tg is the abbreviation of ThinkGeo, the namespace of ThinkGeoCloudClient-js
A class provides the methods to access the ColorUtilities APIs. Generats an diversified family of colors by an input color or a random base color.
Syntax
var colorClient = new tg.ColorClient('Your-Cloud-Service-Api-Key');
Name | Type | Description |
apiKey | string | An API key for access to ThinkGeo Cloud services, it can be created following the guide |
a color object to access the ColorUtilities APIs in ThinkGeo Cloud service.
colorClient.getColorsInAnalogousFamily(options, callback)
Get a family of colors based on three analogous hues.
Syntax
var options = { numberOfColors: 25 }; var callback = function (status, response) { console.log(response); }; colorClient.getColorsInAnalogousFamily(options, callback);
Name | Type | Description | ||
options | Options | |||
Name | Type | Default | Description | |
numberOfColors | integer | A number of output colors desired. The value must be between 3 and 54. | ||
color | string | A base color. Two analogous hues will be found for you. If null, use random color. | ||
outFormat | string | Hex | The format in which you want the output colors. Supported formats: Hex, RGB, HSL. | |
inFormat | string | Hex/RGB | The format of the input Color. Supported formats: Hex, RGB, HSL. If not specified, we will try to parse the inputColor as Hex first, then RGB. | |
callback | function | the callback for response |
colorClient.getColorsInComplementaryFamily(options, callback)
Get a family of colors based on two complementary hues.
Syntax
var options = { numberOfColors: 25 }; var callback = function (status, response) { console.log(response); }; colorClient.getColorsInComplementaryFamily(options, callback);
numberOfColors | integer | The total number of colors you want to be returned. The value must be between 2 and 36. | ||
color | string | A base color. A complementary hue will be found for you. | ||
inFormat | string | Hex/RGB | The format of the input Color. Supported formats: Hex, RGB, HSL. If not specified, we will try to parse the input Color as Hex first, then RGB. | |
colorClient.getColorsInContrastingFamily(options, callback)
Get a family of colors based on two contrasting hues.
Syntax
var options = { numberOfColors: 25 }; var callback = function (status, response) { console.log(response); }; colorClient.getColorsInContrastingFamily(options, callback);
color | string | A base color. A contrasting hue will be found for you. | ||
colorClient.getColorsInHueFamily(options, callback)
Get a family of colors with the same hue and sequential variances in lightness and saturation.
Syntax
var options = { numberOfColors: 25 }; var callback = function (status, response) { console.log(response); }; colorClient.getColorsInHueFamily(options, callback);
numberOfColors | integer | The total number of colors you want to be returned. The value must be between 1 and 255. | ||
colorClient.getColorsInQualityFamily(options, callback)
Get a family of colors with qualitative variances in hue, but similar lightness and saturation.
Syntax
var options = { numberOfColors: 25 }; var callback = function (status, response) { console.log(response); }; colorClient.getColorsInQualityFamily(options, callback);
color | string | The color on which you want to base the color collection. | ||
colorClient.getColorsInTetradFamily(options, callback)
Get a family of colors based on a harmonious tetrad of hues.
Syntax
var options = { numberOfColors: 25 }; var callback = function (status, response) { console.log(response); }; colorClient.getColorsInTetradFamily(options, callback);
numberOfColors | integer | The total number of colors you want returned. The value must be between 4 and 72. | ||
color | string | A base color. Three harmonious hues will be found for you to create a tetrad. | ||
inFormat | string | Hex/RGB | The format of the inputColor. Supported formats: Hex, RGB, HSL. f unspecified, we will try to parse the inputColor as Hex first, then RGB. | |
colorClient.getColorsInTriadFamily(options, callback)
Get a family of colors based on a harmonious triad of hues.
Syntax
numberOfColors | integer | The number of colors you want returned. The value must be between 3 and 54.v | ||
color | string | The color on which you want to base the colors collections. | ||
A class provides the methods to access the Elevation APIs. Get the elevation of a geometry, include point, line, polygon.
Syntax
var elevationClient = new tg.ElevationClient('Your-Cloud-Service-Api-Key');
a elevation object to access the Elevation APIs in ThinkGeo Cloud service.
elevationClient.getElevationOfPoint(options, callback)
Get the elevation of a point.
