thinkgeo_cloud_quick_start_guide
Getting Started with the ThinkGeo Cloud
ThinkGeo Cloud offers a cloud-hosted suite of APIs that allow you to easily consume map tiles, geocode and reverse geocode, perform spatial operations and other GIS services. Whether you're just evaluating the Thinkgeo Cloud or you're a subscriber, this quick start guide will help you start consuming these services in your own applications.
Logging In
You can login to the ThinkGeo Cloud with your ThinkGeo account, the same one you can use to access our community forums. If you don't have a ThinkGeo account yet, sign up for one here.
Then, visit the ThinkGeo Cloud web console login page at https://cloud.thinkgeo.com/login.html and click the “Login with ThinkGeo Account” button.
The Dashboard
Once logged in, you'll be at the Dashboard page of the ThinkGeo Cloud web console. The Dashboard offers a quick look at the activity of your ThinkGeo Cloud clients over the past 24 hours. If you're a new user, you won't see any activity here.
You’ll want to start your experience by creating a *client* within ThinkGeo Cloud. A client is how you can enable your application or website to use ThinkGeo Cloud resources on your behalf. There are two types of clients for different kinds of applications, and each has its own ID and secret key. You can have as many clients in your account as you like.
To manage your clients, begin by clicking on the “Clients” button on the menu bar.
Managing Your Clients
New ThinkGeo Cloud accounts come with two clients, one of each type, that you can use to quickly get started.
  • NativeConfidential clients have full access to all the APIs you do, including those which manage clients and your user profile. They will authenticate by exchanging their ID and secret key for an identity token. Then, they will use that token to make requests to the ThinkGeo Cloud APIs. These clients are called “NativeConfidential” because their secret key must be kept confidential, and thus they are only suitable for use in native compiled applications or web services where the secret can be kept confidential, out of the hands of users.
  • JavaScript clients are intended to be used in web applications. They are simpler to use but can only access ThinkGeo Cloud plugins like elevation or the reverse geocoder. To use a JavaScript client, you only need to include the client ID in the URL of the API you are requesting – no tokens are required. A JavaScript client's ID does not need to be kept confidential, but you should restrict the client so that it can only be used from web domains you control.
For now, let's use one of the default clients that come with your ThinkGeo Cloud account. For this exercise, we'll choose the Native Confidential client called “Sample Native Client”.
To use this client, you'll need its ID (or API Key) and secret. These can be displayed if you click on the green Show Keys button. The “Client Details” dialog will appear, showing you both the API Key and API Secret as follows:
You can use the “Copy” button to copy these values to your clipboard.
Exploring the ThinkGeo Cloud APIs
The ThinkGeo Cloud offers a built-in way for you to explore the available APIs. To use it, click on the “API Reference” menu button. This will open a new browser tab to the ThinkGeo Cloud API Explorer.
On this page, you can use the API Key and API Secret from your Sample Native Client to authenticate, and then experiment with the available APIs.
To do so, click the “Authorize” button:
On this dialog, in the Client Credentials (OAuth2, application) section, do the following:
  1. Paste your client's API Key into the “client_id” box.
  2. Paste your client's API Secret into the “client_secret” box.
  3. Click the Authorize button.
After successfully authenticating, you can close the dialog box.
You can now experiment with the following APIs be expanding the corresponding sections and clicking the “Try it out” button:
  • Elevation - A service that can find the elevation or grade of a point, line or area.
  • ReverseGeocoding - Find the nearest points of interest, addresses, or intersections to a specified coordinate.
  • MapsRaster - Tiled aerial imagery of the world.
  • MapsVector - Tiled maps of the world in lightweight, high-performance vector format.
Additionally, your Sample Native Client gives you access to a select few additional APIs that can be used to query or manage your account information, including:
  • Accounts
    • Get current account
    • Update current account
  • Clients
    • Create a new client
    • Delete client(s)
    • Get granted roles for a client
    • Get a specific client
    • Get a list of your clients
    • Update an existing client
  • Statistics
    • Get API usage statistics for your account (24 hour history)
thinkgeo_cloud_quick_start_guide.1544116644.txt.gz · Last modified: 2018/12/06 17:17 by edgar
