<!– Class –> This is the event arguments for the OverlaysDrawn event on the MapEngine class. It is raised after the overlays are drawn.
This is the event arguments for the OverlaysDrawn event on the MapEngine class. It is raised after the overlays are drawn. This event allows you draw something with the canvas after the Layer draws.
*System.Object System.EventArgs *ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs
OverlaysDrawnWpfMapEventArgs | Constructor of OverlaysDrawnWpfMapEventArgs class. | ||
OverlaysDrawnWpfMapEventArgs | IEnumerable<Overlay>, RectangleShape | Constructor of OverlaysDrawnWpfMapEventArgs class. |
Overlays | IEnumerable<Overlay> | This property gets the overlays you have drawn. | |
WorldExtent | RectangleShape | Gets or sets the world extent that has been drawn. |
This is the default constructor. If you use this constructor then you need to set the required properties manually.
This constructor allows you to set the overlays drawn, the world extent and the image you have drawn on.
| overlays | IEnumerable<Overlay><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WpfDesktopEdition.Overlay} –> | This parameter is the overlays that have been drawn. |
| worldExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter is the wold extent that has been drawn. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs#firstHeading" class="firstHeading" lang="en"><span dir="auto” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs#firstHeading“ class=“firstHeading” lang=“en”><span dir=“auto</a>
<!– ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs#WorldExtent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawnWpfMapEventArgs#WorldExtent</a>