Syntax
var options = { pointY: 33.128367, pointX:-96.809847, srid: 4326, elevationUnit:'Feet' }; var callback = function (status, response) { console.log(response); }; elevationClient.getElevationOfPoint(options, callback);
pointY | number | The Y coordinate of the point. | ||
pointX | number | The X coordinate of the point. | ||
srid | integer | 4326 | The SRID (coordinate system) of the input Point. | |
proj4String | string | The Proj4 (coordinate system) of the input Point. | ||
elevationUnit | string | “Feet” | The unit of measure in which the elevation result is expressed. | |
elevationClient.getElevationOfPoints(options, callback)
Get the elevations of all the points in a collection (up to 1,000 points maximum).
Syntax
var options = { body:[ { "coord":"33.128367,-96.809847", "srid":4326, "elevationUnit":"Meter" } ] srid: 4326, elevationUnit:'Meter' }; var callback = function (status, response) { console.log(response); }; elevationClient.getElevationOfPoints(options, callback);
body | array | A collection of point in JSON, the srid, proj4String and elevationUnit can be individually specified for each point. | ||
srid | integer | 4326 | The common SRID (coordinate system) for points which hasn't been specified. | |
proj4String | string | The common Proj4 (coordinate system) for points which hasn't been specified. | ||
elevationClient.getElevationOfLine(options, callback)
Get the elevation of points along a line.
Syntax
var options = { wkt: 'LINESTRING(-10717751.685805485 3864388.620499513,-10717359.946035523 3864570.1584416907)', srid: 3857, numberOfSegments:5, elevationUnit:'Meter', }; var callback = function (status, response) { console.log(response); }; elevationClient.getElevationOfPoints(options, callback);
wkt | string | The Well Known Text (WKT) of a line feature to get the elevation. | ||
srid | integer | 4326 | The SRID (coordinate system) of the input line. | |
proj4String | string | The Proj4String (coordinate system) of the input line. | ||
numberOfSegments | integer | Splits the requested line into this many segments, then calculates elevation of each point joining the segments. | ||
IntervalDistance | integer | Splits the requested line into intervals of this length. The unit of measure for this distance is specified by the IntervalDistanceUnit parameter. | ||
IntervalDistanceUnit | string | “Feet” | The unit of measure in which the IntervalDistance is expressed. | |
elevationClient.getGradeOfLine(options, callback)
Get the grade (slope) of a line, optionally split into segments.
Syntax
var options = { wkt: 'LINESTRING(-10717751.685805485 3864388.620499513,-10717359.946035523 3864570.1584416907)', srid: 3857, numberOfSegments:5, elevationUnit:'Meter', }; var callback = function (status, response) { console.log(response); }; elevationClient.getGradeOfLine(options, callback);
wkt | string | The Well Known Text(WKT) of the line feature to get the grade. | ||
IntervalDistance | number | Splits the requested line into intervals of this length. The unit of measure for this distance is specified by the IntervalDistanceUnit parameter. | ||
elevationClient.getElevationOfArea(options, callback)
Get the elevation of a matrix of points within an area
Syntax
var options = { wkt: 'POLYGON((-10717723.021919878 3864742.1417553322,-10718038.324661555 3864426.839013656,-10716901.323865812 3864503.2760419413,-10717723.021919878 3864742.1417553322))', srid: 3857, numberOfSegments:5, elevationUnit:'Meter', }; var callback = function (status, response) { console.log(response); }; elevationClient.getElevationOfArea(options, callback);
wkt | string | The Well Known Text (WKT) of a polygon feature to get the elevation. | ||
srid | integer | 4326 | The SRID (coordinate system) of the input polygon. | |
proj4String | string | The Proj4String (coordinate system) of the input polygon. | ||
IntervalDistance | number | 1000.0 | The distance between every two points in the area matrix. Elevation of each point will be calculated and returned. Defaults to 1000.0. The unit of measure for this distance is specified by the IntervalDistanceUnit parameter. | |
A class provides the methods to access the WorldImagery APIs.
Syntax
var mapClient = new tg.MapsClient ('Your-Cloud-Service-Api-Key');
a map object to access the Map APIs in ThinkGeo Cloud service.
mapClient.getRasterTile(options, callback)
Get a Maps raster tile by XYZ.
