Map Suite VectorMap.js is an extension of OpenLayers used to create vector maps for web and mobile devices. It's an open-source on ThinkGeo Github. Map Suite VectorMap.js simplifies the process of creating the vector maps within OpenLayers and optimizes the performance in some aspects.
Map Suite VectorMap.js provides two ways to pass your authentication credentials for access to vector tile services.
Define your "API Key" in your layer:
var layer = new ol.mapsuite.WorldStreetsVectorTileLayer("streets.json",
apiKey:"API Key"
Define your "Client Id" and "Client Secret" in your layer:
clientId:"Client Id",
clientSecret:"Client Secret"
NOTE: Please refer to [[thinkgeo_cloud_client_keys_guideline|Cloud Keys Guidline]] on how to create your own credentials from ThinkGeo and consume services provided by ThinkGeo.
ol.Map in OpenLayers is borrowed by "Map Suite VectorMap.js" to create the map instance.
ol.mapsuite.VectorTileLayer extends OpenLayers class ol.layer.VectorTile with additional options.
var vectorTileLayer= new ol.mapsuite.VectorTileLayer(styleJson,
apiKey:"API Key",
multithread:false,
declutter:true
new ol.mapsuite.VectorTileLayer("styleJson file", options)
The vector StyleJson object in JSON format or the vector styleJson file url, containing the definition of data sources, vector layers and styles used in the vector layers. For ol.mapsuite.VectorTile, the source in StyleJson object only receives tiles with vector features in ".MVT" format.
| Name | Type | A string value will be attached to each tile request URL as a querystring configuration called "apiKey" for credential authentication on service.Needed when clientId or clientSecret are undefined |
| multithread | boolean | A boolean value indicating whether or not using multi-thread to read and draw features. Basically, single-thread will have a better user-experience and higher performance, but doesn't support query feature details based on coordinate. Default is true. |
| declutter | boolean | A bool value indicating whether drawing duplicated labels.Default is true. |
| proxy | url | the url of a proxy srever |
| clientId | string | A string to access server data with clientSecret. Needed when apiKey is undefined, but not recommended. |
| clientSecret | string | A string to access server data with clientId. Needed when apiKey is undefined, but not recommended. |
Return the associated VectorTileSource of the layer.
ol.mapsuite.VectorTileSource extends OpenLayers class ol.source.VectorTile with all options inherited.
Triggered before sending a tile XmlHttpRequest.
ol.mapsuite.WorldStreetsVectorTileLayer extends ol.mapsuite.VectorTileLayer class with ThinkGeo World Streets Vector Tile Service highly integrated.
var vectorTileLayer= new ol.mapsuite.WorldStreetsVectorTileLayer(styleJson,
multithread:true,
declutter:true
