map_suite_spatial_data_extension
Map Suite Spatial Data Extension
The Map Suite Spatial Data Extension is an add-on for Map Suite Desktop, Web, Silverlight and Services Editions that enables reading of spatial data from ArcSDE 9.3. Now you can use the familiar tools of Map Suite to render ArcSDE data just like you would ShapeFiles, Oracle Spatial or other supported formats.
Product Guides
Guides Description
Quick Start Guide This guide helps you get you up to speed with integrating the Spatial Data Extension into your GIS software.
Installation Guide This guide walks you through installing the Spatial Data Extension on your system.
Deployment Guide This guide walks you through deploying your GIS software using the Spatial Data Extension into a production environment.
Frequently Asked Questions
Category Description
General Questions These frequently asked questions cover GIS and Map Suite Spatial Data Extension topics that are not categorized in other areas.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_spatial_data_extension.txt · Last modified: 2015/09/18 09:02 by admin