Syntax
var options = { z: 3, x: 2, y: 3, projection: 3857, mapType:'light', tileSize:512 tileResolution:1 }; var callback = function (status, response) { console.log(response); }; mapClient.getRasterTile(options, callback);
z | integer | The Z value (zoom level) of the tile to get. | ||
x | integer | The X value (matrix column) of the tile to get. | ||
y | integer | The Y value (matrix row) of the tile to get. | ||
projection | integer | The SRID in which to generate the tile. Currently only “3857” is supported. | ||
mapType | string | The style for the requested tile, include 'light', 'dark', 'hybrid', 'aerial', 'transparentBackground' | ||
tileSize | integer | The size of the tile to be returned, include 512,256. | ||
tileResolution | integer | The resolution for the request tile. include 1,2. | ||
mapClient.getVectorTile(options, callback)
Get a Maps Streets vector tile by XYZ.
Syntax
var options = { z: 3, x: 2, y: 3, projection: 3857 }; var callback = function (status, response) { console.log(response); }; mapClient.getVectorTile(options, callback);
A class that provides the methods to access the GIS Server Projection APIs. Converts geometry in Well Known Text format from one spatial reference system to another.
Syntax
var projectionClient = new tg.ProjectionClient('Your-Cloud-Service-Api-Key');
a project object to access the Projection APIs in ThinkGeo Cloud service.
projectionClient.project(options, callback)
Converts a geometry from one spatial reference system to another.
Syntax
var options = { pointX: 31.9000, pointY: -55.0000, fromProj: 4326, toProj: 3857 }; var callback = function (status, response) { console.log(response); }; projectionClient.project(options, callback);
wkt | string | The geometry that you want to reproject. | ||
body | object | A request object containing the geometries to be reprojected, as well as input and output spatial reference systems. | ||
fromProj | string | The EPSG/ESRI ID or Proj4 projection string describing the original spatial reference system in which the geometry is expressed. If using a Proj4 string, the value should be URL-encoded. | ||
toProj | string | The EPSG/ESRI ID or Proj4 projection string describing the target spatial reference system that you want the geometry reprojected to. If using a Proj4 string, the value should be URL-encoded. | ||
projectionClient.projectForPoint(pointY, pointX, fromProj, toProj, callback)
Syntax
var callback = function (status, response) { console.log(response); }; projectionClient.projectForPoint(-55.0000,31.9000,4326,3857, callback);
projectionClient.projectForGeometry(wkt, fromProj, toProj, callback)
Syntax
var callback = function (status, response) { console.log(response); }; projectionClient.projectForGeometry('LINESTRING(-1399103.3657318656 308805.5942721125,-802283.0488812095 592539.8432666864)',3857, 4326, callback);
projectionClient.projectForGeometries(options, callback)
Converts a collection of geometries in Well Known Text format from one spatial reference system to another.
Syntax
var wktArr=[ "POINT(-997961.8412912609 563188.0244051788)", "POINT(-900122.4450862352 484916.5074411584)", "POINT(-802283.0488812095 612107.7225076917)" ]; var options = { body: { wkt: wktArr, fromProj: "3857", toProj: "4326" } }; var callback = function (status, response) { console.log(response); }; projectionClient.projectForGeometries(options , callback);
A class provides the methods to access the ReverseGeocoding APIs. Reverse geocode to find locations near a geometry.
Syntax
var reverseGeocodingClient = new tg.ReverseGeocodingClient ('Your-Cloud-Service-Api-Key');
a ReverseGeocoding object to access the ReverseGeocoding APIs in ThinkGeo Cloud service.
reverseGeocodingClient.search(options, callback)
Searches for locations around a geometry.
