<!– Class –> This is the event arguments for the OverlaysDrawing event on the MapEngine class. It is raised before any of the overlays are drawn.
This is the event arguments for the OverlaysDrawing event on the MapEngine class. It is raised before any of the overlays are drawn. This event allows you to cancel, manipulate the Layer, or draw something with the canvas before the Layer draws.
*System.Object System.EventArgs *ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs
OverlaysDrawingWpfMapEventArgs | Constructor of OverlaysDrawingWpfMapEventArgs class. | ||
OverlaysDrawingWpfMapEventArgs | IEnumerable<Overlay>, RectangleShape, Boolean | Constructor of OverlaysDrawingWpfMapEventArgs class. |
Cancel | Boolean | Gets or sets whether the action will be canceled or not. | |
Overlays | IEnumerable<Overlay> | This property gets the overlays you will be drawing. | |
WorldExtent | RectangleShape | Gets or sets the world extent to draw. |
This is the default constructor. If you use this constructor then you need to set the required properties manually.
This constructor allows you to set the overlays to be drawn, the world extent and the image you are drawing on.
| overlays | IEnumerable<Overlay><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WpfDesktopEdition.Overlay} –> | This parameter is the overlays that will be drawing. |
| worldExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter is the wold extent you are drawing. |
| cancel | Boolean<!– System.Boolean –> | This parameter specifies whether we need to cancel drawing the overlays or not. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#Cancel” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#Cancel</a>
<!– ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#firstHeading" class="firstHeading" lang="en"><span dir="auto” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#firstHeading“ class=“firstHeading” lang=“en”><span dir=“auto</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#WorldExtent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlaysDrawingWpfMapEventArgs#WorldExtent</a>
