The Map Suite iOS QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. The QuickStart Guide supports iOS 10.0.0.0 and higher and will show you how to create an iOS application.
This sample shows how to use Sqlite database with Map Suite Mobile. Check out the code and see how simple it is to use Map Suite!
This sample passed on Linux. Using mono runtime, it is required to replace the ThinkGeo.MapSuite.Layers.SqliteForLinux with ThinkGeo.MapSuite.Layers.SqliteForMono package.
Please refer to Wiki([WinForms](http://wiki.thinkgeo.com/wiki/map_suite_desktop_for_winforms), [Android](http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_android), [iOS](http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_iOS)) for the details.
This sample demonstrates how you can draw the map with Vector Tiles requested from ThinkGeo Cloud Services in your Map Suite GIS applications, with any style you want from [StyleJSON (Mapping Definition Grammar)](https://wiki.thinkgeo.com/wiki/thinkgeo_stylejson). It will show you how to use the XyzFileBitmapTileCache and XyzFileVectorTileCache to improve the performance of map rendering. It supports have 3 built-in default map styles and more awasome styles from StyleJSON file you passed in, by 'Custom': - Light - Dark - TransparentBackground - Custom
Please refer to [Wiki](https://wiki.thinkgeo.com/wiki/map_suite_mobile_for_ios) for the details.
This project shows to create a simulated 3D buildings with iOS map control and shapefile.
This samples shows you how to get started building your first application with the Map Suite iOS Edition.
This samples shows you how to explore all the different Geometric Functions API's .
[Sample Data Download](http://wiki.thinkgeo.com/wiki/_media/routing/routing_howdoi_samples_data.zip)
The Map Suite Routing “How Do I?” solution offers a series of useful how-to examples for using the Map Suite Routing extension. The bundled solution comes with a small set of routable street data from Dallas, TX and demonstrates simple routing, avoiding specific areas, getting turn-by-turn directions, optimizing for the Traveling Salesman Problem, and much more. Full source code is included in both C# and VB.NET languages; simply select your preferred language to download the associated solution.
Please refer to [Wiki](http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_iOS) for the details.
This samples shows you how to explore the different styles available to help you analyze and visualize your data.
This samples shows you how to implement drawing and editing shapes into your web application.
This samples shows you how to examine different labeling techniques to make your maps informative.
This sample shows you how to get started building your first application with the Map Suite Mobile for iOS 10.0.0.
The “How Do I?” samples collection is a comprehensive set containing dozens of interactive samples.
This sample demonstrates how you can read data from an DEM file in your Map Suite GIS applications, and how to render it with DEM embedded value style as well as a customized style. This DEM File support would work in all of the Map Suite controls such as Wpf, Web, Android and iOS.
This Sample demonstrates how you can use ThinkGeo Cloud Client to get meaningful addresses from ThinkGeo GIS Server by a geographic location. It ships with an optimized set of worldwide coverage of cities and towns, but any customized data can be supported as well.
ThinkGeo Cloud Client support would work in all of the Map Suite controls such as Wpf, Web, MVC, WebApi, Android and iOS.
This Sample demonstrates how you can use ThinkGeo Cloud Client to get a geographic location from ThinkGeo GIS Server by a street address.
There are two ways to get the elevation data of the line. First, get the points on the line by setting the interval distance. The other, is to take the points by setting the number of points to be fetched. Then query the elevation data of the point.