Syntax
var options = { pointX: -10780076.527743513, pointY: 3864866.351926295, srid: 3857, }; var callback = function (status, response) { console.log(response); }; reverseGeocodingClient.search(options , callback);
wkt | string | The Well Known Text (WKT) of the geometry to use as the search area. | ||
body | array | A list of points to be reverse geocoded. | ||
srid | integer | 4326 | The SRID (coordinate system) in which to express the result. | |
proj4String | string | The Proj4String (coordinate system) in which to express the result. | ||
searchRadius | number | 200 | The maximun radius around the input point to search for places. Defaults to 200. | |
searchRadiusUnit | string | “Meter” | The unit of measure in which the SearchRadius is expressed. Defaults to “Meter”. | |
maxResults | integer | 20 | The maximum number of results to return. Defaults to 20. | |
locationCategories | string | “Common” | The categories of locations to include in the result set. The default value is “Common”. | |
locationTypes | string | Filters the resulting locations by type. Multiple types should be separated by a comma. Defaults to no filter. | ||
verboseResults | boolean | false | Indicates whether the results should be verbose or not. When false, the results will have fewer properties. Defaults to false. | |
distanceFromQueryFeatureUnit | string | “Meter” | The unit of measure in which the distance is expressed. Defaults to “Meter”. | |
lang | string | “en” | Optional. Sets the language for the search result. The default value is “en”. | |
reverseGeocodingClient.searchPlaceByPoint(pointY, pointX, callback, options)
Syntax
var options = { srid: 3857 }; var callback = function (status, response) { console.log(response); }; reverseGeocodingClient.searchPlaceByPoint(3864866.351926295, -10780076.527743513, callback, options);
callback | function | the callback for response | ||
reverseGeocodingClient.searchPlaceByLine(wkt, callback, options)
Searches for locations around a line.
Syntax
var options = { srid: 3857, }; var callback = function (status, response) { console.log(response); }; reverseGeocodingClient.searchPlaceByLine("LINESTRING(-10780840.898026364 3864952.343583116,-10780219.847171547 3865009.67135433)", callback, options);
reverseGeocodingClient.searchPlaceByArea(wkt, callback, options)
Syntax
var wkt= "POLYGON((-10780611.586941509 3864847.242669224,-10780831.343397828 3864617.9315843685,-10780363.166599581 3864637.0408414397,-10780611.586941509 3864847.242669224))" var options = { srid: 3857, }; var callback = function (status, response) { console.log(response); }; reverseGeocodingClient.searchPlaceByArea(wkt, callback, options);
reverseGeocodingClient.searchPlaceByPoints(options, callback)
Searches for locations around multi points.
Syntax
var options = { body:[ { coord: "32.8345,-96.8616", srid: 4326 }, { coord: "34.8345,-93.8616", srid: 4326 } ] }; var callback = function (status, response) { console.log(response); }; reverseGeocodingClient.searchPlaceByPoints(options , callback);
reverseGeocodingClient.searchPlaceById(placeId, callback, options)
Get details about a place by its OpenStreetMap ID.
Syntax
var options={ lang:"en" } var callback = function (status, response) { console.log(response); }; reverseGeocodingClient.searchPlaceById(8689729, callback, options);
placeId | integer | The OpenStreetMap ID of the place | ||
reverseGeocodingClient.getPlaceCatergories(callback)
Get the available location categories.
Syntax
var callback = function (status, response) { console.log(response); }; reverseGeocodingClient.getPlaceCatergories(callback);
reverseGeocodingClient.getCommonCatergories(callback)
Get the types of locations that are considered common.
Syntax
var callback = function (status, response) { console.log(response); }; reverseGeocodingClient.getCommonCatergories(callback);
A class provides the methods to access the GeocodingClient APIs. Geocode to get the coordinates of an address.
Syntax
var geocodingClient = new tg.GeocodingClient ('Your-Cloud-Service-Api-Key');
a Geocoding object to access the Geocoding APIs in ThinkGeo Cloud service.
geocodingClient.search(options, callback)
Search for a location expression.
Syntax
var options = { location: "Dallas", maxResults: 5, }; var callback = function (status, response) { console.log(response); }; geocodingClient.search(options, callback);
location | array | The location expression. | ||
body | string | A list of addresses to be geocoded. | ||
locationType | string | Specifies what types of locations will be considered a match. Possible values are Address, Street, State, City, County, Zipcode, Country. | ||
fuzzyMatch | boolean | false | Specifies whether to attempt approximate, as well as exact, matching when performing geocodes. Defaults to false. | |
maxResults | integer | 10 | The maximum number of possible matches to return, if multiple candidates are found. Defaults to 10. | |
srid | integer | The SRID (coordinate system ID) in which to express the result. Mutually exclusive from the Proj4String parameter. | ||
proj4String | string | “+proj=longlat +datum=WGS84 +no_defs” | The Proj4 projection string (coordinate system) in which to express the result. Mutually exclusive from the Srid parameter. Defaults to “+proj=longlat +datum=WGS84 +no_defs”. | |
geocodingClient.searchByPoint(location, callback, options)
Syntax
var options = { maxResults: 5, }; var callback = function (status, response) { console.log(response); }; geocodingClient.searchByPoint("Dallas", callback, options);
location | string | The location expression. | ||
geocodingClient.searchBatch(options, callback)
Syntax
var options = { body:[ { searchText:"Dallas", maxResults:5 }, { searchText:"Frisco" } ] maxResults: 6, }; var callback = function (status, response) { console.log(response); }; geocodingClient.searchBatch(options, callback);
A class provides the methods to access the Routing APIs. Get turn-by-turn driving directions, define service areas that can be reached by car in a given time or distance, and more.
