thinkgeo_cloud_javascript_client_apis
ThinkGeoCloudClient-js
NameSapce
tg is the abbreviation of ThinkGeo, the namespace of ThinkGeoCloudClient-js
tg.ColorClient
A class provides the methods to access the ColorUtilities APIs. Generats an diversified family of colors by an input color or a random base color.
Syntax
var colorClient = new tg.ColorClient('Your-Cloud-Service-Api-Key');
Name Type Description
apiKey string An API key for access to ThinkGeo Cloud services, it can be created following the guide
a color object to access the ColorUtilities APIs in ThinkGeo Cloud service.
colorClient.getColorsInAnalogousFamily(options, callback)
Get a family of colors based on three analogous hues.
Syntax
  var options = {
      numberOfColors: 25
  var callback = function (status, response) {
      console.log(response);
  colorClient.getColorsInAnalogousFamily(options, callback);
options Options
Name Type Default Description
numberOfColors integer A number of output colors desired. The value must be between 3 and 54.
color string A base color. Two analogous hues will be found for you. If null, use random color.
outFormat string Hex The format in which you want the output colors. Supported formats: Hex, RGB, HSL.
inFormat string Hex/RGB The format of the input Color. Supported formats: Hex, RGB, HSL. If not specified, we will try to parse the inputColor as Hex first, then RGB.
callback function the callback for response
colorClient.getColorsInComplementaryFamily(options, callback)
Get a family of colors based on two complementary hues.
Syntax
  var options = {
      numberOfColors: 25
  colorClient.getColorsInComplementaryFamily(options, callback);
options Options
numberOfColors integer The total number of colors you want to be returned. The value must be between 2 and 36.
color string A base color. A complementary hue will be found for you.
inFormat string Hex/RGB The format of the input Color. Supported formats: Hex, RGB, HSL. If not specified, we will try to parse the input Color as Hex first, then RGB.
colorClient.getColorsInContrastingFamily(options, callback)
Get a family of colors based on two contrasting hues.
Syntax
  var options = {
      numberOfColors: 25
  colorClient.getColorsInContrastingFamily(options, callback);
options Options
color string A base color. A contrasting hue will be found for you.
colorClient.getColorsInHueFamily(options, callback)
Get a family of colors with the same hue and sequential variances in lightness and saturation.
Syntax
  var options = {
      numberOfColors: 25
  colorClient.getColorsInHueFamily(options, callback);
options Options
numberOfColors integer The total number of colors you want to be returned. The value must be between 1 and 255.
colorClient.getColorsInQualityFamily(options, callback)
Get a family of colors with qualitative variances in hue, but similar lightness and saturation.
Syntax
  var options = {
      numberOfColors: 25
  colorClient.getColorsInQualityFamily(options, callback);
options Options
color string The color on which you want to base the color collection.
colorClient.getColorsInTetradFamily(options, callback)
Get a family of colors based on a harmonious tetrad of hues.
Syntax
  var options = {
      numberOfColors: 25
  colorClient.getColorsInTetradFamily(options, callback);
options Options
numberOfColors integer The total number of colors you want returned. The value must be between 4 and 72.
color string A base color. Three harmonious hues will be found for you to create a tetrad.
inFormat string Hex/RGB The format of the inputColor. Supported formats: Hex, RGB, HSL. f unspecified, we will try to parse the inputColor as Hex first, then RGB.
colorClient.getColorsInTriadFamily(options, callback)
Get a family of colors based on a harmonious triad of hues.
Syntax
  var options = {
      numberOfColors: 25
options Options
numberOfColors integer The number of colors you want returned. The value must be between 3 and 54.v
color string The color on which you want to base the colors collections.
tg.ElevationClient
A class provides the methods to access the Elevation APIs. Get the elevation of a geometry, include point, line, polygon.
Syntax
var elevationClient = new tg.ElevationClient('Your-Cloud-Service-Api-Key');
a elevation object to access the Elevation APIs in ThinkGeo Cloud service.
elevationClient.getElevationOfPoint(options, callback)
Get the elevation of a point.
