map_suite_services_edition_labeling_samples
Map Suite Services Edition Labeling Samples ====== Decimal Degrees Formatting
=78|Sample ^ width=66|Product ^ Description ^
map_suite_services_edition_sample_decimal_degrees_formatting.jpg View Source
C# Download
Need it in another language?
Services \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ The purpose of this project is to complete the static class DecimalDegreesHelper. This class offers functions to go to and from Decimal Degrees but it lacks the functions handling various formats such as Degrees Decimal Minutes and Degrees Minutes Decimal Seconds. Those formats can be output by different GPS devices and it is handy to know how to manipulate them and convert them to Decimal Degrees, the only format that can be input into a GIS or Mapping application.
Label to Show Location
Applies To: Desktop \ Web \ Silverlight \ Services \ Wpf \
Labeling Based On Columns
codesamples
Multi Column Labeling
map_suite_services_edition_labeling_samples.1441619917.txt.gz · Last modified: 2015/09/07 09:58 by admin
