map. There are 20 default ZoomLevels, but sometimes they don’t fit your requirements. In that case, you can specify your own scale which corresponds to a certain ZoomLevel. It’s easy to do and requires just a few lines of code.
Sample:Raster Layer with extent