Syntax
  var options = {
      pointY: 33.128367,
      pointX:-96.809847,
      srid: 4326,
      elevationUnit:'Feet'
  elevationClient.getElevationOfPoint(options, callback);
options Options
pointY number The Y coordinate of the point.
pointX number The X coordinate of the point.
srid integer 4326 The SRID (coordinate system) of the input Point.
proj4String string The Proj4 (coordinate system) of the input Point.
elevationUnit string “Feet” The unit of measure in which the elevation result is expressed.
elevationClient.getElevationOfPoints(options, callback)
Get the elevations of all the points in a collection (up to 1,000 points maximum).
Syntax
   var options = {
      body:[
               "coord":"33.128367,-96.809847",
               "srid":4326,
               "elevationUnit":"Meter"
      srid: 4326,
      elevationUnit:'Meter'
  elevationClient.getElevationOfPoints(options, callback);
options Options
body array A collection of point in JSON, the srid, proj4String and elevationUnit can be individually specified for each point.
srid integer 4326 The common SRID (coordinate system) for points which hasn't been specified.
proj4String string The common Proj4 (coordinate system) for points which hasn't been specified.
elevationClient.getElevationOfLine(options, callback)
Get the elevation of points along a line.
Syntax
 var options = {
      wkt: 'LINESTRING(-10717751.685805485 3864388.620499513,-10717359.946035523 3864570.1584416907)',
      srid: 3857,
      numberOfSegments:5,
      elevationUnit:'Meter',
options Options
wkt string The Well Known Text (WKT) of a line feature to get the elevation.
srid integer 4326 The SRID (coordinate system) of the input line.
proj4String string The Proj4String (coordinate system) of the input line.
numberOfSegments integer Splits the requested line into this many segments, then calculates elevation of each point joining the segments.
IntervalDistance integer Splits the requested line into intervals of this length. The unit of measure for this distance is specified by the IntervalDistanceUnit parameter.
IntervalDistanceUnit string “Feet” The unit of measure in which the IntervalDistance is expressed.
elevationClient.getGradeOfLine(options, callback)
Get the grade (slope) of a line, optionally split into segments.
Syntax
 var options = {
      srid: 3857,
      numberOfSegments:5,
  elevationClient.getGradeOfLine(options, callback);
options Options
wkt string The Well Known Text(WKT) of the line feature to get the grade.
IntervalDistance number Splits the requested line into intervals of this length. The unit of measure for this distance is specified by the IntervalDistanceUnit parameter.
elevationClient.getElevationOfArea(options, callback)
Get the elevation of a matrix of points within an area
Syntax
 var options = {
      wkt: 'POLYGON((-10717723.021919878 3864742.1417553322,-10718038.324661555 3864426.839013656,-10716901.323865812 3864503.2760419413,-10717723.021919878 3864742.1417553322))',
      srid: 3857,
      numberOfSegments:5,
  elevationClient.getElevationOfArea(options, callback);
options Options
wkt string The Well Known Text (WKT) of a polygon feature to get the elevation.
srid integer 4326 The SRID (coordinate system) of the input polygon.
proj4String string The Proj4String (coordinate system) of the input polygon.
IntervalDistance number 1000.0 The distance between every two points in the area matrix. Elevation of each point will be calculated and returned. Defaults to 1000.0. The unit of measure for this distance is specified by the IntervalDistanceUnit parameter.
tg.MapsClient
A class provides the methods to access the WorldImagery APIs.
Syntax
var mapClient = new tg.MapsClient ('Your-Cloud-Service-Api-Key');
a map object to access the Map APIs in ThinkGeo Cloud service.
mapClient.getRasterTile(options, callback)
Get a Maps raster tile by XYZ.
Syntax
  var options = {
      z: 3,
      x: 2,
      y: 3,
      projection: 3857,
      mapType:'light',
      tileSize:512
      tileResolution:1
  mapClient.getRasterTile(options, callback);
options Options
z integer The Z value (zoom level) of the tile to get.
x integer The X value (matrix column) of the tile to get.
y integer The Y value (matrix row) of the tile to get.
projection integer The SRID in which to generate the tile. Currently only “3857” is supported.
mapType string The style for the requested tile, include 'light', 'dark', 'hybrid', 'aerial', 'transparentBackground'
tileSize integer The size of the tile to be returned, include 512,256.
tileResolution integer The resolution for the request tile. include 1,2.
mapClient.getVectorTile(options, callback)
Get a Maps Streets vector tile by XYZ.
