thinkgeo_cloud_javascript_sdk_quick_start_guide
ThinkGeo Cloud JavaScript SDK Quick Start Guide
Create a basic web application with CloudClient.js
In this walkthrough, you will learn how to create a basic web application with CloudClient.js. You should have some familiarity with HTML/CSS and JavaScript, but the source code is provided. Any operating system or text editor will work, but you will need an internet connection while you are working (Take GeoCoding Service as example).
Step 1: Create an API Key
CloudClient.js requires an API key for access to ThinkGeo Cloud services, it can be created following the “Client Keys Guide”. For help, see the API Reference.
Step 2: Create an index page
To get started making your application with Cloud Service, you need to use a text editor to update the HTML.
  • Start your text editor with a blank document “index.html” and copy and paste the following HTML.
     <!DOCTYPE html>
     <html>
       <head>
         <meta charset="utf-8">
       </head>
       <body>
       </body>
     </html>
  • In the <head> tag, add a title, such as <title>My Cloud Service Sample</title>.
  • In the <body> tag, add a DIV to show the response from Cloud Services.
After all the above, the HTML document should look as below:
   <code javascript>
   <!DOCTYPE html>
   <html>
     <head>
     </head>
     <body>
       <div id="response"></div>
     </body>
   </html>
   </code>
Step 3: Add references JavaScript files
To get started using CloudClient.js, you need to link to the JS files in the '' section. Both NPM or CDN provides the minified version, which is a compressed file that improves performance.
CDN
Load from CDN in your project:
<!-- latest minified version of thinkgeocloudclient.js -->
<script src="https://cdn.thinkgeo.com/cloudclient-js/1.0.0/thinkgeocloudclient.js"></script>
NPM
  • Install the package:
    npm i thinkgeocloudclient-js
  • Include it to your page:
    <script src="path/to/dist/thinkgeocloudclient.js"></script>
Step 4: At the bottom of your page, add a JavaScript section to consume the services.
    let reverseGeocodingClient = new tg.ReverseGeocodingClient('Your-Cloud-Service-Api-Key');
    // Find the ThinkGeo office address by coordinate
    reverseGeocodingClient.searchPlaceByPoint(33.128367, -96.809847, function (status, response) {
       if (response.data.bestMatchLocation) {
          let address = response.data.bestMatchLocation.data.address;
          document.getElementById('response').innerHTML = address;
More Client Class
After include ThinkGeoCloudClient.js, you can find there is a namespace tg short for ThinkGeo. Currently, there are 6 Client Classes in tg:
ClassDescription
tg.ElevationClientA class provides the methods to access the Elevation APIs.
tg.MapsClientA class provides the methods to access the Maps APIs.
tg.ProjectionClientA class that provides the methods to access the GIS Server Projection APIs.
tg.GeocodingClientA class provides the methods to access the Geocoding APIs.
tg.ReverseGeocodingClientA class provides the methods to access the ReverseGeocoding APIs.
tg.RoutingClientA class provides the methods to access the Routing APIs.
tg.ColorClientA class provides the methods to access the ColorUtilities APIs.
Here is an online sample.
thinkgeo_cloud_javascript_sdk_quick_start_guide.txt · Last modified: 2019/07/02 06:59 by kevinwan
