thinkgeo.mapsuite.wpfdesktopedition.overlaysdrawnwpfmapeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs
This is the event arguments for the OverlaysDrawn event on the MapEngine class. It is raised after the overlays are drawn.
      • ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs
OverlaysDrawnWpfMapEventArgs()
Constructor of OverlaysDrawnWpfMapEventArgs class.
This is the default constructor. If you use this constructor then you need to set the required properties manually.
OverlaysDrawnWpfMapEventArgs(IEnumerable<Overlay>,RectangleShape)
  • overlays
    • Type:IEnumerable<Overlay>
    • Description:This parameter is the overlays that have been drawn.
  • worldExtent
    • Description:This parameter is the wold extent that has been drawn.
WorldExtent
Gets or sets the world extent that has been drawn.
Overlays
This property gets the overlays you have drawn.
thinkgeo.mapsuite.wpfdesktopedition.overlaysdrawnwpfmapeventargs.1442546072.txt.gz · Last modified: 2015/09/18 03:14 by admin
