map_suite_predefined_styles
Map Suite Predefined Style Guide
Overview
MapSuite contains many predefined styles, including the WorldMapKit Predifined Styles outlined below.
Code
This code snippet will retrieve all of the AreaStyles returned by the methods in the WorldMapKitAreaStyles class using Reflection, and saves them as images.
          MethodInfo[] methodInfos = typeof(WorldMapKitAreaStyles).GetMethods(BindingFlags.Public | BindingFlags.Static);
          PropertyInfo[] propertyInfos;
          propertyInfos = typeof(WorldMapKitAreaStyles).GetProperties(BindingFlags.Public |
          AreaStyle areaStyle;
          foreach (MethodInfo methodInfo in methodInfos)
              ParameterInfo[] parameterInfos = methodInfo.GetParameters();
              if (parameterInfos.Length > 1)
                  int parmLength = parameterInfos.Length;
              List<object> parmList = new List<object>();
              foreach (ParameterInfo parameterInfo in parameterInfos)
                  if (parameterInfo.ParameterType == typeof(Single) || parameterInfo.ParameterType == typeof(int) || parameterInfo.ParameterType == typeof(float))
                      parmList.Add(25);
                  else if (parameterInfo.ParameterType == typeof(String))
                      parmList.Add("Test");
              object[] parms = new object[] { };
              if (parmList.Count > 0)
                  parms = parmList.ToArray();
              areaStyle = (AreaStyle)methodInfo.Invoke(null, parms);
              Bitmap bitmap = new Bitmap(128, 128);
              GdiPlusGeoCanvas gdiPlusGeoCanvas = new GdiPlusGeoCanvas();
              gdiPlusGeoCanvas.BeginDrawing(bitmap, new RectangleShape(-180, 90, 180, -90), GeographyUnit.DecimalDegree);
              areaStyle.DrawSample(gdiPlusGeoCanvas);
              gdiPlusGeoCanvas.EndDrawing();
              bitmap.Save(@"c:\temp\AreaStyles\" + methodInfo.Name + ".png", ImageFormat.Png);
WorldMapKitLineStyles
The previous code can modified to produce these images, by changing WorldMapKitAreaStyles to WorldMapKitLineStyles, and AreaStyle to LineStyle.
WorldMapKitTextStyles
And by changing WorldMapKitAreaStyles to WorldMapKitTextStyles and AreaStyle to TextStyle, you can produce the images below.
map_suite_predefined_styles.1479330703.txt.gz · Last modified: 2016/11/16 21:11 by tomtaylor