Syntax
  var options = {
      z: 3,
      x: 2,
      y: 3,
      projection: 3857
  mapClient.getVectorTile(options, callback);
options Options
tg.ProjectionClient
A class that provides the methods to access the GIS Server Projection APIs. Converts geometry in Well Known Text format from one spatial reference system to another.
Syntax
var projectionClient = new tg.ProjectionClient('Your-Cloud-Service-Api-Key');
a project object to access the Projection APIs in ThinkGeo Cloud service.
projectionClient.project(options, callback)
Converts a geometry from one spatial reference system to another.
Syntax
  var options = {
    pointX: 31.9000,
    pointY: -55.0000,
    fromProj: 4326,
    toProj: 3857
  projectionClient.project(options, callback);
options Options
wkt string The geometry that you want to reproject.
body object A request object containing the geometries to be reprojected, as well as input and output spatial reference systems.
fromProj string The EPSG/ESRI ID or Proj4 projection string describing the original spatial reference system in which the geometry is expressed. If using a Proj4 string, the value should be URL-encoded.
toProj string The EPSG/ESRI ID or Proj4 projection string describing the target spatial reference system that you want the geometry reprojected to. If using a Proj4 string, the value should be URL-encoded.
projectionClient.projectForPoint(pointY, pointX, fromProj, toProj, callback)
Syntax
  projectionClient.projectForPoint(-55.0000,31.9000,4326,3857, callback);
projectionClient.projectForGeometry(wkt, fromProj, toProj, callback)
Syntax
  projectionClient.projectForGeometry('LINESTRING(-1399103.3657318656 308805.5942721125,-802283.0488812095 592539.8432666864)',3857, 4326, callback);
projectionClient.projectForGeometries(options, callback)
Converts a collection of geometries in Well Known Text format from one spatial reference system to another.
Syntax
   var wktArr=[
      "POINT(-997961.8412912609 563188.0244051788)",
      "POINT(-900122.4450862352 484916.5074411584)",
      "POINT(-802283.0488812095 612107.7225076917)"
   var options = {
      body: {
          wkt: wktArr,
          fromProj: "3857",
          toProj: "4326"
  projectionClient.projectForGeometries(options , callback);
options Options
tg.ReverseGeocodingClient
A class provides the methods to access the ReverseGeocoding APIs. Reverse geocode to find locations near a geometry.
Syntax
  var reverseGeocodingClient = new tg.ReverseGeocodingClient ('Your-Cloud-Service-Api-Key');
a ReverseGeocoding object to access the ReverseGeocoding APIs in ThinkGeo Cloud service.
reverseGeocodingClient.search(options, callback)
Searches for locations around a geometry.
Syntax
  var options = {
      pointX: -10780076.527743513,
      pointY: 3864866.351926295,
      srid: 3857,
  reverseGeocodingClient.search(options , callback);
options Options
wkt string The Well Known Text (WKT) of the geometry to use as the search area.
body array A list of points to be reverse geocoded.
srid integer 4326 The SRID (coordinate system) in which to express the result.
proj4String string The Proj4String (coordinate system) in which to express the result.
searchRadius number 200 The maximun radius around the input point to search for places. Defaults to 200.
searchRadiusUnit string “Meter” The unit of measure in which the SearchRadius is expressed. Defaults to “Meter”.
maxResults integer 20 The maximum number of results to return. Defaults to 20.
locationCategories string “Common” The categories of locations to include in the result set. The default value is “Common”.
locationTypes string Filters the resulting locations by type. Multiple types should be separated by a comma. Defaults to no filter.
verboseResults boolean false Indicates whether the results should be verbose or not. When false, the results will have fewer properties. Defaults to false.
distanceFromQueryFeatureUnit string “Meter” The unit of measure in which the distance is expressed. Defaults to “Meter”.
lang string “en” Optional. Sets the language for the search result. The default value is “en”.
reverseGeocodingClient.searchPlaceByPoint(pointY, pointX, callback, options)
Syntax
  var options = {
      srid: 3857
  reverseGeocodingClient.searchPlaceByPoint(3864866.351926295, -10780076.527743513, callback, options);
options Options
reverseGeocodingClient.searchPlaceByLine(wkt, callback, options)
Searches for locations around a line.
