map_suite_server_routing
Map Suite Routing
Let your mapping applications start taking you places! Map Suite Routing is an extension for Map Suite Desktop, Web, or Services that calculates routes and driving directions. This native .NET component gives your Map Suite applications the power to find the shortest path from A to B, deliver turn-by-turn directions, avoid specified areas, and much more.
Product Guides
This guide helps you get you up to speed with integrating the Routing map control into your GIS software.
This guide walks you through installing the map control on your system and creating a simple GIS application.
This guide walks you through deploying your GIS software using the map control into a production environment.
This guide introduces the dependencies Map Suite Routing needs with their features, versions and source websites.
API Documentation
  • ThinkGeo.MapSuite.Routing
    The Map Suite Routing API documentation covers the ThinkGeo.MapSuite.Routing namespace which resides in the ThinkGeo.MapSuite.Routing.dll assembly. It contains all of the Map Suite Routing specific classes such as the map control itself, Overlays, and supported map classes.
Package
Description This is an extension for use in ThinkGeo's Map Suite product line, see below, as it cannot be used stand alone.
Supported Platforms: Windows, Linux, MacOS
Compatible Products
  • Map Suite Desktop for WPF
  • Map Suite Desktop for WinForms
  • Map Suite Web for WebForms
  • Map Suite Web for Mvc
  • Map Suite World Streets
Code Samples
In addition to the samples below, we have dozens of interactive Map Suite Routing sample applications available here.
We have provided several .Net code samples in C# & VB.NET to help you get going quickly. We have categorized them to allow you to quickly find what you are looking for. Each code sample includes an overview, complete code online to review and the ability to download the sample to run it yourself.
All Samples
All samples about Map Suite Routing.
Project Templates
These projects show various study cases based on Routing.
Layers & FeatureSources
Miscellaneous
Styles
Videos
Map Suite Routing Sample App Walkthrough Video Series
Step through the Map Suite Routing sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
Introduction to the Map Suite Routing
Screenshots
The Routing Extension screenshots gallery section showcases a wide range of screenshots covering various GIS features.
Shortest length or fastest time
Just a few lines of code
Shortest length or fastest time Just a few lines of code
Road type
Road length
Start/end point
Road type Road length Start/end point
Draw your own areas
Routes adjust automatically
Draw your own areas Routes adjust automatically
Turn-by-turn
By intersection
Turn-by-turn By intersection
Add a stop with a single click
Unlimited stops
Add a stop with a single click Unlimited stops
Intelligently find the most efficient route around point-based roadblocks
Based on average speed and drive time
Generate an optimal route for visiting a set of locations
Easy to see and learn
Source code available for every sample
Easy to see and learn Source code available for every sample
Change Logs
  • API Change Log
Frequently Asked Questions
  • All Questions
    All the frequently asked questions about Map Suite Routing.
  • General Questions
    These frequently asked questions cover GIS and map control topics that are not categorized in other areas.
  • Layers & FeatureSources
    These frequently asked questions cover.
  • Styles
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_server_routing.1487827803.txt.gz · Last modified: 2017/02/23 05:30 by marklee
