thinkgeo_cloud_maps_wms
ThinkGeo Cloud Maps Wms
ThinkGeo Cloud Maps Wms serves tiles follow Wms standard.
RESTful APIs
ThinkGeo Cloud Geocoding provides the following Restful API:
<!-- Consume the map tiles via Wms -->
HTTP GET
https://cloud.thinkgeo.com/api/v1/maps/wms
  • Request: Requried. The type of the request. Acceptable values are “GetMap”, “GetCapabilities”.
  • Service: Requried. The service name. Must be “WMS”. Default value: WMS
  • Version: Requried. The version of the WMS. Now, it supports “1.1.1” and “1.3.0”. Default value: 1.1.1
  • Layers: Required for “GetMap”. The layers of the requested image. Use “,” as the separator for the multiply layers.
  • Styles: Required for “GetMap”. The styles of the requested image. Use “,” as the separator for the multiply styles.
  • Format: Required for “GetMap”. The format of the requested image.
  • Width: Required for “GetMap”. The width of reqeusted image in pixels. Default value: 512
  • Height: Required for “GetMap”. The height of the requested image in pixels. Default value: 512
  • Srs: Required for “GetMap”. The coordinate refrenence system in which the BBox is specified. It is used in version “1.1.1”. Default value: EPSG:3857
  • Crs: Required for “GetMap”. The coordinate refrenence system in which the BBox is specified. It is used in version “1.3.0”.
  • BBox: Required for “GetMap”. The bounding box of the requested image. The valid format is “minX,minY,maxX,maxY”.
  • Exceptions: The output format of the exception.
  • Transparent: Indicates whether the requested image should have an alpha channel.
  • Hit Try it Out button below GetWmsMap to test it online.
thinkgeo_cloud_maps_wms.1550207063.txt.gz · Last modified: 2019/02/15 05:04 by tgwikiupdate