Syntax
  var options = {
      srid: 3857,
  reverseGeocodingClient.searchPlaceByLine("LINESTRING(-10780840.898026364 3864952.343583116,-10780219.847171547 3865009.67135433)", callback, options);
options Options
reverseGeocodingClient.searchPlaceByArea(wkt, callback, options)
Syntax
  var wkt= "POLYGON((-10780611.586941509 3864847.242669224,-10780831.343397828 3864617.9315843685,-10780363.166599581 3864637.0408414397,-10780611.586941509 3864847.242669224))"
  var options = {
      srid: 3857,
  reverseGeocodingClient.searchPlaceByArea(wkt, callback, options);
options Options
reverseGeocodingClient.searchPlaceByPoints(options, callback)
Searches for locations around multi points.
Syntax
  var options = {
      body:[
             coord: "32.8345,-96.8616",
             srid: 4326
             coord: "34.8345,-93.8616",
             srid: 4326
  reverseGeocodingClient.searchPlaceByPoints(options , callback);
options Options
reverseGeocodingClient.searchPlaceById(placeId, callback, options)
Get details about a place by its OpenStreetMap ID.
Syntax
  var options={
      lang:"en"
  reverseGeocodingClient.searchPlaceById(8689729, callback, options);
placeId integer The OpenStreetMap ID of the place
options Options
reverseGeocodingClient.getPlaceCatergories(callback)
Get the available location categories.
Syntax
  reverseGeocodingClient.getPlaceCatergories(callback);
reverseGeocodingClient.getCommonCatergories(callback)
Get the types of locations that are considered common.
Syntax
  reverseGeocodingClient.getCommonCatergories(callback);
tg.GeocodingClient
A class provides the methods to access the GeocodingClient APIs. Geocode to get the coordinates of an address.
Syntax
var geocodingClient = new tg.GeocodingClient ('Your-Cloud-Service-Api-Key');
a Geocoding object to access the Geocoding APIs in ThinkGeo Cloud service.
geocodingClient.search(options, callback)
Search for a location expression.
Syntax
  var options = {
       maxResults: 5,
  geocodingClient.search(options, callback);
options Options
location array The location expression.
body string A list of addresses to be geocoded.
locationType string Specifies what types of locations will be considered a match. Possible values are Address, Street, State, City, County, Zipcode, Country.
fuzzyMatch boolean false Specifies whether to attempt approximate, as well as exact, matching when performing geocodes. Defaults to false.
maxResults integer 10 The maximum number of possible matches to return, if multiple candidates are found. Defaults to 10.
srid integer The SRID (coordinate system ID) in which to express the result. Mutually exclusive from the Proj4String parameter.
proj4String string “+proj=longlat +datum=WGS84 +no_defs” The Proj4 projection string (coordinate system) in which to express the result. Mutually exclusive from the Srid parameter. Defaults to “+proj=longlat +datum=WGS84 +no_defs”.
geocodingClient.searchByPoint(location, callback, options)
Syntax
  var options = {
       maxResults: 5,
  geocodingClient.searchByPoint("Dallas", callback, options);
location string The location expression.
options Options
geocodingClient.searchBatch(options, callback)
Syntax
  var options = {
       body:[
              searchText:"Dallas",
              maxResults:5
              searchText:"Frisco"
       maxResults: 6,
  geocodingClient.searchBatch(options, callback);
options Options
tg.BaseClient
A class provides the basic methods to send request to ThinkGeo Cloud services. Subclasses: ColorClient, Elevation, GeocodingClient, MapsClient, ProjectionClient, ReverseGeocodingClient.
on
  • sendingrequest
  • sentrequest
// For example elevationClient
elevationClient.on("sendingrequest", function (e){
    console.log(e);
elevationClient.on("sentrequest", function (e){
    console.log(e);
thinkgeo_cloud_javascript_client_apis.1550260682.txt.gz · Last modified: 2019/02/15 19:58 by benbai