Syntax
var routingClient = new tg.RoutingClient ('Your-Cloud-Service-Api-Key');
a Routing object to access the Routing APIs in ThinkGeo Cloud service.
routingClient.getRoute(waypoints, callback, options)
Get a route through the specified waypoints.
Syntax
var waypoints = [{ x: -96.872893, y: 33.184352 },{ x: -83.441568, y: 42.404719 }]; var options = { srid: 4326, turnByTurn: true, distanceUnit: 'Meter', durationUnit: 'Minute' }; var callback = function (status, response) { console.log(response); }; routingClient.getRoute(waypoints, callback, options);
waypoints | array | A list of coordinates to travel in order. | ||
callback | function | the callback for response. | ||
srid | integer | The SRID (coordinate system ID) in which to input and output the result. Mutually exclusive from the Proj4String parameter. | ||
proj4String | string | “+proj=longlat +datum=WGS84 +no_defs” | The Proj4 projection string (coordinate system) in which to input and output the result. Mutually exclusive from the Srid parameter. Defaults to “+proj=longlat +datum=WGS84 +no_defs”. | |
turnByTurn | boolean | false | Whether to return turn-by-turn instructions or not. Defaults to false. | |
coordinateSnapRadius | double | 5000 | The maximum distance of a coordinate can be snapped to the road network. Defaults to 5000 meters. | |
coordinateSnapRadiusUnit | string | meter | The unit of the radius to snap the input coordinate to road network. | |
distanceUnit | string | meter | The unit of measure in which to express the length of the route. Default to Meter. | |
durationUnit | string | minute | The unit of the time in which to express the duration of the route. |
routingClient.getServiceArea(pointY, pointX, serviceLimits, callback, options)
Get the reachable service area (isochrones) for a coordinate point, based on the specified time or distance constraints.
Syntax
var serviceLimits = [10, 30, 60]; var callback = function (status, response) { console.log(response); }; var options = { srid = 3857, serviceLimitsType = 'Time', durationUnit = 'minute', distanceUnit = 'meter' }; routingClient.getServiceArea(33.184352, -96.872893, serviceLimits, callback, options);
pointY | double | The Y coordinate of the point. | ||
pointX | double | The X coordinate of the point. | ||
serviceLimits | array | The list represents the travel distances or travel times to generate for each facility. The maximum number of serviceLimits is 6. | ||
contourGranularity | double | 1.0 | A float in the range of (0, 1.0) to identify how much we want to remove the contours. 0 means do not remove any contour at all, 1.0 means only return the largest contour. | |
coordinateSnapRadius | double | 5000 | The maximum distance of a coordinate can be snapped to the road network. | |
distanceUnit | string | meter | The unit of measure in which to express the length of route. | |
durationUnit | string | minute | The unit of the time in which to express the duration of traveling the route. | |
gridSizeInMeters | double | 400 | A float value in meters used as the tolerance for concave polygon. The smaller of the number is getting more accurate of the service areas but slower performance, better a value bigger than 300, but depends on the size of the result coverage. | |
serviceAreaSeparationType | string | separated | Specify whether to include the region covered by the smaller service area into the region covered by the larger service area. | |
serviceAreaType | string | polygon | Indicates whether the result is returned as polygons enveloping the accessible roads, or as linestrings surrounding those roads. | |
serviceLimitsType | string | time | Indicates the unit of the serviceLimits. | |
travelDirection | string | from | Indicates the direction of travel to or from the coordinates. |
Coming soon.
A class provides the basic methods to send request to ThinkGeo Cloud services. Subclasses: ColorClient, Elevation, GeocodingClient, MapsClient, ProjectionClient, ReverseGeocodingClient.
on
// For example elevationClient elevationClient.on("sendingrequest", function (e){ console.log(e); }); elevationClient.on("sentrequest", function (e){ console.log(e); })
