thinkgeo_cloud_colors
ThinkGeo Cloud Colors
ThinkGeo Cloud Colors provides some ways to generate families of colors based on the input color. Check out Generate Color Themes for a quick look.
RESTful APIs
There are two kinds of APIs provided by ThinkGeo Cloud Colors Utility that provide different color generation algorithms.
Generate Colors Based On A Specific Color
https://cloud.thinkgeo.com/api/v1/color/scheme/{algorithm}/{inputColor}/{numberOfColors}?inFormat={inFormat}&outFormat={outFormat}&apiKey={apiKey}
  • algorithm: The algorithm, supported values are:
    • analogous: Get a family of colors based on three analogous hues.
    • complementary: Get a family of colors based on two complementary hues.
    • contrasting: Get a family of colors based on two contrasting hues.
    • sequential: Get a family of colors with the same hue and sequential variances in lightness and saturation.
    • qualitative: Get a family of colors with qualitative variances in hue, but similar lightness and saturation.
    • tetrad: Get a family of colors based on a harmonious tetrad of hues.
    • triad: Get a family of colors based on a harmonious triad of hues.
  • inputColor: A base color, for different algorithms:
    • analogous: Two analogous hues will be found for you.
    • complementary: A complementary hue will be found for you.
    • contrasting: A contrasting hue will be found for you.
    • sequential: It's the color on which you want to base the color collection.
    • qualitative: It's the color on which you want to base the color collection.
    • tetrad: Three harmonious hues will be found for you.
    • triad: It's the color on which you want to base the colors collections.
  • numberOfColors: The total number of colors you want to be returned, for different algorithms:
    • analogous: The value must be between 3 and 54.
    • complementary: The value must be between 2 and 36.
    • contrasting: The value must be between 2 and 36.
    • sequential: The value must be between 1 and 255.
    • qualitative: The value must be between 1 and 255.
    • tetrad: The value must be between 4 and 72.
    • triad: The value must be between 3 and 54.
  • apikey: the apikey
  • inFormat (optional): The format of the inputColor. Supported formats: Hex, RGB, HSL. If unspecified, the server will try to parse the inputColor in the order of Hex, RGB and HSL.
  • outFormat (optional): The format in which you want the output colors. Supported formats: Hex, RGB, HSL. Defaults to Hex.
Sample Request https://cloud.thinkgeo.com/api/v1/color/scheme/analogous/FF00FF/5?apiKey=mykey
Responses
  • 200: Success.
  • 401: Unauthorized.
  • 403: Forbidden.
Generate Colors Based On A Random Color
Three analogous colors will be generated randomly as the base colors
https://cloud.thinkgeo.com/api/v1/color/scheme/{algorithm}/random/{numberOfColors}?outFormat={outFormat}&apiKey={apiKey}
  • numberOfColors: The total number of colors you want to be returned, for different algorithm:
Sample Request https://cloud.thinkgeo.com/api/v1/color/scheme/analogous/random/5?apiKey=mykey
Responses
  • 200: Success.
  • 403: Forbidden.
Try it Online
Consume From Client Side SDKs
A .Net SDK ThinkGeo Cloud Client is provided to consume the ThinkGeo Cloud Service as well. It's available on NuGet, here is the complete API List.
Sample Code:
ColorClient client = new ColorClient("clientId", "clientSecret");
Dictionary<GeoColor, Collection<GeoColor>> results = client.GetColorsInAnalogousFamily(new GeoColor(255, 0, 255), 5);
Task<Dictionary<GeoColor, Collection<GeoColor>>> results = client.GetColorsInAnalogousFamily(new GeoColor(255, 0, 255), 5);
Dictionary<GeoColor, Collection<GeoColor>> results = client.GetColorsInAnalogousFamily(5);
Task<Dictionary<GeoColor, Collection<GeoColor>>> results = client.GetColorsInAnalogousFamily(5);
Samples
thinkgeo_cloud_colors.1550251061.txt.gz · Last modified: 2019/02/15 17:17 by benbai
