The page was created before Map Suite 10. Map Suite 10.0 organized many classes into new namespaces and assemblies as well as had a few minor breaks in compatibility. The majority of previously built code should work without modification assuming the new namespaces are added. For guidance on upgrading your existing code check out this(http://wiki.thinkgeo.com/wiki/map_suite_10_upgrade_guide).
The ThinkGeo Wiki is the central and official source of documentation, sample code and learning material for Map Suite users. It contains resources such as API reference, QuickStart Guides to get you started, sample projects with source code you can learn from, change logs for each version, and more.
The wiki's resources are categorized by product, so you can easily find the information you need for the Map Suite edition you're working with.
For Mobile Platforms
For Windows Desktop Platforms
For Web Platforms
Build REST based webservices for your JavaScript/HTML5 Web applications
For Other Platforms
Customizable Web-Based GPS Tracking Platform
