map_suite_web_edition_zooming_panning_moving_samples
Map Suite Web Edition Zooming Panning Moving Samples
Center Map Based On Lat/Long
Centering Map with Tolerance
Customize ZoomLevels
This web-based project demonstrates how to customize the ZoomLevels of your Map Suite Web Edition map. There are 20 default ZoomLevels, but sometimes they don’t fit your requirements. In that case, you can specify your own scale which corresponds to a certain ZoomLevel. It’s easy to do and requires just a few lines of code.
GetZoomLevel
Map Scales
Moving Features with Ajax
Raster Layer with extent
Restricting Extent
Zoom In To Feature
Zoom In To Point
Zoom Levels Partitioning
Zoom to Full extent
Centering and Rotating
Custom Zoom Levels
Zoom to Full extent
Map Suite License File Generator
map_suite_web_edition_zooming_panning_moving_samples.txt · Last modified: 2015/10/10 07:31 (external edit)
